Submit document failure using the OHF [message #516276] |
Tue, 23 February 2010 13:32 |
Raph Messages: 10 Registered: February 2010 |
Hi !
I'm trying to submit a document on a repository using OHF, but I have the following error :
org.eclipse.ohf.ihe.common.ws.OHFSOAPException: Error Sending SOAP Message [Caused by java.net.SocketException: Socket retries exhausted.]
at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeSend(AbstractOHFSOAPSender.java:253)
at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(AbstractOHFSOAPSender.java:363)
at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(AbstractOHFSOAPSender.java:384)
at org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(AbstractXDSSoapClient.java:148)
at org.eclipse.ohf.ihe.xds.source.B_Source.submit(B_Source.java:166)
at testohf.MyXDSManager.putDocument(MyXDSManager.java:104)
at testohf.Main.main(Main.java:28)
Caused by: java.net.SocketException: Socket retries exhausted.
at org.eclipse.ohf.ihe.atna.transport.TransporterImpl.createSocket(TransporterImpl.java:306)
at org.eclipse.ohf.ihe.atna.transport.TransporterImpl.getSocket(TransporterImpl.java:100)
at org.eclipse.ohf.ihe.atna.agent.AtnaAgent.getSocket(AtnaAgent.java:223)
at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.configureTransportProtocol(AbstractOHFSOAPSender.java:195)
at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeSend(AbstractOHFSOAPSender.java:228)
... 6 more
Here is my code :
// création de l'objet transaction qui servira par la suite
SubmitTransactionData txnData = new SubmitTransactionData();
// création du document CDA à partir de l'url du fichier
Document clinicalDocument = new Document(urlDocument, DocumentDescriptor.CDA_R2);
// ajout du document ainsi créé à la transaction
String docEntryUUID = txnData.addDocument(clinicalDocument);
// récupération d'une partie des metadonnées du document pour les compléter
DocumentEntryType docEntry = txnData.getDocumentEntry(docEntryUUID);
// ajout de métadonnées concernant l'identifiant du patient
CX patientId = Hl7v2Factory.eINSTANCE.createCX();
patientId.setIdNumber(patientIdNumber);
patientId.setAssigningAuthorityUniversalId("1.3.6.1.4.1.21367.2005.1.1");
patientId.setAssigningAuthorityUniversalIdType("ISO");
docEntry.setPatientId(patientId);
// récupération d'une autre partie des métadonnées du document pour les compléter
SubmissionSetType subset = txnData.getSubmissionSet();
CodedMetadataType contentTypeCode = MetadataFactory.eINSTANCE.createCodedMetadataType();
contentTypeCode.setCode("Consult");
// contentTypeCode.setDisplayName("Consult");
subset.setContentTypeCode(contentTypeCode);
// définition de l'url du repository dans lequel on va envoyer le document
URI repositoryUri = URI.create(repositoryUrl);
B_Source source = new B_Source(repositoryUri);
AtnaAgentFactory.getAtnaAgent().setAuditRepository(repositoryUri);
// définition du proxy
System.setProperty("http.proxySet", "true");
System.setProperty("http.proxyHost", proxyHost);
System.setProperty("http.proxyPort", proxyPort);
// identification de l'auteur de la requête
AtnaAgentFactory.getAtnaAgent().setInitiatingUser(putDocumentInitiatingUser);
// exécution de la requête pour envoyer le document vers le repository
XDSResponseType xdsresponsetype = source.submit(txnData);
System.out.println("xdsresponsetype : " + xdsresponsetype);
} catch (MetadataExtractionException ex) {
Logger.getLogger(Main.class.getName()).log(Level.SEVERE, null, ex);
} catch (SubmitTransactionCompositionException ex) {
} catch (FileNotFoundException ex) {
} catch (IOException ex) {
} catch (OHFSOAPException ex) {
Logger.getLogger(MyXDSManager.class.getName()).log(Level.SEVERE, null, ex);
} catch (Exception ex) {
Does someone know what I did wrong ?
Thanks for your help ...
FUDForum. Page generated in 0.03122 seconds
