Home » Archived » Buckminster » Problem build an aggregated site headless
Problem build an aggregated site headless [message #515060] Wed, 17 February 2010 15:36 Go to next message
John is currently offline JohnFriend
Hi!
I have the following Agggregator model:
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:aggregator="http://www.eclipse.org/buckminster/2009/aggregator" description="The aggregated update site for NBD" label="NBD" buildRoot="/temp/bmaggregator/build">
<configurations/>
<contributions label="NBD">
<repositories location="http://mysiteserver/core-site/dev" mirrorArtifacts="false" categoryPrefix="C">
<metadataRepository href="p2:http://mysiteserver/core-site/dev#//@metadataRepository"/>
</repositories>
<repositories location="http://mysiteserver/psd-site/dev" mirrorArtifacts="false" categoryPrefix="P">
<metadataRepository href="p2:http://mysiteserver/psd-site/dev#//@metadataRepository"/>
</repositories>
<repositories location="http://mysiteserver/psd-ncl-site/dev" mirrorArtifacts="false" categoryPrefix="PN">
<metadataRepository href=" p2:http://mysiteserver/psd-ncl-site/dev#//@metadataRepositor y"/>
</repositories>
</contributions>
<validationRepositories location="file:///C:/ccviews/psd_dev_1_2_30/NTP_NCD/src/RCP/RCP-RUN">
<metadataRepository href=" p2:file:///C:/ccviews/psd_dev_1_2_30/NTP_NCD/src/RCP/RCP-RUN #//@metadataRepository"/>
</validationRepositories>
<validationRepositories location="file:///C:/Temp/aggr/galileo-site/mirror/final">
<metadataRepository href=" p2:file:///C:/Temp/aggr/galileo-site/mirror/final#//@metadat aRepository"/>
</aggregator:Aggregator>
This model builds fine in my Eclipse IDE.
When trying to build it using headless Buckminster I get the error below.
Any hints on why this fails?
I downloaded a new Buckminster 35. yesterday and have the following Aggregator jar files:
org.eclipse.buckminster.aggregator.engine.maven_1.0.0.r11191 .jar
org.eclipse.buckminster.aggregator.engine_1.0.0.r11068.jar
org.eclipse.buckminster.aggregator_1.0.0.r11090.jar
Thanks in advance.
/John.
INFO: aggregate '--buildModel' 'assemble-aggregated-site.build' '--action' 'CLEAN_BUILD' '--buildRoot' '/temp/nbd/aggregate-site/aggregate-site-root'
ERROR: Build failed! Exception was java.lang.NullPointerException:
at org.eclipse.buckminster.aggregator.engine.Builder.verifyCont ributions(Builder.java:1264)
at org.eclipse.buckminster.aggregator.engine.Builder.run(Builde r.java:634)
at org.eclipse.buckminster.aggregator.engine.Builder.run(Builde r.java:1059)
at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: Problem build an aggregated site headless [message #515079 is a reply to message #515060] Wed, 17 February 2010 16:28 Go to previous messageGo to next message
Okay!
I peeked in the code at org.eclipse.buckminster.aggregator.engine.Builder.verifyCont ributions(Builder.java:1264). It seems like there may be a problem related to the path specified for the model file. This shouldn't of course give an NPE, but I may be able to continue.
So I tried to add a ./ in front of the file and got a new error as shown below. Now it doesn't like my target platform as a site. This, again, works fine in the Eclipse IDE?
What is the problem here?
Thanks.
/John.
INFO: aggregate '--buildModel' './assemble-aggregated-site.build' '--action' 'CLEAN_BUILD' '--buildRoot' '/temp/nbd/aggregate-site/aggregate-site-root'
ERROR: Unable to load repository file:///C:/ccviews/psd_dev_1_2_30/NTP_NCD/src/RCP/RCP-RUN
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: No repository found at file:///C:/ccviews/psd_dev_1_2_30/NTP_NCD/src/RCP/RCP-RUN.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.fail(AbstractRepositoryManager.java:380)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:641)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
at org.eclipse.buckminster.aggregator.p2.util.P2RepositoryLoade r.load(P2RepositoryLoader.java:132)
at org.eclipse.buckminster.aggregator.p2.util.P2RepositoryLoade r.load(P2RepositoryLoader.java:78)
at org.eclipse.buckminster.aggregator.p2.util.MetadataRepositor yResourceImpl$RepositoryLoaderJob.run(MetadataRepositoryReso urceImpl.java:233)
ERROR: The feature 'metadataRepository' of 'org.eclipse.buckminster.aggregator.impl.MetadataRepositoryR eferenceImpl @e1eae7 {file:/C:/ccviews/psd_build_main_latest/NTP_NCD/build/script /./assemble-aggregated-site.build#//@validationRepositories. 0}' contains an unresolved proxy ' org.eclipse.buckminster.aggregator.p2.impl.MetadataRepositor yImpl@523be{p2:file:///C:/ccviews/psd_dev_1_2_30/NTP_NCD/src /RCP/RCP-RUN#//@metadataRepository}'
ERROR: Build failed! Exception was org.eclipse.core.runtime.CoreException: Build model validation failed: Diagnosis of org.eclipse.buckminster.aggregator.impl.AggregatorImpl@96b5c2 {file:/C:/ccviews/psd_build_main_latest/NTP_NCD/build/script /./assemble-aggregated-site.build#/}
at org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:64)
at org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:59)
at org.eclipse.buckminster.aggregator.engine.Builder.runTransfo rmation(Builder.java:1241)
at org.eclipse.buckminster.aggregator.engine.Builder.run(Builde r.java:635)
Re: Problem build an aggregated site headless [message #515087 is a reply to message #515079] Wed, 17 February 2010 16:45 Go to previous messageGo to next message
Filip Hrbek is currently offline Filip HrbekFriend
Could you please enter both issues in the bugzilla? I'll try to fix them ASAP.
