Home » Eclipse Projects » JFace » model/TreeView synchronization problem.
model/TreeView synchronization problem. [message #514348] |
Sun, 14 February 2010 21:07 |
Mauro Condarelli Messages: 428 Registered: September 2009 |
I have a TreeView that is the main selection provider for one page:
tree = toolkit.createTree(composite_2, SWT.BORDER);
toolkit.paintBordersFor(tree);
tree.setHeaderVisible(true);
tree.setLinesVisible(true);
tViewer = new TreeViewer(tree);
page.getEditorSite().setSelectionProvider(tViewer);
I have a context menu attached to the TreeView which has provisions to
add new nodes to the Model.
The context is dynamically created and, in the end fires the handler of
a Command. The handler for one particular addition (Add Scene) is like this:
public class AddScene extends AbstractHandler {
static final String ID = "it.condarelli.wbtest.commands.AddScene";
public Object execute(ExecutionEvent event) throws ExecutionException {
ISelection is = HandlerUtil.getCurrentSelection(event);
if (is instanceof IStructuredSelection) {
IStructuredSelection iss = (IStructuredSelection) is;
Object o = iss.getFirstElement();
if (o instanceof Chapter) {
Chapter _c = (Chapter) o;
Scene sc = ModelFactory.eINSTANCE.createScene();
_c.getScene().add(0, sc);
System.out.println("AddScene: added new Scene at start
of Chapter '" + _c.getTitle()+"'");
} else if (o instanceof Scene) {
Scene _s = (Scene) o;
Chapter _c = _s.getChapter();
int i = _c.getScene().indexOf(_s);
_c.getScene().add(i+1, sc);
System.out.println("AddScene: added new Scene in
Chapter '" + _c.getTitle()+"' after Scene '"+_s.getTitle()+"'" );
} else
System.err.println("AddScene bad selection: " + is);
return null;
Up to here everything is Ok. There is a nice separation between the UI
and the Model, but now problems start:
1) the TreeView does not fully reflect the changes in the model; if I
add a Scene after another Scene (else if (o instanceof Scene) {...)
everything is ok, but if I add a Scene in an empty Chapter (if (o
instanceof Chapter) {...) the addition is *not* reflected by UI: I need
to reload the application (or otherwise reinitialize the TreeViewer to
see the newly created Scene.
2) I would like to automatically select the new Scene, but I simply do
not know how to do that at this point in the code.
I am aware of several documents explaining how to synchronize <ui with
Model (e.g.:
http://www.eclipse.org/articles/Article-TreeViewer/TreeViewe rArticle.htm),
but they all seem to require knowledge of the visual component (tViewer,
in this case).
I can think of several ways to let the Handler to get hold of tViewer,
but I strngly suspect there should be a better way than to pollute the
whole code with cross-knowledge between Model and UI.
Ideally I would like to be able to extract information about the Widget
(tViewer) from the Selection I get from the Selection Service, but I
didn't find a way to do that.
Can someone point me in the right direction, please?
Thanks in Advance
Mauro
Re: model/TreeView synchronization problem. [message #514413 is a reply to message #514348] |
Mon, 15 February 2010 09:11 |
Mauro Condarelli wrote:
> this:
> @Override
> System.out.println("AddScene: added new Scene in Chapter
> } else
> return null;
> Model (e.g.:
> in this case).
> Thanks in Advance
> Mauro
Ok,
Answering to myself again ;)
For the record:
I solved the above problem by adding this to the AddScene Handler:
ISelectionProvider isp = HandlerUtil
.getActiveEditor(event)
.getSite()
.getSelectionProvider();
if (isp instanceof Viewer) {
Viewer tv = (Viewer) isp;
tv.refresh();
ISelection sel = new StructuredSelection(sc);
isp.setSelection(sel);
Now I have a similar problem involving EMF Databinding.
This is reason for crossposting.
My TreeViewer displays some data from the Model.
I have some master/detail pages that modify the model, possibly
including the data displayed in the master TreeViewer.
When this happens the TreeViewer is not automatically refreshed and I
couldn't guess how to do it manually.
