Home » Eclipse Projects » Rich Client Platform (RCP) » Popup submenu
Popup submenu [message #512792] Sun, 07 February 2010 13:21 Go to next message
I've a problem with creating sub-menu in a pop-up menu. I've created a command extension point, which represents a simply button. In the createPartControl() method of my own View I have a code like this:
MenuManager menuManager = new MenuManager();
Menu menu = menuManager.createContextMenu(viewer.getControl());
viewer.getControl().setMenu(menu);
getSite().registerContextMenu(menuManager, viewer);
Now, it shows pop-up menu with the push button defined in command extension point. It's fine. But there comes my problem. I have a ContributionItem object which represents a Menu object with 3 radio buttons. I would like to insert this object in the menu above, and futhermore in it's own submenu like this:
CommandButton
Zoom menu    > radioButton 1
               radioButton 2
               radioButton 3
How can I do it?
Re: Popup submenu [message #518392 is a reply to message #512792] Wed, 03 March 2010 18:23 Go to previous message
Hi Stranger,
Use the org.eclipse.ui.menus extension point to add a menu into your context
menu. Then add commands to your menu like you did before but take a look at
the style which can be defined it the menus extension point as well. Set the
style to radio.
id="add.item"
point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:org.eclipse.ui.popup.any?after=additions ">
<command
commandId="someorg.someid.someCommand"
icon="icons/anything.gif"
id="someorg.someid.BasicCmdItem"
label="Simple Item"
style="radio"
mnemonic="S">
</command>
</menuContribution>
</extension>
Best Regards,
Wim Jongman
-- Computers make very fast, very accurate mistakes.
(Eclipse Old Skool Quote Service)
this:
> CommandButton
> radioButton 2
> radioButton 3
> How can I do it?
> Thanks
Previous Topic:RCP app installed as an OSGI bundle
Next Topic:Property Sheet View
Current Time: Sun Jul 13 11:40:46 EDT 2025
Powered by FUDForum. Page generated in 0.04468 seconds
