Home » Eclipse Projects » Standard Widget Toolkit (SWT) » NullPointerException printing on mac
icon5.gif  NullPointerException printing on mac [message #514824] Tue, 16 February 2010 18:17 Go to next message
Paul Wells is currently offline Paul WellsFriend
If I run the below code on Mac OS X 10.6.2 then creation of the GC causes a NullPointerException to be thrown. If I run the same code on Windows 7 it is fine.
In both cases I'm building/running with
org.eclipse.swt_3.5.1.v3555a.jar
then the platform dependent jar of the same version.
org.eclipse.swt.cocoa.macosx.x86_64_3.5.1.v3555a.jar
in the case of the mac.
Thanks in advance for any help with getting printing working on the mac.
Paul
package com.test.printer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.printing.PrintDialog;
import org.eclipse.swt.printing.Printer;
import org.eclipse.swt.printing.PrinterData;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
public class PrinterTest
public static void main(String[] arguments)
final Display display = new Display();
final Shell shell = new Shell(display);
final Button printButton = new Button(shell, SWT.PUSH);
printButton.setText("print");
printButton.pack();
printButton.setLocation(10, 68);
printButton.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
final PrintDialog dialog = new PrintDialog(shell);
final PrinterData printerData = dialog.open();
if (printerData == null)
return;
final Printer printer = new Printer(printerData);
try
new GC(printer);
System.out.println("GC created");
catch (NullPointerException exception)
System.out.println("NPE while constructing GC");
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: NullPointerException printing on mac [message #515071 is a reply to message #514824] Wed, 17 February 2010 16:07 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
Hi Paul,
You're seeing an swt bug that is fixed [1] in the 3.6 stream. I don't think
there's a way to make this case work with your current swt jar, so you can
either use a 3.6-stream milestone release such as
http://download.eclipse.org/eclipse/downloads/drops/S-3.6M5- 201001291300/index.php ,
or if this is not possible, use the 3.5.1 carbon-based swt instead since it
does not show this problem. (If attempting to run the carbon port on 64-bit
OS X take note of http://www.eclipse.org/swt/faq.php#cocoa32launch ).
[1] The NPE is fixed at least, though there are now many warnings written to
stderr. I've logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=303074
for this.
Grant
"Paul Wells" <paul.wells@agilej.com> wrote in message
news:hlenf8$dgj$1@build.eclipse.org...
is fine.
> Paul
> import org.eclipse.swt.widgets.Display;
> printButton.pack();
> @Override
> return;
> try
> new GC(printer);
> shell.open();
> display.sleep();
> display.dispose();
Re: NullPointerException printing on mac [message #515148 is a reply to message #515071] Wed, 17 February 2010 21:43 Go to previous message
Grant,
Thanks for confirming that this is a known issue and that it is being fixed.
I cannot run my application on 3.6, there are other dependency issues thrown up as I try to install, so I cannot confirm that it is resolved.
Thanks again for your help
Paul
Previous Topic:VerifyListener, statemask
Next Topic:SWT Toggle Button mousehover
Current Time: Tue Apr 16 08:53:52 GMT 2024
Powered by FUDForum. Page generated in 0.05791 seconds