TreeVieweris built like this:
bind();
The binding is:
protected void bindText(DataBindingContext dbc, Text t, EObject o,
EStructuralFeature sf) {
final IWidgetValueProperty wvp = WidgetProperties.text(SWT.Modify);
IObservableValue uiObs = wvp.observeDelayed(400, t);
IEMFValueProperty evp = EMFProperties.value(sf);
IObservableValue mObs = evp.observe(o);
dbc.bindValue(uiObs, mObs, null, null);
protected void bind() {
DataBindingContext dbc = new DataBindingContext();
bindText(dbc, textAuthor, world, Literals.WORLD__AUTHOR);
bindText(dbc, textName, world, Literals.WORLD__TITLE);
bindText(dbc, textDesc, world, Literals.WORLD__DESC);
IObservableFactory iof = new WorldObservableFactory();
TreeStructureAdvisor tsa = new WorldTreeStructureAdvisor();
ObservableListTreeContentProvider cp = new
ObservableListTreeContentProvider(iof, tsa);
tViewer.setContentProvider(cp);
WorldLabelProvider wlp = new WorldLabelProvider();
tViewer.setLabelProvider(wlp);
IEMFListProperty projects =
EMFProperties.list(ModelPackage.Literals.WORLD__BOOK);
tViewer.setInput(projects.observe(world));
This works, but tViewer is not updated when the Model changes.
I tried adding:
IObservableList w = projects.observe(world);
w.addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
tViewer.refresh();
But it is never called.
I can send any information needed. I just refrained from adding to an
already quite long post. Just ask.
What should I do?
TiA
Mauro
Re: model/TreeView synchronization problem. [message #514414 is a reply to message #514413] |
Mon, 15 February 2010 09:17 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
You need an ObservableMapLabelProvider (provided by JFace-Databinding) -
or a more special one like is show in my posts about EMF-Databinding.
A ColumnLabelProvider is in
http://tomsondev.bestsolution.at/2009/06/27/galileo-emf-data binding-part-5/
and a CellLabelProvider in
http://tomsondev.bestsolution.at/2009/06/08/galileo-emf-data binding-%e2%80%93-part-3/
All the code is in EMF-CVS so you can check it out copy it to your
project and your are done.
Tom
Am 15.02.10 10:11, schrieb Mauro Condarelli:
>> Hi,
>> of a Command. The handler for one particular addition (Add Scene) is
>> like this:
>> @Override
>> } else
>> return null;
>> need to reload the application (or otherwise reinitialize the
>> TreeViewer to see the newly created Scene.
>> Model (e.g.:
>> (tViewer, in this case).
>> Widget (tViewer) from the Selection I get from the Selection Service,
>> but I didn't find a way to do that.
>> Thanks in Advance
>> Mauro
> Ok,
> For the record:
> .getSite()
> tv.refresh();
> bind();
> The binding is:
> I tried adding:
> @Override
> tViewer.refresh();
> What should I do?
> TiA
> Mauro
Re: model/TreeView synchronization problem. [message #514505 is a reply to message #514414] |
Mon, 15 February 2010 11:16 |
Thanks a lot Tom.
I already saw Your tutorial, but (shame on me) I was not able to follow
exactly that part. I will try again.
In the meantime I modified my bindings as follows:
IObservableSet set = cp.getKnownElements();
final IObservableMap[] map = new IObservableMap[4];
map[0] =
EMFProperties.value(Literals.SCENE__TITLE).observeDetail(set );
map[1] =
EMFProperties.value(Literals.CHAPTER__TITLE).observeDetail(s et);
map[2] =
EMFProperties.value(Literals.BOOK__TITLE).observeDetail(set) ;
map[3] =
EMFProperties.value(Literals.WORLD__TITLE).observeDetail(set );
ObservableMapLabelProvider omlp = new
ObservableMapLabelProvider(map) {
public Image getColumnImage(Object element, int columnIndex) {
// TODO Auto-generated method stub
return super.getColumnImage(element, columnIndex);
public String getColumnText(Object element, int columnIndex) {
if (columnIndex == 0) {
if (element instanceof Scene) {
Object o = map[0].get(element);
return (o != null) ? o.toString() : "(null)";
} else if (element instanceof Chapter) {
Object o = map[1].get(element);
} else if (element instanceof Book) {
Object o = map[2].get(element);
} else if (element instanceof World) {
Object o = map[3].get(element);
return super.getColumnText(element, columnIndex);
tViewer.setLabelProvider(omlp);
EMFProperties.list(Literals.WORLD__BOOK);
.... and it WORKS!!
