Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Lockable Composite
icon5.gif  Lockable Composite [message #515130] Wed, 17 February 2010 20:05 Go to next message
Andre Kullmann is currently offline Andre KullmannFriend
Member
I'm searching for something simular to swing labs lockable panel from swt.
see https://jxlayer.dev.java.net/webstart/LockableDemo.jnlp
I want to lock an Composite/View and paint and busy animation until the loading is finished.
Does someone known where I can find something like this ?
Thanx,
André
Re: Lockable Composite [message #515194 is a reply to message #515130] Thu, 18 February 2010 05:46 Go to previous messageGo to next message
Vijay RajFriend
I think you have create a custom built composite with stacklayout...
The top control being the main composite with controls and bottom composite with animation...
so that when you want to show a busy screen you will bring the busy screen control on the top...
bit tricky but very usefull...
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
Re: Lockable Composite [message #524646 is a reply to message #515194] Thu, 01 April 2010 16:36 Go to previous message
Member
thanks for the hint !!
I created lockable composite under https://mirror.dev.java.net
Here's the source
https://mirror.dev.java.net/source/browse/mirror/trunk/net.j ava.mirror.ercp/src/net/java/mirror/ercp/LockableComposite.j ava?rev=16&view=log
André
Previous Topic:Where I can download SWT?
Next Topic:New to eclipse and SWT
Current Time: Thu Feb 20 11:10:53 GMT 2020
Powered by FUDForum. Page generated in 0.03591 seconds
