Re: Only few elements are displayed from generated model [message #512495 is a reply to message #512344] |
Fri, 05 February 2010 10:06 |
Timothy Marc Messages: 547 Registered: July 2009 |
Okay, i have narrowed the problem to some degree, since i found out,
that the diagram internal model creates no links to the domain model for
some elements? I don'T know why, because when i create the same nodes
with the diagram the mapping is correct???
Timothy Marc schrieb:
> Hi all,
> there is a strange behavior of my GMF diagram. When i'm drawing a new
> model started from the "New Diagram..." wizard all elements are
> displayed properly in the model, even if i initializ a new one and
> reopen them.
> BUT: I've a workflow implemented that generates the model. However, when
> i try to initialize a diagram from the generated model, only few
> elements are displayed, some are ignored. When i add nodes from the same
> type by using the palette into the diagram, that hides some generated
> nodes, these additional nodes are displayed without any problems after
> reopening or initializing the diagram.
> I really don't know why this happens. Unfortunately, there is no
> expection in the log.
> I need help!!!!
> Thanks in advance Timothy
FUDForum. Page generated in 0.03575 seconds
