Headless import fails [message #514440] |
Mon, 15 February 2010 11:04  |
I have an RMAP as follows:
<searchPath name="default">
<provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature,buckminster" source="true" mutable="true">
<uri format=":pserver:gjmcknight:mypass@cvs.local:/opt/data/cvsroot,{0}/"><bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<locator searchPathRef="default" />
This works using Eclipse ("resolve and materialize"), but with the Headless (I installed the core and CVS features from the 3.5 update site), I get the following error when running the headless "import" command:
Unable to find a searchPath for org.eclipse.core.runtime.compatibility.auth:osgi.bundle
Is there something missing from my headless install?
Do I need to explicitly provide links to these components (i.e components outside of my project (such as org.eclipse, javax.servlet etc)???
Thanks a lot!
Greg
Re: Headless import fails [message #514462 is a reply to message #514440] |
Mon, 15 February 2010 08:20   |
Hi Greg,
You have not setup a target platform so the build runtime (the headless buckminster in this case) is used as the default
target platform. This is not ideal since whatever your build becomes dependent on the version of your build tool.
I would recommend that you set up an empty target platform in the form of a directory and that you add an entry to your
rmap that uses an 'eclipse.import' reader type that will allow buckminster to resolve target platform components against
a platform p2 repository such as http://download.eclipse.org/eclipse/updates/3.5/
You will also need to use an mspec to tell buckminster that whatever is resolved using this reader type should
materialize to the target platform (as opposed to the workspace). Something like this:
<mspec:mspec xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0" materializer="p2" name="mspec"
url="build.cquery">
<mspec:mspecNode materializer="workspace" namePattern="" filter="(buckminster.source=true)"/>
</mspec:mspec>
assuming that it is stored in the same directory as the 'build.cquery'.
The steps are (in this order).
1. Create an empty target platform. Can be done using buckminster setpref targetPlatformPath=<directory> or using a
target platform descriptor (.target file). Make sure the target is active.
2. Import the mspec using the Buckminster 'import' command.
3. Build.
HTH,
Thomas Hallgren
> mutable="true">
> <uri
> format=":pserver:gjmcknight:mailto:mypass@cvs.local:/opt/data/cvsroot,{0}/"><bc:propertyRef
> </uri>
> </provider>
> </searchPath>
> command:
> etc)???
> Thanks a lot!
> Greg
Re: Headless import fails [message #514481 is a reply to message #514462] |
Mon, 15 February 2010 14:31   |
Hi Thomas
I have installed the target platform as follows:
C:\fast>..\bin\bmh\buckminster importtargetdefinition -A C:/mysrc/example-app/
example-main-site/rcp.target
Lsttargets gives this:
C:\fast>..\bin\bmh\buckminster lstargets
Using workspace at file:/C:/fast/workspace/ ...
* Eclipse RCP : win32,win32,x86/de_CH
Running Platform : win32,win32,x86/de_CH
All good so far...
I created the MSPEC as you propsed, I only changed the build.cquery to site.query (that is the filename of my CSPEC).
They exist in the same directory.
I added the following to my RMAP:
<searchPath name="galileo">
<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature"
mutable="false" source="false">
<uri format=" http://download.eclipse.org/releases/galileo?importType=bina ry"/>
</provider>
</searchPath>
<locator searchPathRef="default" pattern="^calorifer\-.*" />
<locator searchPathRef="galileo" failOnError="false" />
Now I try to import:
C:\fast>..\bin\bmh\buckminster -L DEBUG import C:/mysrc/example-app/example-main-site/site.mspec
But I receive the same errors as before:
Note: I have this in my log file:
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-15 15:15:15.723
!MESSAGE Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
Is the right target platform being used?
Here is my RMAP
<rmap
xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
<provider
readerType="cvs"
source="true"
mutable="true">
</uri>
</provider>
</searchPath>
</provider>
</searchPath>
</rmap>
Here is my MSPEC:
<mspec:mspec xmlns:mspec="http://www.eclipse.org/buckminster/MetaData-1.0" materializer="p2" name="mspec" url="site.cquery">
</mspec:mspec>
Also, I am interested why can I materialize within eclipse without the MSPEC? Is there a default MSPEC in the eclipse plug-in?