Filip
John napsal(a):
> Okay!
> Thanks.
> /John.
> repository found at
> urceImpl.java:233)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> mailto: 'org.eclipse.buckminster.aggregator.impl.MetadataRepositoryR eferenceImpl @e1eae7
> Diagnosis of
> mailto:org.eclipse.buckminster.aggregator.impl.AggregatorImpl@96b5c2
> Diagnosis of
> r.java:635)
> r.java:1059)
> :189)
> tarter.java:368)
> tarter.java:179)
> 559)
Re: Problem build an aggregated site headless [message #515254 is a reply to message #515079] Thu, 18 February 2010 04:56 Go to previous messageGo to next message
John napsal(a):
> Okay!
What does your TP folder contain? If there is no metadata file (content.xml or content.jar) present, it cannot be loaded as a repository, neither from IDE or from headless. Or am I missing something?
Filip
Re: Problem build an aggregated site headless [message #515292 is a reply to message #515254] Thu, 18 February 2010 11:17 Go to previous messageGo to next message
Hi Filip!
My TP folder dosen't conatin any metadata. It's just organized like an Eclipse installation with features and plugins folders.
I wondered if it would be usable as a validation repository, but as I have experienced it actually works in the Eclipse IDE. I can resolve it and the aggregated site can be build and used with a Buckminster headless build.
It only fails when I build it headless.
/John
Re: Problem build an aggregated site headless [message #515294 is a reply to message #515087] Thu, 18 February 2010 11:26 Go to previous messageGo to next message
The NPE is here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303165
Re: Problem build an aggregated site headless [message #515311 is a reply to message #515087] Thu, 18 February 2010 13:13 Go to previous messageGo to next message
The load problem is reported here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303176
Re: Problem build an aggregated site headless [message #515352 is a reply to message #515292] Thu, 18 February 2010 14:50 Go to previous messageGo to next message
If I remove the TP as a validation repository I can also build headless.
However, if I set the buildRoot to a relative path I get an error.
The documentation doesn't state that it should be an absolute path and I'd prefer if it doesn't have to be. In all other Buckminster commands I use, I can use relative paths.
Is it reasonable to enter a bug?
/John
ERROR: Build failed! Exception was org.eclipse.core.runtime.CoreException: File .\temp\nbd\aggregate-site\aggregate-site-root\final is not an absolute path
at org.eclipse.buckminster.aggregator.engine.Builder.createURI( Builder.java:241)
at org.eclipse.buckminster.aggregator.engine.Builder.deleteMeta dataRepository(Builder.java:275)
at org.eclipse.buckminster.aggregator.engine.Builder.cleanMetad ata(Builder.java:1094)
at org.eclipse.buckminster.aggregator.engine.Builder.cleanAll(B uilder.java:1064)
at org.eclipse.buckminster.aggregator.engine.Builder.run(Builde r.java:640)
Re: Problem build an aggregated site headless [message #517876 is a reply to message #515352] Tue, 02 March 2010 12:13 Go to previous message
Logged as https://bugs.eclipse.org/bugs/show_bug.cgi?id=304341
> /John
> Builder.java:241)
> uilder.java:1064)
> r.java:640)
> r.java:1059)
> :189)
> tarter.java:368)
> tarter.java:179)
> 559)
Previous Topic:installJRE and IBM j9
Next Topic:Target Platform and buckminster-headless: update, multiple with same name, rmtarget
Current Time: Tue Sep 28 21:00:11 GMT 2021
Powered by FUDForum. Page generated in 0.03256 seconds
