Home » Modeling » M2T (model-to-text transformation) » [XPAND] XPand and Partitioning Ecore is possible ?(With a multiple ecore file metamodel, non-root class are not found)
[XPAND] XPand and Partitioning Ecore is possible ? [message #513530] |
Wed, 10 February 2010 13:59 |
Hi everyone,
I have a problem to generate files with XPand when my metamodel is a multiple ecore files.
To have a clear metamodel for my EMF editor, i made a 'partitioned' one.
A problem appears when i try to generate files with Xpand. It doesn't find the Class which are not in the root Ecore file, and i can't define the functions...
But, if i call them by hierarchy (and make an horrible single DEFINE function it works...) everything is OK he finds all the classes i call.
I checked the dependencies in the MANIFEST.MF and everything is OK.
The problem seems to come from my definition but i have no idea to do it in an other way.
Or maybe it is impossible to associate Xpand with a multiple file metamodel ?
If anybody already had this problem, or if you know the possibility (or impossibility ) to do this, it will be really helpfull...
Thanks !
Florine
Simple Example:
The root Ecore file has the Procedure Class.
An other Ecore file has the RobotTask Class.
The Class Procedure has EReference to a List of RobotTask.
.xpt file code :
«IMPORT procedure »
«IMPORT robot »
«DEFINE RobotDef FOR RobotTask»
Bla bla...
«ENDDEFINE»
«DEFINE Root FOR Procedure»
«EXPAND RobotDef FOREACH hasTaskRobot»
«ENDDEFINE»
Error detected :
SEVERE: Error in Component generator of type org.openarchitectureware.xpand2.Generator:
EvaluationException : No Definition 'RobotDef for robot::RobotTask' found!
templates::Root.xpt[206,36] on line 15 'EXPAND RobotDef FOREACH hasTaskRobot'
[23,38] on line 1 'EXPAND templates::Root::Root FOR model'
[Updated on: Wed, 10 February 2010 14:02] Report message to a moderator
Re: [XPAND] XPand and Partitioning Ecore is possible [message #513582 is a reply to message #513530] |
Wed, 10 February 2010 10:54 |
--------------050606010808040007000704
florine,
this should work. redview (http://redview.org) uses always some ecore files
register them all:
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value=".." />
<registerEcoreFile value="${redview.mm.dir.uri}binding.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}datatypes.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}elements.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}layout.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}styles.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}validation.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}converter.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}visibility.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}dnd.ecore"/>
<registerEcoreFile value="${redview.mm.dir.uri}events.ecore"/>
<registerEcoreFile value="${redview.mm.ext.riena.dir.uri}validators.ecore"/>
<registerEcoreFile value="${redview.mm.ext.riena.dir.uri}converters.ecore"/>
</bean>
as karsten said - use URIs - not Pathes
ekke
Am 10.02.10 14:59, schrieb Florine Boudin:
> Hi everyone,
> it in an other way.
> metamodel ?
> (or impossibility :( ) to do this, it will be really helpfull...
> Thanks !
> Florine
> Simple Example:
> xpt file code :
> «IMPORT procedure »
> «IMPORT robot »
> Bla bla...
> «ENDDEFINE»
> «ENDDEFINE»
> Error detected :
> org.openarchitectureware.xpand2.Generator: EvaluationException :
> hasTaskRobot'
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
florine,<br>
<br>
this should work. redview (<a class="moz-txt-link-freetext" href="http://redview.org">http://redview.org</a>) uses always some ecore
files<br>
<br>
register them all:<br>
<br>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"><br >
<platformUri value=".." /> <br>
<registerEcoreFile
value="${redview.mm.dir.uri}binding.ecore"/><br>
<registerEcoreFile
value="${redview.mm.dir.uri}datatypes.ecore"/><br>
<registerEcoreFile
value="${redview.mm.dir.uri}elements.ecore"/><br>
<registerEcoreFile
value="${redview.mm.dir.uri}layout.ecore"/> <br>
<registerEcoreFile
value="${redview.mm.dir.uri}styles.ecore"/><br>
<registerEcoreFile
value="${redview.mm.dir.uri}validation.ecore"/><br >
<registerEcoreFile
value="${redview.mm.dir.uri}converter.ecore"/><br>
<registerEcoreFile
value="${redview.mm.dir.uri}visibility.ecore"/><br >
<registerEcoreFile
value="${redview.mm.dir.uri}dnd.ecore"/><br>
<registerEcoreFile
value="${redview.mm.dir.uri}events.ecore"/><br>
<br>
<registerEcoreFile
value="${redview.mm.ext.riena.dir.uri}validators.ecore"/> <br>
<registerEcoreFile
value="${redview.mm.ext.riena.dir.uri}converters.ecore"/> <br>
</bean><br>
<br>
as karsten said - use URIs - not Pathes<br>
<br>
ekke<br>
<br>
<blockquote cite="mid:hkue46$2gr$1@build.eclipse.org" type="cite">Hi
everyone,
<br>
<br>
<br>
<br>
one.
<br>
the functions...
<br>
<br>
<br>
<br>
<br>
<br>
it in an other way.
<br>
metamodel ?
<br>
<br>
<br>
<br>
Thanks !
<br>
<br>
Florine
<br>
<br>
<br>
Simple Example:
<br>
<br>
<br>
The Class Procedure has EReference to a List of RobotTask. <br>
xpt file code :
<br>
<br>
«IMPORT procedure »
<br>
«IMPORT robot »
<br>
<br>
<br>
Bla bla...
<br>
«ENDDEFINE»
<br>
<br>
<br>
<br>
«ENDDEFINE»
<br>
<br>
<br>
Error detected :
<br>
<br>
org.openarchitectureware.xpand2.Generator: EvaluationException : No
<br>
hasTaskRobot'
<br>
[23,38] on line 1 'EXPAND templates::Root::Root FOR model' <br>
</blockquote>
<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------050606010808040007000704--
ekke
independent software architect
blog: http://ekkes-corner.org
Re: [XPAND] XPand and Partitioning Ecore is possible [message #513613 is a reply to message #513582] |
Wed, 10 February 2010 17:10 |
Thank you ekke and Karsten !
You reassured me about the feasibility of it.
Right now it doesn't work. But i think i need to understand all the step of the workflow to make it work, for the moment new errors appeared...
I will post my solution. I hope as soon as possible .
Maybe i will ask other questions.
Thanks again !
Florine
Re: [XPAND] XPand and Partitioning Ecore is possible [message #531314 is a reply to message #513613] |
Tue, 04 May 2010 14:28 |
Hi everyone,
I managed few days after my last message and i think it's a good idea to share my solution with you.
With a partitioning ecore, when i use XPand, i modified the worflow.oaw file.
The ecore file 'procedure' uses classes of the 'task.ecore' file, which uses classes of the 'module.ecore' file.
In the Generator defined in the oaw file, I call all each one of them in a metamodel :
<component id="generator"
class="org.openarchitectureware.xpand2.Generator">
<metaModel id="mm"
class="org.openarchitectureware.type.emf.EmfMetaModel">
<metaModelPackage value="procedure.ProcedurePackage"/>
</metaModel>
<metaModel id="mm2"
<metaModelPackage value="task.TaskPackage"/>
</metaModel>
<metaModel id="mm3"
<metaModelPackage value="module.ModulePackage"/>
</metaModel>
</component>
Now, in the xpt file, the imports are recognized ! ! No more errors
«IMPORT procedure »
«IMPORT tache »
«IMPORT module »
Thanks again for your help !
Florine
Current Time: Wed Apr 24 22:40:16 GMT 2024
Powered by FUDForum. Page generated in 0.02857 seconds
