Home » Eclipse Projects » Mylyn » WikiText: following links in the preview
Re: WikiText: following links in the preview [message #514357 is a reply to message #514297] |
Mon, 15 February 2010 00:12 |
Heribert Schütz Messages: 24 Registered: July 2009 |
Hi David,
thanks for your answers. I'm not sure whether my previous post was completely clear. So I elaborate a bit more.
> It'll work fine for you if you want the links to resolve once you've generated
> HTML from the Textile source. For example, given two pages:
> one.textile
> two.textile
> You should be able to link from one to two as follows: "two":two.html
Yes, that's what I already understood. And that might be appropriate in a situation where the roles of authors and readers are clearly separated. The readers who follow the links will never see the original wiki files but only the generated html files and thus for them an html-to-html link is appropriate.
In my use case (technical code documentation) the situation is different: My colleagues and me are at the same time authors and readers of these files. When I follow a link, I want to be able to edit the file without searching for the wiki source of some html file. So I'd prefer textile-to-textile (actually wiki-source-to-wiki-source) links.
In addition I'd prefer to avoid the hassles of generating and managing html files:
- automating the translation from wiki to html (e.g., whenever I save a wiki file)
- configuring revision control to ignore these redundant html files, and
- ensuring that html files are also generated whenever I get a new or updated
wiki file from revision control.
Of course WikiText could come with all this automation and it could hide the generated html files from me in the same way as I need not deal with class files when I write Java code. But that would be quite some effort.
I thought a much easier solution would be to support links like "two":two.textile within one.textile. Following this link in preview mode already does open two.textile (i.e., the wiki source) as I like, but unfortunately in a browser tab where I cannot edit it. I hoped that links to wiki files could simply be intercepted and opened in an editor tab instead (at least if the resource is writable).
> Perhaps Mylyn WikiText should be smart enough to support your workflow, in other
> words if you click on the link in the source view it should open the editor for the
> textile file instead of the HTML file.
I think a link like "two":two.textile in the wiki file would be better than "two":two.html, even for use cases where the wiki source is not delivered to the readers. This is because a link to two.html only works with translation to html whereas a link to two.textile can be adapted to any translation target, e.g., docbook.
But these were just some general thoughts. They are not needed for my use case but show that my suggestion above (to support source-to-source links) is not just a hack.
Heribert.
Re: WikiText: following links in the preview [message #514808 is a reply to message #514357] |
Tue, 16 February 2010 16:57 |
David Green Messages: 136 Registered: July 2009 |
Heribert,
Thanks for clarifying. Comments below:
On 14/02/10 4:12 PM, Heribert Schütz wrote:
> Hi David,
>> generated
>> one.textile
>> two.textile
That makes sense to me.
Such links should work from the source view as well (with the usual keyboard modifier such as CTRL+Click or
Command+Click on a mac).
Please file a bug if you think an enhancement is needed here.
> html files:
> wiki file)
> updated
Agreed, for your use case it makes sense to not have to generate anything when using the files locally, though it would
be nice if these links did not preclude that option. For example, perhaps links such as "one":one.textile should
automatically be modified to point to the corresponding HTML file when generating HTML (as you describe below).
Please file a bug describing this issue
>> workflow, in other
>> editor for the
> Regards,
> Heribert.
Re: WikiText: following links in the preview [message #600696 is a reply to message #514297] |
Hi David,
> one.textile
> two.textile
Heribert.
Re: WikiText: following links in the preview [message #600705 is a reply to message #600696] |
David Green Messages: 96 Registered: July 2009 |
Member |
Heribert,
> Hi David,
>> generated
>> one.textile
>> two.textile
> html files:
> wiki file)
> updated
>> workflow, in other
>> editor for the
> Regards,
> Heribert.
Current Time: Thu Apr 25 10:28:09 GMT 2024
Powered by FUDForum. Page generated in 0.03687 seconds
