Home » Eclipse Projects » Equinox » Declarative Services (DS) do not work as expected
Declarative Services (DS) do not work as expected [message #512933] |
Mon, 08 February 2010 11:54 |
Bjoern Berg Messages: 47 Registered: November 2009 Location: Essen |
Member |
I have a very interesting problem while using declarative services in an Eclipse application. I created two Interfaces IDataLoader and IListChangeListener; services implement these interfaces and are automatically bind / unbind to Lists of my own type of IList.
The problem is: Registering services implementig IDataLoader works without problems, but the services implementig IListChangeListener are not called or better the binding method is not called.
To make it more clear, here is the definition for a List binding IDataLoader and IListChangeListener:
modemlist.xml
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" enabled="true" immediate="true" name="de.genesys_e.modem.modemList">
<implementation class="de.genesys_e.modem.impl.ModemListImpl"/>
<service>
<provide interface="de.genesys_e.datamodell.lists.IList"/>
</service>
<reference bind="addListener" cardinality="0..n" interface="de.genesys_e.datamodell.lists.IListChangeListener" name="IListChangeListener" policy="dynamic" unbind="removeListener"/>
<reference bind="addLoader" cardinality="0..n" interface="de.genesys_e.datamodell.lists.IDataLoader" name="IDataLoader" policy="dynamic" unbind="removeLoader"/>
</scr:component>
The definition for services implementing IDataLoader or IListChangeListener look like this:
modemloader.xml
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" immediate="true" name="de.genesys_e.modem.registry.modemLoader">
<implementation class="de.genesys_e.modem.registry.ModemRegistryLoader"/>
<service>
<provide interface="de.genesys_e.datamodell.lists.IDataLoader"/>
</service>
</scr:component>
modemwriter.xml
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" immediate="true" name="de.genesys_e.modem.registry.modemWriter">
<implementation class="de.genesys_e.modem.registry.ModemRegistryWriter"/>
<service>
<provide interface="de.genesys_e.datamodell.lists.IListChangeListener"/>
</service>
</scr:component>
To see whats happening behind, I have activated tracing for DS and can see that the services implementing IChangeListener and IDataLoader are build and that the service knows where it has to bind / unbind the bundles, but the appropriate bind-method for IChangeListener is not called. The log looks like this:
DEBUG 49 ServiceComponentProp.bindReference(): component de.genesys_e.modem.modemList -> Reference[name = IListChangeListener, interface = de.genesys_e.datamodell.lists.IListChangeListener, policy = dynamic, cardinality = 0..n, target = null, bind = addListener, unbind = removeListener]
DEBUG 49 ServiceComponentProp.bindReference(): The service is not yet registered, but it is already instantiated
DEBUG 49 ServiceComponentProp.bindReference(): component de.genesys_e.modem.modemList -> Reference[name = IDataLoader, interface = de.genesys_e.datamodell.lists.IDataLoader, policy = dynamic, cardinality = 0..n, target = null, bind = addLoader, unbind = removeLoader]
DEBUG 49 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ServiceComponentProp.activat e(): name: de.genesys_e.modem.modemList
DEBUG 49 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ServiceComponentProp.activat e(): using bundle: null
DEBUG 49 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ServiceComponentProp.activat e(): instance: org.eclipse.equinox.internal.ds.impl.ComponentInstanceImpl@63a1ae
DEBUG 49 ServiceComponent.getMethod(): activate
DEBUG 49 ComponentStorage.parseXMLDeclaration(): loading bundleentry://16.fwk23103355/OSGI-INF/modemloader.xml
DEBUG 49 ComponentStorage.parseXMLDeclaration(): loading bundleentry://16.fwk23103355/OSGI-INF/protocolloader.xml
DEBUG 49 ComponentStorage.parseXMLDeclaration(): loading bundleentry://16.fwk23103355/OSGI-INF/modemwriter.xml
DEBUG 49 ComponentStorage.parseXMLDeclaration(): loading bundleentry://16.fwk23103355/OSGI-INF/protocolwriter.xml
INFO 49 [DS perf] The components of bundle de.genesys_e.modem.registry_1.0.1.qualifier [16] are parsed for 15 ms
