Home » Language IDEs » Objectteams » eclipse update OTDT failed(eclipse update OTDT failed)
eclipse update OTDT failed [message #516871] Thu, 25 February 2010 12:18 Go to next message
Jarn Tang is currently offline Jarn TangFriend
what's happen when update in eclipse 3.6 ?
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.objectteams.jdt.ui.adaptor,1.4.0.20100127193 0
No repository found containing: osgi.bundle,org.objectteams.otdt,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.compiler.adaptor,1.4.0.2010 01271930
No repository found containing: osgi.bundle,org.objectteams.otdt.debug.adaptor,1.4.0.2010012 71930
No repository found containing: osgi.bundle,org.objectteams.otdt.debug.ui,1.3.2.200909280002
No repository found containing: osgi.bundle,org.objectteams.otdt.metrics,1.3.2.200909280002
No repository found containing: osgi.bundle,org.objectteams.otdt.pde.ui,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.refactoring.adaptor,1.4.0.2 01001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.samples,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.ui,1.4.0.201001271930
No repository found containing: osgi.bundle,org.objectteams.otdt.ui.help,1.4.0.201001280200
No repository found containing: osgi.bundle,org.objectteams.otequinox.runtime,1.4.0.20100127 1930
No repository found containing: osgi.bundle,org.objectteams.runtime,1.3.2.200909280002
Re: eclipse update OTDT failed [message #516902 is a reply to message #516871] Thu, 25 February 2010 13:53 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan HerrmannFriend
Dear Jarn Tang
From the version numbers I assume you have an Eclipse 3.6. M5
installed and try to install the OTDT 1.4.0 M3, right?
Those versions are compatible and so installing *should* definitely work.
From my experience with p2, the error message might hint at some
networking problem. For that reason I have prepared a zip file at
http://www.objectteams.org/distrib/otdt-updates-1.4.zip
(32 MB)
Could you please download this file, unpack in a temporary location
and within Eclipse add the unpacked directory otdt-updates-1.4
as a local software site. Are you able to install from there?
It might be necessary to uncheck [] Group items by category
I'm not sure.
Does this work for you?
Stephan
Re: eclipse update OTDT failed [message #517074 is a reply to message #516902] Fri, 26 February 2010 05:08 Go to previous messageGo to next message
Dear Stephan
Thanks for your reply 。you are right ,I have an Eclipse 3.6 M5 installed, however it's normal when use eclipse 3.5 to install. So the network didn't problem.I will try to install with zip.
Jarn Tang
Re: eclipse update OTDT failed [message #517213 is a reply to message #517074] Fri, 26 February 2010 15:44 Go to previous message
Jarn Tang wrote on Fri, 26 February 2010 00:08
Dear Stephan
It could still happen, that network connection failed just once and
perhaps p2 has cached incomplete information.
Those things are very difficult to debug.
Jarn Tang
Please let me know if the problem persists.
In that case I would need some more details of what exactly
you tried, in order to understand what is going on.
cheers,
Stephan
Re: eclipse update OTDT failed [message #569110 is a reply to message #516902] Fri, 26 February 2010 05:08 Go to previous message
Dear Stephan
Jarn Tang
Re: eclipse update OTDT failed [message #569198 is a reply to message #569110] Fri, 26 February 2010 15:44 Go to previous message
> Dear Stephan
> Jarn Tang
cheers,
Stephan
Previous Topic:Feedback on examples
Next Topic:Yet another release: OTDT 1.3.3
Current Time: Sun May 31 05:24:33 GMT 2020
Powered by FUDForum. Page generated in 0.02457 seconds
