Home » Eclipse Projects » Remote Application Platform (RAP) » Custom widget embedding FCKeditor
Re: Custom widget embedding FCKeditor [message #513370 is a reply to message #513362] |
Tue, 09 February 2010 21:11   |
Nikolai Raitsev Messages: 102 Registered: July 2009 |
maybe you still need to register the fckeditor resources?
We do it programmatically, e.g.:
public RichHtmlEditor(Composite parent, int style) {
super(parent, style);
logger.debug("creating RichHtmlEditor Object, register tinymce resources");
Activator activator = Activator.getDefault();
if (!activator.isResoursesRegistered())
activator.registerResources();
In Activator of RichHtmlEditor-Bundle:
(under tiny_mce-Folder are all TinyMCE resources (all js-files and images)
public void registerResources()
try
logger.debug("register tinymce resources");
registerResources("tiny_mce", new String[]{".svn"});
resourcesRegistered = true;
}catch (Exception e)
logger.error("Error in registerResources", e);
resourcesRegistered = false;
* Register all resources, recursively under specified folder
* <br />
* search path = plugin root location
* @param clazz - executor class
* @param folder - folder name
* @param exclude - compared by filename.startsWith(exclude[*])
private void registerResources(String folder, String...exclude) {
RWT.getResourceManager().setContextLoader(this.getClass().ge tClassLoader());
List<String> collectedPaths = new ArrayList<String>();
getContents("/" + folder, collectedPaths, exclude);
for ( String resource:collectedPaths ) {
if ( !RWT.getResourceManager().isRegistered(resource) ) {
RWT.getResourceManager().register(resource);
logger.debug("registered resource ->" + resource);
private void getContents(String path, List<String> collectedPaths,
String...exclude)
Enumeration<?> enums = getBundle().getEntryPaths(path);
while(enums.hasMoreElements())
Object object = enums.nextElement();
Enumeration<?> tmpEnum =getBundle().getEntryPaths(object.toString());
if(tmpEnum != null)
getContents(object.toString(), collectedPaths, exclude);
else
boolean accept = true;
for(String str:exclude)
if(object.toString().contains(str))
accept = false;
if(accept)
collectedPaths.add(object.toString());
for more see in code from Georgi:)
wish you much fun:)
Nikolai
Valer Roman schrieb:
> Hello,
> I am trying to create a custom widget for the FCKEditor.
> I have studied the GMap example and all seems clear but ... the
> problem I have is in using the fckeditor.js java script library as a
> resource.
> I have used it as an external resource on a different server path
> localhost:8080/fckeditor/fckeditor.js. Here the problem is that it
> reports "Permission denied" messages on some code of other javascripts
> libraries fckeditor.js uses. This is I think because rap runs on
> localhost:9090/rap so it sees localhost:8080 as a different server and
> browser security forbids some methods to be executed.
> I would like somehow to have the fckeditor deployed on the same server
> as rap, localhost:9090/rap or something like that, to avoid the security
> problems.
> If somebody could help me ... maybe I am on the wrong track ...
> Thank you,
> Valer Roman
Re: Custom widget embedding FCKeditor [message #513373 is a reply to message #513370] |
Tue, 09 February 2010 21:29  |
Valer Roman Messages: 36 Registered: July 2009 |
Member |
Thanks again :)
I have also tried the TinyMCE code, works great. The only issue is that
I want to use also images in the text so I am still playing with
FCKEditor integration.
I have managed to start the FCKEditor visually, thanks to code from
TinyMCE, but got some errors when using.
I think your code for registering recursively resources will help me
advance.
will get back with more info or problems :)
Nikolai Raitsev wrote:
> resources");
> try
> * <br />
> String...exclude)
> if(tmpEnum != null)
> else
> accept = false;
> if(accept)
> wish you much fun:)
> Best regards,
> Nikolai
>> Hello,
>> resource.
>> problems.
>> Thank you,
>> Valer Roman
Current Time: Thu Feb 09 10:40:28 GMT 2023
Powered by FUDForum. Page generated in 0.01810 seconds
