Internal Error when creating method/class with Quick Fix [message #514689] |
Tue, 16 February 2010 06:08  |
I have been experiencing errors when I create a method or class with the Quick Fix (I type a method which does not exist, and the Quick Fix creates one for me). Usually Eclipse jumps to the newly created method or class, but lately I am getting internal eclipse errors, and it doesn't jump where it should.
I am using Eclipse IDE for Java EE Developers 3.5
StackTrace:
org.eclipse.core.runtime.CoreException: First position: 'lastErrorCounter' at 28220, this position: '' at 5000
at org.eclipse.jdt.internal.ui.text.correction.proposals.CUCorrectionProposal.performChange(CUCorrectionProposal.java:343)
at org.eclipse.jdt.internal.ui.text.correction.proposals.CUCorrectionProposal.apply(CUCorrectionProposal.java:301)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup.insertProposal(CompletionProposalPopup.java:931)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup.insertSelectedProposalWithMask(CompletionProposalPopup.java:877)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup.access$27(CompletionProposalPopup.java:873)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup$5.widgetDefaultSelected(CompletionProposalPopup.java:655)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:113)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
Caused by: org.eclipse.jface.text.BadLocationException: First position: 'lastErrorCounter' at 28220, this position: '' at 5000
at org.eclipse.jface.text.link.LinkedPositionGroup.enforceEqualContent(LinkedPositionGroup.java:132)
at org.eclipse.jface.text.link.LinkedPositionGroup.addPosition(LinkedPositionGroup.java:113)
at org.eclipse.jdt.internal.ui.viewsupport.LinkedProposalModelPresenter.enterLinkedMode(LinkedProposalModelPresenter.java:82)
at org.eclipse.jdt.internal.ui.text.correction.proposals.CUCorrectionProposal.performChange(CUCorrectionProposal.java:332)
... 30 more
Session Data:
Quote: | eclipse.buildId=M20090917-0800
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product -data N:
Anyone know what is wrong? Is it a bug in JDT?
[Updated on: Tue, 16 February 2010 06:13] by Moderator
Re: Internal Error when creating method/class with Quick Fix [message #514705 is a reply to message #514689] |
Tue, 16 February 2010 07:01   |
Mads Stavang wrote:
> Hello,
That's a bug which got recently fixed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195834
Dani
> StackTrace:
> at
> org.eclipse.jdt.internal.ui.text.correction.proposals.CUCorr ectionProposal.performChange(CUCorrectionProposal.java:343)
> at
> org.eclipse.jdt.internal.ui.text.correction.proposals.CUCorr ectionProposal.apply(CUCorrectionProposal.java:301)
> at
> org.eclipse.jface.text.contentassist.CompletionProposalPopup .insertProposal(CompletionProposalPopup.java:931)
> at
> org.eclipse.jface.text.contentassist.CompletionProposalPopup .insertSelectedProposalWithMask(CompletionProposalPopup.java :877)
> at
> org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$27(CompletionProposalPopup.java:873)
> at
> org.eclipse.jface.text.contentassist.CompletionProposalPopup $5.widgetDefaultSelected(CompletionProposalPopup.java:655)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:113)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at
> org.eclipse.jface.text.link.LinkedPositionGroup.enforceEqual Content(LinkedPositionGroup.java:132)
> at
> org.eclipse.jface.text.link.LinkedPositionGroup.addPosition( LinkedPositionGroup.java:113)
> at
> org.eclipse.jdt.internal.ui.viewsupport.LinkedProposalModelP resenter.enterLinkedMode(LinkedProposalModelPresenter.java:8 2)
> at
> org.eclipse.jdt.internal.ui.text.correction.proposals.CUCorr ectionProposal.performChange(CUCorrectionProposal.java:332)
> .. 30 more
> Session Data:
> Quote:
FUDForum. Page generated in 0.02746 seconds