SORRY WORK IN PROGRESS...WILL POST MY PROGRESS IN A LITTLE WHILE
Greg
[Updated on: Mon, 15 February 2010 15:01] by Moderator Report message to a moderator
Re: Headless import fails [message #514498 is a reply to message #514481] |
Mon, 15 February 2010 15:15   |
Hi Greg,
Judging from your RMAP you forgot one of the things I suggested:
"add an entry to your rmap that uses an 'eclipse.import' reader type that will allow buckminster to resolve target
platform components against a platform p2 repository such as http://download.eclipse.org/eclipse/updates/3.5/"
Thomas Hallgren
On 02/15/2010 03:31 PM, gjmcknight@schlagundrahm.ch wrote:
> Hi Thomas
> All good so far...
> !ENTRY org.eclipse.buckminster.core 4 293 2010-02-15 15:15:22.228
> !MESSAGE ERROR [0000] : No suitable provider for component
> javax.servlet:osgi.bundle was found in resourceMap
> file:/C:/fast/workspace/calorifer-main-site/site.rmap
> ERROR [0000] : Unable to find a searchPath for javax.servlet:osgi.bundle
> Here is my RMAP
> <rmap
> <provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature"
> <uri
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="default" pattern="^example\-.*" />
> </rmap>
> Here is my MSPEC:
> <mspec:mspec
> </mspec:mspec>
> Any ideas?
> Thanks
> Greg
Re: Headless import fails [message #514510 is a reply to message #514481] |
Mon, 15 February 2010 16:24   |
There is a default MSPEC but it's the same regardless of if you run headless or not.
The reason it fails when running headless and succeeds in the IDE is that you are using the tool itself as the target
platform. So in one case your headless Buckminster runtime is the target platform and in the other case it's your
Eclipse IDE. The IDE installation contains the bundle in question. The headless Buckminster doesn't.
Thomas Hallgren
Re: Headless import fails [message #514520 is a reply to message #514510] |
Mon, 15 February 2010 16:48   |
Thanks so much for your quick help Thomas.
I've got it materializing!
Now I've got this error:
ERROR [0004] : Unable to determine target platform install location
ERROR: Unable to determine target platform install location
ERROR: Errors and Warnings
I'll see how I go from here.
Thanks again.
Re: Headless import fails [message #514526 is a reply to message #514520] |
Mon, 15 February 2010 16:50   |
Hi Greg,
The error indicates that the active target platform does not have exactly one directory so Buckminster cannot determine
where to put things.
HTH,
- thomas
> Thanks again.
Re: Headless import fails [message #514560 is a reply to message #514540] |
Mon, 15 February 2010 18:58   |
On 02/15/2010 06:38 PM, gjmcknight@schlagundrahm.ch wrote:
> The directory "workspace" has "features" and "plugins" directories after
> materialization.
That sounds OK.
> Hasn't Buckminster already materialized everything? It seems so, all my
> source is there...
Probably. Your ... suggests that something is wrong?
- thomas
Re: Headless import fails [message #514641 is a reply to message #514560] |
Tue, 16 February 2010 08:24   |
Hi Thomas
I still have the error:
I have a "workspace" directory which has "features" and "plugins".
What is buckminster trying to do now?
Thanks again
Greg
Re: Headless import fails [message #514650 is a reply to message #514641] |
Tue, 16 February 2010 04:02   |
On 02/16/2010 09:24 AM, gjmcknight@schlagundrahm.ch wrote:
> Hi Thomas
Buckminster is trying to find a target platform that it can use and fails.
What target platform is active when this happens?
Does this target platform have exactly one directory?
