Home » Eclipse Projects » JFace » EMF+Databinding+Master/DetailsForms=LOST
EMF+Databinding+Master/DetailsForms=LOST [message #513995] Thu, 11 February 2010 23:33 Go to next message
Mauro Condarelli is currently offline Mauro CondarelliFriend
Sorry to disturb again and doubly sorry because I'm cross-posting, but
I'm not sure what's the right place for this.
I'm trying to build a custom editor for my model written using EMF.
I am using forms to be consistent with normal eclipse behavior.
After some experimentation I managed to have a structure I like and it
is somewhat working.
I have a multi-page editor, but that is unimportant because my problems
are on the first "overview" page.
This is a simple (?) Master/Details page holding a TreeViewer on the
master block and a few DetailsPage's
Problem is in the DetailsPage's.
I have the following:
public class ChapterDetailsPage implements IDetailsPage {
private Chapter chapter; //<< this is the EMF Interface to display
public void createContents(Composite parent) {
//testComposite = new testComposite(parent, SWT.NONE);
//parent.setLayout(new FillLayout());
FormToolkit toolkit = managedForm.getToolkit();
Section sctnBook = toolkit.createSection(parent,
ExpandableComposite.EXPANDED | ExpandableComposite.TITLE_BAR);
sctnBook.setText("Chapter");
.... create the detail form this seems ok ...
if (chapter != null) // never entered: at creation time chapter
== null
m_bindingContext = initDataBindings();
public void selectionChanged(IFormPart part, ISelection selection) {
IStructuredSelection structuredSelection =
(IStructuredSelection) selection;
if (structuredSelection.size()==1) {
Chapter c = (Chapter)structuredSelection.getFirstElement();
if (!c.equals(chapter)) {
chapter = c;
if (m_bindingContext == null) << HERE IS PROBLEM (see
below)
update();
// here I do my Databindings; are they OK?
protected DataBindingContext initDataBindings() {
DataBindingContext bindingContext = new DataBindingContext();
IObservableValue txtTitleObserveTextObserveWidget =
SWTObservables.observeText(txtTitle, SWT.Modify);
IObservableValue bookTitleObserveValue =
EMFObservables.observeValue(chapter, Literals.CHAPTER__TITLE);
bindingContext.bindValue(txtTitleObserveTextObserveWidget,
bookTitleObserveValue, null, null);
IObservableValue txtDescObserveTextObserveWidget =
SWTObservables.observeText(txtDesc, SWT.Modify);
IObservableValue bookDescObserveValue =
EMFObservables.observeValue(chapter, Literals.CHAPTER__DESC);
bindingContext.bindValue(txtDescObserveTextObserveWidget,
bookDescObserveValue, null, null);
ObservableListContentProvider listContentProvider = new
ObservableListContentProvider();
tViewer.setContentProvider(listContentProvider);
IObservableMap[] observeMaps =
EMFObservables.observeMaps(listContentProvider.getKnownEleme nts(), new
EStructuralFeature[]{Literals.SCENE__TITLE, Literals.CHAPTER__DESC});
tViewer.setLabelProvider(new
ObservableMapLabelProvider(observeMaps));
IObservableList bookChapterObserveList =
EMFObservables.observeList(Realm.getDefault(), chapter,
Literals.CHAPTER__SCENE);
tViewer.setInput(bookChapterObserveList);
return bindingContext;
Problem is this way I do not track the changes when chapter changes.
This is because the bindings are done only once and thus the form always
displays the same content.
The obvious workaround: reinitialize the bindings each time chapter is
updated (remove the problematic "if (m_bindingContext == null)" doesn't
work either because I get exceptions:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
Getter called on disposed observable
org.eclipse.emf.databinding.EObjectObservableMap@1655fb9
So I suspect I have done something seriously wrong with databinding.
Unfortunately I was not able to find a suitable example code.
I have found Master/Details and I have found EMF separately.
I did not find Master/Details and found EMF together.
Any suggestion?
Thanks a lot
Mauro
Re: EMF+Databinding+Master/DetailsForms=LOST [message #514026 is a reply to message #513995] Fri, 12 February 2010 08:50 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
My tutorial [1] on EMF-Databinding shows Master-Detail in action.
Am I correct in assuming that the field chapter is changing all the time?
I don't see you createing a detail-observables but only standard
observables.
If I get your code right.
Then you need change:
a) Instance field to:
WritableList chapter = new WritableList();
b) Create your bindings:
EMFObservables.observeDetail(chapter,....)
Please also note that you are using the old EMFObservables-Factory
whereas the newer EMFProperties should be preferred.
Tom
[1] http://tomsondev.bestsolution.at/2009/06/06/galileo-improved -emf-databinding-support/
Am 12.02.10 00:33, schrieb Mauro Condarelli:
> == null
> chapter = c;
> below)
> update();
> Any suggestion?
> Thanks a lot
> Mauro
Re: EMF+Databinding+Master/DetailsForms=LOST [message #514027 is a reply to message #513995] Fri, 12 February 2010 09:04 Go to previous messageGo to next message
Answering to myself :)
I found the following is somewhat working.
see below.
private IObservableValue observableChapter = new
WritableValue(null, Chapter.class);
//delete > if (chapter != null) // never entered: at creation
time chapter
> == null
> chapter = c;
//delete > if (m_bindingContext == null) << HERE IS
PROBLEM (see
//delete > below)
//delete > m_bindingContext = initDataBindings();
observableChapter.setValue(c);
> update();
//change > IObservableValue bookTitleObserveValue =
//change > EMFObservables.observeValue(chapter, Literals.CHAPTER__TITLE);
EMFObservables.observeDetailValue(Realm.getDefault(), observableChapter,
//change > IObservableValue bookDescObserveValue =
//change > EMFObservables.observeValue(chapter, Literals.CHAPTER__DESC);
//change >
//change > EStructuralFeature[]{Literals.SCENE__TITLE,
EStructuralFeature[]{Literals.SCENE__TITLE, Literals.SCENE__DESC});
//change > EMFObservables.observeList(Realm.getDefault(), chapter,
//change > Literals.CHAPTER__SCENE);
EMFObservables.observeDetailList(Realm.getDefault(), observableChapter,
> Any suggestion?
> Thanks a lot
> Mauro
With this update (somewhat working) code I have two major problems:
1) The TableViewer (tViewer) always displays just one column: the first
one defined in observeMaps. The others are silently ignored. I'm missing
something, but I can't divine what.
2) I don't really know what I'm doing. I'm blindly coping pieces of code
found googling around, but I miss a somewhat general picture. All usage
of EMFObservables is rather obscure to me.
Can someone shed light around, pretty please?
Thanks in Advance
Mauro
Re: EMF+Databinding+Master/DetailsForms=LOST [message #514031 is a reply to message #514027] Fri, 12 February 2010 09:20 Go to previous message
You are not showing us how you create the table viewer:
a) You need to create your Table/TableViewer-Columns
b) You need to set a LabelProvider to each of them
See my tutorial code in CVS.
What you are doing is correct Master-Detail binding. Did you go through
my EMF-Databinding Tutorial and the source code it is coming with?
Tom
Previous Topic:[Databinding] what TreeView support is ao display my vailable from EMF?
Next Topic:No checkbox for all nodes in a CheckboxTreeViewer ?
Current Time: Tue Apr 16 14:42:44 GMT 2024
Powered by FUDForum. Page generated in 0.15601 seconds
