Home » Modeling » GMF (Graphical Modeling Framework) » Link Mapping without Source or Target Feature
Link Mapping without Source or Target Feature [message #516614] Wed, 24 February 2010 15:16 Go to next message
Dennis sui is currently offline Dennis suiFriend
Member
i have a ecore Model for a special Statemachine.
The State an Transition Classes look like this:
State : EClass
->name : String
->transitions : Transition
Transition:EClass
->id : String
->target : String
the target Attribute in Transition should be the name of a state.
Of course, I could change the ecore Model and add State References in the Transition Type Class but is there a way without changing the ecore Model for that?
Re: Link Mapping without Source or Target Feature [message #519213 is a reply to message #516614] Mon, 08 March 2010 05:32 Go to previous message
Jevon  is currently offline Jevon Friend
Hi Sui,
If you set State.name as the unique ID in EMF, and Transition to an
EReference of State, you should be able to emulate this functionality
without needing to modify any GMF code.
Cheers
Jevon
Sui wrote:
> State : EClass
> ->name : String
> Transition:EClass
> ->id : String
> ->target : String
> Model for that?
Previous Topic:Manage non-graphical nodes
Next Topic:Unexpected behaviour with audit rules.
Current Time: Fri Apr 23 15:35:47 GMT 2021
Powered by FUDForum. Page generated in 0.02117 seconds