- thomas
Re: Headless import fails [message #514667 is a reply to message #514650] |
Tue, 16 February 2010 09:46   |
OK, here is the log (from workspace/.metadata/.log)
!SESSION 2010-02-16 10:15:37.662 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Framework arguments: -L DEBUG import C:/mysrc/example-app/example-main-site/site.mspec
Command-line arguments: -L DEBUG import C:/mysrc/example-app/example-main-site/site.mspec
!ENTRY org.eclipse.buckminster.runtime 0 293 2010-02-16 10:15:39.968
!MESSAGE import 'C:/mysrc/example-app/example-main-site/site.mspec'
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:15:41.283
!MESSAGE Platform install location: C:\bin\bmh
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:15:41.760
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:15:58.064
!MESSAGE Provider cvs(:pserver:gjmcknight:mypass@cvs.local:/opt/data/cvsroot,example-main-site/): materializing to C:/fast/workspace/features/example-main-site/
!ENTRY org.eclipse.buckminster.core 4 293 2010-02-16 10:15:58.248
!MESSAGE ERROR [0004] : Unable to determine target platform install location
!ENTRY org.eclipse.buckminster.runtime 4 0 2010-02-16 10:15:58.251
!MESSAGE Unable to determine target platform install location
!ENTRY org.eclipse.buckminster.core 4 293 2010-02-16 10:15:59.856
!MESSAGE Errors and Warnings
!STACK 1
org.eclipse.core.runtime.CoreException: Errors and Warnings
at org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
at org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:175)
at org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
Contains: [0004] : Unable to determine target platform install location
!SUBENTRY 1 org.eclipse.buckminster.core 4 0 2010-02-16 10:15:59.858
!SUBENTRY 2 org.eclipse.buckminster.runtime 4 0 2010-02-16 10:15:59.858
!MESSAGE [0004] : Unable to determine target platform install location
!ENTRY org.eclipse.buckminster.core 1 293 2010-02-16 10:15:59.862
!MESSAGE TAG-ID 0004 = Query for example-main-site:eclipse.feature, path: example-main-site:eclipse.feature$1.0.0.qualifier -> example-main-feature:eclipse.feature$1.0.0.qualifier -> example-main:osgi.bundle$1.0.0.qualifier
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:16:02.865
!MESSAGE Doing full workspace refresh
!ENTRY org.eclipse.buckminster.core 0 293 2010-02-16 10:16:02.868
!MESSAGE Waiting for jobs to end
As you can see, I have cut the resolution stuff out of the middle of the log.
Here is the active target:
And here is the commands I have run:
C:\fast>..\bin\bmh\buckminster importtargetdefinition -A C:/mysrc/example-app/example-main-site/rcp.target
The workspace directory has two sub-directories, "features" and "plugins" after the import.
Re: Headless import fails [message #514683 is a reply to message #514667] |
Tue, 16 February 2010 05:42   |
What does the rcp.target file look like?
- thomas
Re: Headless import fails [message #514691 is a reply to message #514683] |
Tue, 16 February 2010 11:14   |
rcp.target
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.5"?>
<target name="Eclipse RCP">
<locations>
<location includeAllPlatforms="true" includeMode="slicer" type="InstallableUnit">
<unit id="org.eclipse.equinox.executable.feature.group" version="3.3.200.R35x_v20090724-7M-FneFF9aMTyz0pw04ONXn"/>
<unit id="org.eclipse.rcp.sdk.id" version="3.5.1.M20090917-0800"/>
<repository location="http://download.eclipse.org/releases/galileo"/>
</location>
</locations>
</target>
Actually, when I ran "lsprefs", the targetDefinition was undefined.
So I then set the targetDefinition using setprefs "targetDefinition=Eclipse RCP".
Then I looked at "lsprefs" and the target definition was properly set. It seems that the "-A" flag used in "importdefinition" might not be persisting...(i.e Should the -A flag should do the same thing as setprefs targetDefiniton?)
I have now re-run the import, but now I end up without any of plug-ins and features materialized. Just a .metadata directory.
lsprefs gives:
org.eclipse.buckminster.pde.targetDefinition
Description: Sets the active Target Platform Definition
Value : Eclipse RCP
org.eclipse.buckminster.pde.targetNL
Description: Sets the locale of the currently active target platform
(no value set)
org.eclipse.buckminster.pde.targetOS
Description: Sets the operating system on the currently active target platform
(no value set)
org.eclipse.buckminster.pde.targetPlatformPath
Description: Set the active Target Platform to a definition that appoints a path
Value : C:\fast\workspace\.metadata\.plugins\org.eclipse.pde.core\.b undle_pool
org.eclipse.buckminster.pde.targetWS
Description: Sets the window system on the currently active target platform
(no value set)
Re: Headless import fails [message #514770 is a reply to message #514691] |
Tue, 16 February 2010 15:21   |
This target definition does not look like it contains a directory location. As I said earlier, Buckminster cannot
determine where to put things. You need to add a directory location to your target platform.
- thomas
On 02/16/2010 12:14 PM, gjmcknight@schlagundrahm.ch wrote:
> rcp.target
> <locations>
> </location>
> </locations>
> </target>
> lsprefs gives:
> Value : Eclipse RCP
> (no value set)
> platform
> (no value set)
> appoints a path
> undle_pool
> (no value set)
FUDForum. Page generated in 0.05493 seconds
