Home » Eclipse Projects » Rich Client Platform (RCP) » How do I find out if the content assist popup window is currently showing?
How do I find out if the content assist popup window is currently showing? [message #514044] Fri, 12 February 2010 09:51 Go to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
I am implementing a text editor that is closed when ESC is pressed. But
if the content assist popup window is showing, ESC should only close
this popup.
The main problem is that the
org.eclipse.jface.text.contentassist.CompletionProposalPopup .verifyKey(VerifyEvent)
returns true when ESC is pressed, thus handing the key event through to
the KeyListener that closes the editor.
My current workaround is a combined VerifyKeyListener / KeyListener that
sets a flag in verifyKey() if ESC is pressed and
ContentAssistant.hasProposalPopupFocus() returns true. If the flag is
set, the keyPressed() method ignores the next ESC. But that ugly
workaround only works if the popup is *focussed*.
I cannot add another IContentAssistListener to the ContentAssistant that
returns false in this case, as the add method is package private. I
guess that'd be a problem anyway, as I cannot make sure in which order
the IContentAssistListeners are registered / executed.
Any ideas?
Get professional support from the Xtext committers at www.typefox.io
Re: How do I find out if the content assist popup window is currently showing? [message #514117 is a reply to message #514044] Fri, 12 February 2010 13:32 Go to previous message
Dani Megert is currently offline Dani MegertFriend
> But if the content assist popup window is showing, ESC should only
> close this popup.
> to the KeyListener that closes the editor.
> that sets a flag in verifyKey() if ESC is pressed and
> that returns false in this case, as the add method is package private.
> I guess that'd be a problem anyway, as I cannot make sure in which
> order the IContentAssistListeners are registered / executed.
> Any ideas?
You don't need to implement closing on 'Esc'. Simply assign 'Esc' to the
Close command and all works as expected.
Dani
Previous Topic:How ViewPart response to some EditorPart Action
Next Topic:TabbedProperties
Current Time: Wed Sep 11 00:09:35 GMT 2024
Powered by FUDForum. Page generated in 0.02867 seconds
