Home » Modeling » TMF (Xtext) » Lookahead value of xtext grammar
Re: Lookahead value of xtext grammar [message #871495 is a reply to message #52382] |
Mon, 14 May 2012 08:47 |
Renaud Helias Messages: 4 Registered: May 2012 |
I am stress testing tmf xtext with a little large grammar.
I have to parse it with lookahead value 4 bceause lookahead =1 is not
enough for the nature of grammar.
How can I specify the lookaheadSSSSS valueSSSSS ?
I personnaly need a lookahead (options {k=1;}) value for each branch of grammar, instead of just root (changing it in mwe2 doesn't cover full grammar but just from root of it)
I don't find a way in order to do that.
stress used : C.g grammar from Terence Parr ( ANTLR=>grammar=>C Preprocessor )
C Hello Word failed on Xtext.
Fail example :
int toto = 45;//failed
int * toto = 45; //correct
Rules failing here :
declarator
: pointer? direct_declarator
| pointer
pointer
: '*' type_qualifier+ pointer?
| '*' pointer
Remark for using MyDsl.xtext (my file is attached) : you have one occurence of ")=>" on rule "external_declaration".
For this project, I am based on Xtext Hello Word project.
Remarks for forcing compilation, DO NOT INSERT MyDsl.xtext FILE INTO PROJECT WORKSPACE (Xtext Editor is too low for this large grammar), just modify GenerateMyDsl.mwe2 as it:
//var grammarURI = "classpath:/org/xtext/example/mydsl/MyDsl.xtext"
var grammarURI = "file:///C:\\Users\\freemac\\workspaceSDK\\MyDsl.xtext"
// it permits to edit text outside of Eclipse, without provocate "Xtext Validation" bug (lost of performance, and crash on my poor computer)
fragment = parser.antlr.XtextAntlrGeneratorFragment {
options = AntLrOptionsWithKAsString {
backtrack = true
memoize = true
kAsString = "3"
fragment = parser.antlr.XtextAntlrUiGeneratorFragment {
backtrack = true
memoize = true
kAsString = "3"
Time of compilation : a few more than 3 hours.
Need a fix after : "The code of method specialStateTransition(int, IntStream) is exceeding the 65535 bytes limit", on InternalMyDslParser.java that is a big file, it can be corrected manually by making a sub-function launch that contains cases switch range 0 to 400. It gives somethings like that :
// function to correct
public int specialStateTransition(int s, IntStream _input) throws NoViableAltException {
TokenStream input = (TokenStream)_input;
int _s = s;
if (s<326)
try {
return toto(s);
} catch (TotoException e) {
// continue
switch ( s ) {
case 400 :
//... end of current function by there.
//sub-function inserted
private int toto(int s) throws TotoException {
switch (s) {
case 0 :
//.. cases 0 to 399
break;
throw new TotoException();
InternalMyDslParser will be on both org.xtext.example.mydsl and org.xtext.example.mydsl.ui parts of Xtext Hello Word project.
My feels abouts this bug :
k parameter (for lookahead depth), used on mwe2 file, affects only root of grammar.
Note that I used there k=3 on mwe2, using maximum of k value that occurs on C.g
But fact is that sub sub sub rule of C.g don't seem reaching pointer rule.
My project : mamevhdl
Main project is generating main part of VHDL code from C++ code of Mame. Resulting arcade schematics with wires and bottom components (each components empty but with Mame names, helping to normalize of arcade VHDL projects)
I am really new on Xtext and ANTLR.
A frenchy boy,
Renaud Helias
Attachment: C.g
(Size: 10.91KB, Downloaded 179 times) -
Attachment: MyDsl.xtext
(Size: 11.63KB, Downloaded 190 times) -
Attachment: hello_c.jpg
(Size: 20.06KB, Downloaded 1363 times)
Re: Lookahead value of xtext grammar [message #871968 is a reply to message #871495] |
Tue, 15 May 2012 08:22 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Renaud,
please double check whether it's really necessary to explicitly pass the
lookahead? Antlr will usually figure that out automagically. Regarding
the bytecode limit you may want to explore the the classSplitting option
in the Antlr options.
Sebastian
Am 14.05.12 10:47, schrieb Renaud Helias:
> Fail example :
> declarator
> | pointer
> pointer
> | '*' pointer
> backtrack = true
> memoize = true
> kAsString = "3"
> backtrack = true
> memoize = true
> kAsString = "3"
> int _s = s;
> if (s<326)
> try {
> return toto(s);
> // continue
> switch ( s ) {
> case 400 :
> switch (s) {
> case 0 :
> //.. cases 0 to 399
> break;
> A frenchy boy,
> Renaud Helias
Re: Lookahead value of xtext grammar [message #873262 is a reply to message #871968] |
Thu, 17 May 2012 20:33 |
Hi Sebastian,
It seems that there is no magic backtrack/LL(*) occurring in this sorcerer backtrack/LL(k) case.
k and backtrack are used directly on branches for prototyping a grammar (for example coming from a BNF), I think C.g is an evil case for its ANTLR algorithm test.
I thinked that k was only used for performance... damn.
I have done an other test : I compare use of parameters between C.g and my MyDsl.g (the same playing with backtrack/memoize options only at top, and without using k)
If my input file hello.c is :
/* Hello World program */
#include<stdio.h>
int * r=4;
* main()
printf("Hello World");
My log output is :
Test de C.g
Test de MyDsl.g backtrack=true memoize=false
Test de MyDsl.g backtrack=true memoize=true
Test de MyDsl.g backtrack=true memoize=false et syntactic predicates
And then if my input file hello.c is :
#include<stdio.h>
int r=4;
main()
My log output is :
Test de C.g
hello.c line 4:9 mismatched input '=' expecting ';'
hello.c line 5:9 no viable alternative at input ')'
hello.c line 6:4 mismatched input '{' expecting ';'
hello.c line 7:11 no viable alternative at input '"Hello World"'
Here attached this basic java project source code (not Xtext)
A frenchy boy,
Renaud
[Updated on: Thu, 17 May 2012 20:45] Report message to a moderator
Re: Lookahead value of xtext grammar [message #873962 is a reply to message #873262] |
Sat, 19 May 2012 15:54 |
Hi Sebastian,
I founded a semantic predicate on C.g, k parameter didn't affect here (k no sense here). I read somewhere that semantic predicate are not implemented on Xtext.
It is ok for me, to compare Xtext/model and ANTLR/semantic-predicates is like comparing DOM and SAX
I think that LL(*) just cover LL(k), with or without using backtrack.
memoize parameter is just a optimisation parameter that didn't have any border effect.
Problem here came just from a special case where ANTLR crap itself :
a : b c?;
b : ('toto'|IDENTIFIER)+;
c : IDENTIFIER | IDENTIFIER '=';
Thanks a lot for your help,
Renaud
Attachment: toto_points_p_eq.png
(Size: 16.13KB, Downloaded 1342 times) -
Attachment: hello_c_ok.png
(Size: 16.55KB, Downloaded 1373 times) -
Attachment: MyDsl.g
(Size: 11.40KB, Downloaded 235 times) -
Attachment: C.g
(Size: 10.91KB, Downloaded 140 times) -
(Size: 11.77KB, Downloaded 267 times)
[Updated on: Sat, 19 May 2012 16:54] Report message to a moderator
Current Time: Thu Apr 25 20:33:42 GMT 2024
Powered by FUDForum. Page generated in 0.03314 seconds