I still need to understand things better, but I can proceed.
Another thing I haven't found out how to do is:
The root of my model is World.
* @model
public interface World extends EObject {
* @model
public String getAuthor();
* @model opposite="world" containment="true"
public EList<Book> getBook();
* @model containment="true"
public EList<Actor> getActor();
public EList<Location> getLocation();
} // World
So it is rather wrong to use:
IEMFListProperty projects = EMFProperties.list(Literals.WORLD__BOOK);
.... but I didn't find what I should use instead!
My ModelPackage doesn't seem to contain an EReference pointing to the
Model Root.
What should I use?
TiA
Mauro
> Tom
>>> Hi,
>>> like this:
>>> @Override
>>> } else
>>> return null;
>>> Model (e.g.:
>>> Thanks in Advance
>>> Mauro
>> Ok,
>> For the record:
>> .getSite()
>> tv.refresh();
>> bind();
>> The binding is:
>> I tried adding:
>> @Override
>> tViewer.refresh();
>> What should I do?
>> TiA
>> Mauro
Re: model/TreeView synchronization problem. [message #514506 is a reply to message #514505] |
I'm not sure I follow this. Do you talk about observing the
Resource#getContent()? There's currently no properties support for this
and you need to use EMFObservables#observeResource().
There's a bug (and a 90% ready implementation) already to provide this
through the Properties-API but I can't remember the bug id.
Tom
Am 15.02.10 16:58, schrieb Mauro Condarelli:
> Thanks a lot Tom.
> map[0] =
> map[1] =
> map[2] =
> map[3] =
> @Override
> @Override
> ... and it WORKS!!
> * @model
> * @model
> } // World
> Model Root.
> What should I use?
> TiA
> Mauro
>> Tom
>>>> Hi,
>>>> like this:
>>>> @Override
>>>> } else
>>>> return null;
>>>> Model (e.g.:
>>>> Thanks in Advance
>>>> Mauro
>>> Ok,
>>> For the record:
>>> .getSite()
>>> tv.refresh();
>>> bind();
>>> The binding is:
>>> I tried adding:
>>> @Override
>>> tViewer.refresh();
>>> What should I do?
>>> TiA
>>> Mauro
Re: model/TreeView synchronization problem. [message #514512 is a reply to message #514506] |
Mon, 15 February 2010 16:14 |
Tom Schindl wrote:
Thanks a lot for the ultra-fast answer!
Yes. I want to observe Resource.getContent().
I will search for the bug and, in the meantime, I will try to understand
how to use EMFObservables#observeResource().
Many Thanks again
Mauro
> Tom
>> Thanks a lot Tom.
>> map[0] =
>> map[1] =
>> map[2] =
>> map[3] =
>> @Override
>> @Override
>> ... and it WORKS!!
>> * @model
>> * @model
>> } // World
>> Model Root.
>> What should I use?
>> TiA
>> Mauro
>>> Tom
>>>>> Hi,
>>>>> like this:
>>>>> @Override
>>>>> } else
>>>>> return null;
>>>>> Model (e.g.:
>>>>> Thanks in Advance
>>>>> Mauro
>>>> Ok,
>>>> For the record:
>>>> .getSite()
>>>> tv.refresh();
>>>> bind();
>>>> The binding is:
>>>> I tried adding:
>>>> @Override
>>>> tViewer.refresh();
>>>> What should I do?
>>>> TiA
>>>> Mauro
Re: model/TreeView synchronization problem. [message #514570 is a reply to message #514568] |
Mon, 15 February 2010 19:18 |
Tom Schindl wrote:
> Can you show us your ObservableFactory, I guess this where your problem
> is orginating from.
