Home » Eclipse Projects » Rich Client Platform (RCP) » Add Tabbed pane to a ViewPart
Add Tabbed pane to a ViewPart [message #517021] Thu, 25 February 2010 13:36 Go to next message
Originally posted by: rob.a.wood.gmail.com
I have a view that extends ViewPart and is implemented as a Form. I
need to restructure it to add more information, and the best way to
organize it visually will be to use tabs. I've investigated using
TabFolder/CTabFolder, but the TabItem can only accept a Control. At
this point the only solution I can see is to provide a very crude
simulation: use buttons as proxies for tabs, and clear / rebuild the
entire form each time a button is clicked -- this is very expensive and
error prone, so I'm looking for any a better approach.
Any sane recommendations for simulating a tabbed pane (like JTabbedPane,
but compatible with Forms) would be greatly appreciated.
- Rob
Re: Add Tabbed pane to a ViewPart [message #517181 is a reply to message #517021] Fri, 26 February 2010 09:19 Go to previous messageGo to next message
Why would only accepting a control be a problem? AFAIK you would place
a Composite in each CTabItem. You can then break up your Form, one per
Composite as you need to break up information.
Check out org.eclipse.ui.part.MultiPageEditorPart (as a code example)
which uses a CTabFolder and is used to implement editors like the PDE
MANIFEST.MF editor.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Add Tabbed pane to a ViewPart [message #517731 is a reply to message #517181] Mon, 01 March 2010 15:46 Go to previous message
> MANIFEST.MF editor.
> PW
Thanks for the suggestion. I studied MultiPageEditorPart, and, after a
little trial and error, got it working.
Previous Topic:Eclipse 3.5.1 destroys editor titles...
Next Topic:cannot run application on mac os x
Current Time: Sun Jul 20 16:26:20 EDT 2025
Powered by FUDForum. Page generated in 0.05870 seconds