DEBUG 49 WorkThread.run(): object to process [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@1751a9e; actionType 1
DEBUG 49 [SCR] WorkThread.run(): Timer service is not available! Skipping timeout check
DEBUG 49 Resolver.enableComponents(): [Component[
name = de.genesys_e.modem.registry.modemLoader
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = de.genesys_e.modem.registry.ModemRegistryLoader
properties = null
serviceFactory = false
serviceInterface = [de.genesys_e.datamodell.lists.IDataLoader]
references = null
located in bundle = de.genesys_e.modem.registry_1.0.1.qualifier [16]
], Component[
name = de.genesys_e.modem.registry.protocolLoader
activate = activate
modified =
factory = null
autoenable = true
immediate = true
implementation = de.genesys_e.modem.registry.ProtocolRegistryLoader
properties = null
references = null
], Component[
name = de.genesys_e.modem.registry.modemWriter
activate = activate
modified =
factory = null
autoenable = true
immediate = true
implementation = de.genesys_e.modem.registry.ModemRegistryWriter
properties = null
serviceInterface = [de.genesys_e.datamodell.lists.IListChangeListener]
references = null
], Component[
name = de.genesys_e.modem.registry.protocolWriter
activate = activate
modified =
factory = null
autoenable = true
immediate = true
implementation = de.genesys_e.modem.registry.ProtocolRegistryWriter
properties = null
references = null
DEBUG 49 Resolver.map(): Creating SCP for component de.genesys_e.modem.registry.modemLoader
DEBUG 49 Resolver.map(): Creating SCP for component de.genesys_e.modem.registry.protocolLoader
DEBUG 49 Resolver.map(): Creating SCP for component de.genesys_e.modem.registry.modemWriter
DEBUG 49 Resolver.map(): Creating SCP for component de.genesys_e.modem.registry.protocolWriter
DEBUG 49 Resolver:resolveEligible(): resolved components = [org.eclipse.update.configurator.bundlegroup, de.genesys_e.modem.modemList, de.genesys_e.modem.hayesList, de.genesys_e.modem.registry.modemLoader, de.genesys_e.modem.registry.protocolLoader, de.genesys_e.modem.registry.modemWriter, de.genesys_e.modem.registry.protocolWriter]
INFO 49 [DS perf] Start building component de.genesys_e.modem.registry.modemLoader
DEBUG 49 InstanceProcess.buildComponents(): building immediate component de.genesys_e.modem.registry.modemLoader
DEBUG 49 InstanceProcess.buildComponent(): building component de.genesys_e.modem.registry.modemLoader
INFO 49 [DS perf] Start building instance of component de.genesys_e.modem.registry.modemLoader
INFO 49 [DS perf] Start building component de.genesys_e.modem.registry.modemWriter
DEBUG 49 InstanceProcess.buildComponents(): building immediate component de.genesys_e.modem.registry.modemWriter
DEBUG 49 InstanceProcess.buildComponent(): building component de.genesys_e.modem.registry.modemWriter
INFO 49 [DS perf] Start building instance of component de.genesys_e.modem.registry.modemWriter
DEBUG 49 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ServiceComponentProp.activat e(): name: de.genesys_e.modem.registry.modemWriter
DEBUG 49 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ServiceComponentProp.activat e(): instance: org.eclipse.equinox.internal.ds.impl.ComponentInstanceImpl@18b3e62
INFO 49 [DS perf] The instance of component de.genesys_e.modem.registry.modemWriter is built for 0ms
DEBUG 49 Resolver.getEligible(): processing service event org.osgi.framework.ServiceEvent[source={de.genesys_e.datamod ell.lists.IListChangeListener}={component.name=de.genesys_e. modem.registry.modemWriter, component.id=5, service.id=41}]
DEBUG 49 Service event type: REGISTERED
DEBUG 49 Resolver.selectDynamicBind(): selected = [org.eclipse.equinox.internal.ds.Reference@ac97cc, org.eclipse.equinox.internal.ds.Reference@121f653]
DEBUG 49 ServiceReg.getService(): service 'de.genesys_e.modem.registry.modemWriter' is used 1 time(s), object = de.genesys_e.modem.registry.ModemRegistryWriter@8497f6
DEBUG 49 InstanceProcess.registerService(): de.genesys_e.modem.registry.modemWriter registered as *service*
INFO 49 [DS perf] The component de.genesys_e.modem.registry.modemWriter is built for 0ms
Any idea, what's going wrong?
