Home » Modeling » M2T (model-to-text transformation) » [Acceleo]How to protect user code by signature changes
[Acceleo]How to protect user code by signature changes [message #512228] Thu, 04 February 2010 12:46 Go to next message
Originally posted by: koos.waytostay.com
Hi All,
We have been generation classes using the protected functionally for writing
user code in the operation body which works fine.
If we change the operation name or signature of the operation the old
operation including the user code is removed.
How do we specify the old operation not to be removed?
Koos
Re: [Acceleo]How to protect user code by signature changes [message #512449 is a reply to message #512228] Fri, 05 February 2010 08:23 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------050101080700030409040601
Hi Koos,
Protected code will never be removed through generation, except if :
1) You change the marker of the protected area
2) You've put "@generated" on your class and haven't changed this tag
in-between generations, causing JMerge to remove the old operation
Acceleo generations aren't tied to their target : it doesn't know your
generating code. Method names thus cannot alter the generation process.
However, Eclipse's jdt can alter your code ; for example if you've set
it to automatically remove unused methods.
Laurent Goubet
Obeo
Koos wrote:
> Hi All,
> Koos
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------050101080700030409040601--
Previous Topic:[Xpand] Advices not applied
Next Topic:[Accelo]use of @code-explicit
Current Time: Wed Nov 30 15:13:19 GMT 2022
Powered by FUDForum. Page generated in 0.02587 seconds
