Home » Eclipse Projects » Rich Client Platform (RCP) » Plug-in stop() be terminated before completion.(How to workaround?)
Plug-in stop() be terminated before completion. [message #513158] Tue, 09 February 2010 06:42 Go to next message
Tony  is currently offline Tony Friend
I have a plugin need to do some clean up work upon the shutdown of the RCP. I tried to override the stop() of the Plugin class, but sometimes it's terminated before completion.
I notice in the Plugin API, there's a notes:
This method is intended to perform simple termination of the plug-in environment. The platform may terminate invocations that do not complete in a timely fashion.
So looks like it's designed to be so.
Does anyone have idea how to workaround it?
Re: Plug-in stop() be terminated before completion. [message #513197 is a reply to message #513158] Tue, 09 February 2010 10:44 Go to previous message
Michael Golovanov is currently offline Michael GolovanovFriend
Member
You can try to use IWorkbenchListener
PlatformUI.getWorkbech().addWorkbechListener
listener has methods for pre and post shutdown handling
Regards, Mike
Previous Topic:how (and when) are view constructed?
Next Topic:how to know which eclipse version i am using
Current Time: Fri Sep 30 17:16:39 GMT 2022
Powered by FUDForum. Page generated in 0.02171 seconds