Re: Declarative Services (DS) do not work as expected [message #513163 is a reply to message #513116] |
Tue, 09 February 2010 07:24 |
Member |
Phil,
thank you for your message. I have started the console, typing "status" I get the following (shortened):
9 reference:file:/D:/gasbuild/Eclipse-RCP/de.genesys_e.datamodell/
ACTIVE de.genesys_e.datamodell_1.0.0.qualifier
15 reference:file:/D:/gasbuild/Eclipse-RCP/de.genesys_e.modem/
ACTIVE de.genesys_e.modem_1.0.0
16 reference:file:/D:/gasbuild/Eclipse-RCP/de.genesys_e.modem.registry/
<<LAZY>> de.genesys_e.modem.registry_1.0.1.qualifier
17 reference:file:/D:/gasbuild/Eclipse-RCP/de.genesys_e.modem.ui/
ACTIVE de.genesys_e.modem.ui_0.9.0
{de.genesys_e.datamodell.lists.IList}={component.name=de.genesys_e.modem.modemList, component.id=1, service.id=37}
{de.genesys_e.datamodell.lists.IList}={component.name=de.genesys_e.modem.hayesList, component.id=2, service.id=38}
{de.genesys_e.datamodell.lists.IDataLoader}={component.name=de.genesys_e.modem.registry.modemLoader, component.id=3, service.id=39}
{de.genesys_e.datamodell.lists.IDataLoader}={component.name=de.genesys_e.modem.registry.protocolLoader, component.id=4, service.id=40}
{de.genesys_e.datamodell.lists.IListChangeListener}={component.name=de.genesys_e.modem.registry.modemWriter, component.id=5, service.id=41}
{de.genesys_e.datamodell.lists.IListChangeListener}={component.name=de.genesys_e.modem.registry.protocolWriter, component.id=6, service.id=42}
And ls commands say the follwoing:
osgi> ls -c 15
Components in bundle de.genesys_e.modem:
ID Component details
1 Component[
name = de.genesys_e.modem.modemList
activate = activate
modified =
factory = null
autoenable = true
immediate = false
implementation = de.genesys_e.modem.impl.ModemListImpl
properties = null
serviceInterface = [de.genesys_e.datamodell.lists.IList]
references = {
Reference[name = IListChangeListener, interface = de.genesys_e.datamodell.lists.IListChangeListener, policy = dynamic, cardinality = 0..n, target = null, bind = addChangeListener, unbind = removeChangeListener]
located in bundle = de.genesys_e.modem_1.0.0 [15]
Dynamic information :
The component is satisfied
All component references are satisfied
Component configurations :
Configuration properties:
component.name = de.genesys_e.modem.modemList
component.id = 1
objectClass = Object[de.genesys_e.datamodell.lists.IList]
Instances:
2 Component[
name = de.genesys_e.modem.hayesList
activate = activate
modified =
factory = null
autoenable = true
immediate = false
implementation = de.genesys_e.modem.impl.HayesProtocolListImpl
properties = null
references = {
component.name = de.genesys_e.modem.hayesList
component.id = 2
Instances:
osgi> ls -c 16
Components in bundle de.genesys_e.modem.registry:
3 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = false
properties = null
references = null
component.name = de.genesys_e.modem.registry.modemLoader
component.id = 3
objectClass = Object[de.genesys_e.datamodell.lists.IDataLoader]
Instances:
4 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = false
properties = null
references = null
component.name = de.genesys_e.modem.registry.protocolLoader
component.id = 4
Instances:
5 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = false
properties = null
references = null
component.name = de.genesys_e.modem.registry.modemWriter
component.id = 5
objectClass = Object[de.genesys_e.datamodell.lists.IListChangeListener]
Instances:
6 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = false
properties = null
references = null
component.name = de.genesys_e.modem.registry.protocolWriter
component.id = 6
Instances:
For me everything looks pretty good. Do you have an idea?
Bjoern
Re: Declarative Services (DS) do not work as expected [message #513169 is a reply to message #513163] |
Tue, 09 February 2010 07:55 |
Member |
In my last posting there was an error: In the meanwhile I had done some trial and error with the options for loading the service and I removed "immediate=true". With the flag set, status and ls -c look like following:
ACTIVE de.genesys_e.modem.registry_1.0.1.qualifier
{org.eclipse.equinox.internal.util.threadpool.ThreadPoolManager, org.eclipse.equinox.internal.util.threadpool.ThreadPoolFactory}={service.id=40}
{de.genesys_e.datamodell.lists.IDataLoader}={component.name=de.genesys_e.modem.registry.protocolLoader, component.id=4, service.id=41}
{de.genesys_e.datamodell.lists.IListChangeListener}={component.name=de.genesys_e.modem.registry.modemWriter, component.id=5, service.id=42}
{de.genesys_e.datamodell.lists.IListChangeListener}={component.name=de.genesys_e.modem.registry.protocolWriter, component.id=6, service.id=43}
osgi> ls -c 16
3 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = true
properties = null
references = null
component.id = 3
Instances:
org.eclipse.equinox.internal.ds.impl.ComponentInstanceImpl@6c2a78
4 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = true
properties = null
references = null
component.id = 4
Instances:
org.eclipse.equinox.internal.ds.impl.ComponentInstanceImpl@15863e4
5 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = true
properties = null
references = null
component.id = 5
Instances:
org.eclipse.equinox.internal.ds.impl.ComponentInstanceImpl@6270b
6 Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = true
properties = null
references = null
component.id = 6
Instances:
org.eclipse.equinox.internal.ds.impl.ComponentInstanceImpl@1ed54a0
Could it be a sync problem? As far as I know the services are build in not sequentiell way. When I debugged a session I have seen that only modemLoader is registered with modemList and when hayesList is build it registers modemLoader and protocolLoader with hayesList.
Current Time: Wed Apr 17 23:27:58 GMT 2024
Powered by FUDForum. Page generated in 0.02089 seconds
