Re: Build Eclipse RCP Application using Apache Ant scripts? [message #514754 is a reply to message #514714] |
Tue, 16 February 2010 14:41 |
Hello
1. I am using an ant script to build my rcp application. Beside the PDE build I am doing some additional steps. The advantage is that I can start the build outside the Eclipse IDE using a batch/bash script.
2. As a starting point you can try this link: http://rcpquickstart.com/2007/06/06/getting-started-with-pde -build/. Or you can try http://www.pluginbuilder.org/.
3. It is a bit frustrating in the beginning because you will probably get some cryptic error messages (especially related to PDE build) but after some practice you will get it right.
4. I do not know any tool that will automatically generate the ant scripts (although in my opinion the product export wizard should do this beside the actual export).
5. Do a search on "eclipse headless build" and you will get additional info.
Time is what you make of it.
FUDForum. Page generated in 0.02990 seconds
