Home » Eclipse Projects » Rich Client Platform (RCP) » How to create a pop-up menu
How to create a pop-up menu [message #513821] Thu, 11 February 2010 12:16 Go to next message
Jan Krakora is currently offline Jan KrakoraFriend
Hi guys,
I have an IContributionItem object and I want to create a pop-up menu in my View. How can I add this IContributionItem in the pop-up menu?
This works fine:
MenuManager menuManager = new MenuManager();
manager.add(myContributionItemObject);
Menu menu = menuManager.createContextMenu(viewer.getControl());
viewer.getControl().setMenu(menu);
getSite().registerContextMenu(menuManager, viewer);
But I'd like to have myContributionItemObject in its own sub-menu called "Zoom". How can I do that?
Re: How to create a pop-up menu [message #513838 is a reply to message #513821] Thu, 11 February 2010 08:24 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Create a second MenuManager. Add that to the first MenuManager, and add
your contribution item to the second.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to create a pop-up menu [message #513868 is a reply to message #513838] Thu, 11 February 2010 14:38 Go to previous messageGo to next message
Hi Paul,
thank for your advice. Did you mean something like this:
MenuManager submenuManager = new MenuManager("Zoom");
menuManager.add(new GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
menuManager.add(new Separator());
menuManager.add(submenuManager);
submenuManager.add(myContributionItemObject);
Great, but if I hover by mouse on the "Zoom" in the menu, it turns gray and nothing happens..I mean, no sub-menu shows up. Confused
Re: How to create a pop-up menu [message #513907 is a reply to message #513868] Thu, 11 February 2010 16:09 Go to previous messageGo to next message
That's because myContributionItemObject appears to be not-visible or
doesn't create any MenuItems. Your submenu is then disabled because it
has nothing in it. What is your contribution item doing?
PW
Paul Webster
Re: How to create a pop-up menu [message #513917 is a reply to message #513907] Thu, 11 February 2010 16:26 Go to previous message
Paul Webster wrote on Thu, 11 February 2010 11:09
PW
myContributionItemObject is a list of 6 zoom values. But if I right-click and open pop-up menu, there is a "Zoom" item and it's enabled. It goes gray only after I hover on that with mouse.
It's weird. If I use this code:
It works perfectly except that those 6 zoom values are in root menu. And I want to put them in "Zoom" submenu Smile
[Updated on: Thu, 11 February 2010 16:27]
Report message to a moderator
Previous Topic:limiting command visibility depending on view selecction
Next Topic:Jeff McAffers new RCP book - when?
Current Time: Thu Sep 12 16:48:05 GMT 2024
Powered by FUDForum. Page generated in 0.04412 seconds