Pronto!
package it.condarelli.wbtest.editors;
import it.condarelli.wbtest.model.Book;
import it.condarelli.wbtest.model.Chapter;
import it.condarelli.wbtest.model.ModelPackage;
import it.condarelli.wbtest.model.World;
import org.eclipse.core.databinding.observable.IObservable;
import org.eclipse.core.databinding.observable.list.IObservableList ;
import
org.eclipse.core.databinding.observable.masterdetail.IObserv ableFactory;
import org.eclipse.emf.databinding.EMFProperties;
import org.eclipse.emf.databinding.IEMFListProperty;
public class WorldObservableFactory implements IObservableFactory {
private IEMFListProperty wMulti =
EMFProperties.multiList(ModelPackage.Literals.WORLD__ACTOR,
ModelPackage.Literals.BOOK__LOCATION, ModelPackage.Literals.WORLD__BOOK);
private IEMFListProperty bMulti =
EMFProperties.multiList(ModelPackage.Literals.BOOK__ACTOR,
ModelPackage.Literals.BOOK__CHAPTER, ModelPackage.Literals.BOOK__ITEM);
private IEMFListProperty cMulti =
EMFProperties.multiList(ModelPackage.Literals.CHAPTER__ACTOR ,
ModelPackage.Literals.CHAPTER__SCENE);
public WorldObservableFactory() {
// TODO Auto-generated constructor stub
public IObservable createObservable(Object target) {
if (target instanceof IObservableList) {
return (IObservable) target;
} else if (target instanceof World) {
return wMulti.observe(target);
} else if (target instanceof Book) {
return bMulti.observe(target);
} else if (target instanceof Chapter) {
return cMulti.observe(target);
return null;
TiA
Mauro
> Tom
> Am 15.02.10 20:11, schrieb Mauro Condarelli:
>>> Tom Schindl wrote:
>>>> Hi,
>>> understand how to use EMFObservables#observeResource().
>>> Many Thanks again
>>> Mauro
>> Sorry to pester You again.
>> I tried the following code:
>> Resource r = model.getResource();
>> // EList<EObject> eol = r.getContents();
>> IObservableList iol = EMFObservables.observeResourceContents(r);
>> tViewer.setInput(iol);
>> ... and it really displays the root of my tree.
>> Unfortunately trying to open it to display nodes it bombs with:
>> java.lang.ClassCastException: java.lang.String cannot be cast to
>> java.util.List
>> at
>> org.eclipse.emf.databinding.internal.EMFListProperty.doGetLi st(EMFListProperty.java:65)
>> at
>> org.eclipse.core.databinding.property.list.SimpleListPropert y.getList(SimpleListProperty.java:63)
>> at
>> org.eclipse.core.internal.databinding.property.list.SimplePr opertyObservableList.getList(SimplePropertyObservableList.ja va:122)
>> at
>> org.eclipse.core.internal.databinding.property.list.SimplePr opertyObservableList.doGetSize(SimplePropertyObservableList. java:126)
>> So I must be doing som Real Bad Things :((
>> I have not (yet) been able to find a suitable example on the Internet,
>> so here I am :)
>> Thanks in Advance
>> Mauro
Re: model/TreeView synchronization problem. [message #514577 is a reply to message #514570] |
Mon, 15 February 2010 19:41 |
> Tom Schindl wrote:
>> Hi,
>> is orginating from.
> Pronto!
> import
HERE IS THE BUG!! it should be:
ModelPackage.Literals.WORLD__LOCATION, ModelPackage.Literals.WORLD__BOOK);
Many thanks for pointing me in the right direction I never would have
guessed!
T H A N K S!!
Mauro
> @Override
> return null;
> TiA
> Mauro
>> Tom
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> this
>>>> Many Thanks again
>>>> Mauro
>>> java.util.List
>>> at
>>> at
>>> at
>>> at
>>> so here I am :)
>>> Thanks in Advance
>>> Mauro
Current Time: Fri Apr 19 23:14:26 GMT 2024
Powered by FUDForum. Page generated in 0.03848 seconds
