Home » Eclipse Projects » EclipseLink » ORA-03137 error while using eclipselink 1.1.1(ORA-03137 error while using eclipselink 1.1.1)
ORA-03137 error while using eclipselink 1.1.1 [message #512129] Thu, 04 February 2010 04:42 Go to next message
Otto  is currently offline Otto Friend
Has anyone ever seen the following error while using eclipselink 1.1.1?
ORA-03137: TTC protocol internal error : 12333 [4] 195 99] [ ] [ []
Our Oracle version is:
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
PL/SQL Release 11.2.0.1.0 - Production
CORE
11.2.0.1.0 Production
TNS for Linux: Version 11.2.0.1.0 - Production
NLSRTL Version 11.2.0.1.0 - Production
I assume that Oracle's bug 7390077 was also merged from 11.1.7 to 11.2.0.1. Am I wrong?
Thanks in advance,
Otto
Re: ORA-03137 error while using eclipselink 1.1.1 [message #512259 is a reply to message #512129] Thu, 04 February 2010 14:23 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Could you include the full exception stack trace, and indicate what you are doing to get this error?
James : Wiki : Book : Blog : Twitter
Re: ORA-03137 error while using eclipselink 1.1.1 [message #512418 is a reply to message #512259] Fri, 05 February 2010 01:48 Go to previous messageGo to next message
20:48:04,065 INFO [ServerImpl] Starting JBoss (Microcontainer)...
20:48:04,066 INFO [ServerImpl] Release ID: JBoss [The Oracle] 5.1.0.GA (build: SVNTag=JBoss_5_1_0_GA date=200905221634)
20:48:04,067 INFO [ServerImpl] Bootstrap URL: null
20:48:04,067 INFO [ServerImpl] Home Dir: /mnt/OD_DOC/jboss-4.2.2.GA
20:48:04,067 INFO [ServerImpl] Home URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/
20:48:04,067 INFO [ServerImpl] Library URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/lib/
20:48:04,067 INFO [ServerImpl] Patch URL: null
20:48:04,067 INFO [ServerImpl] Common Base URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/common/
20:48:04,067 INFO [ServerImpl] Common Library URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/common/lib/
20:48:04,067 INFO [ServerImpl] Server Name: node2
20:48:04,067 INFO [ServerImpl] Server Base Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server
20:48:04,068 INFO [ServerImpl] Server Base URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/
20:48:04,068 INFO [ServerImpl] Server Config URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/conf/
20:48:04,068 INFO [ServerImpl] Server Home Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2
20:48:04,068 INFO [ServerImpl] Server Home URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/
20:48:04,068 INFO [ServerImpl] Server Data Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/data
20:48:04,068 INFO [ServerImpl] Server Library URL: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/lib/
20:48:04,068 INFO [ServerImpl] Server Log Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/log
20:48:04,068 INFO [ServerImpl] Server Native Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp/native
20:48:04,068 INFO [ServerImpl] Server Temp Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp
20:48:04,068 INFO [ServerImpl] Server Temp Deploy Dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp/deploy
20:48:05,048 INFO [ServerImpl] Starting Microcontainer, bootstrapURL=file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/co nf/bootstrap.xml
20:48:05,841 INFO [VFSCacheFactory] Initializing VFSCache [org.jboss.virtual.plugins.cache.CombinedVFSCache]
20:48:05,843 INFO [VFSCacheFactory] Using VFSCache [CombinedVFSCache[real-cache: null]]
20:48:06,431 INFO [CopyMechanism] VFS temp dir: /mnt/OD_DOC/jboss-4.2.2.GA/server/node2/tmp
20:48:06,454 INFO [ZipEntryContext] VFS force nested jars copy-mode is enabled.
20:48:07,764 INFO [ServerInfo] Java version: 1.6.0_16,Sun Microsystems Inc.
20:48:07,764 INFO [ServerInfo] Java Runtime: Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
20:48:07,765 INFO [ServerInfo] Java VM: Java HotSpot(TM) 64-Bit Server VM 14.2-b01,Sun Microsystems Inc.
20:48:07,765 INFO [ServerInfo] OS-System: Linux 2.6.18-92.1.22.el5,amd64
20:48:07,766 INFO [ServerInfo] VM arguments: -Xms10g -Xmx12g -XX:MaxPermSize=512m -XX:NewRatio=1 -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djava.net.preferIPv4Stack=true -Djboss.messaging.ServerPeerID=2 -Djboss.partition.name=tempOD -Djava.endorsed.dirs=/mnt/OD_DOC/clusterJBoss/lib/endorsed
20:48:07,804 INFO [JMXKernel] Legacy JMX core initialized
20:48:09,784 INFO [ProfileServiceBootstrap] Loading profile: ProfileKey@14cef147[domain=default, server=default, name=node2]
20:48:16,299 INFO [WebService] Using RMI server codebase: http://10.1.1.2:8083/
20:48:21,459 INFO [NativeServerConfig] JBoss Web Services - Stack Native Core
20:48:21,459 INFO [NativeServerConfig] 3.1.2.GA
20:48:22,312 INFO [LogNotificationListener] Adding notification listener for logging mbean "jboss.system:service=Logging,type=Log4jService" to server org.jboss.mx.server.MBeanServerImpl@4969dd64[ defaultDomain='jboss' ]
20:48:52,442 INFO [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@540200319 {vfsfile:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/prof ileservice-secured.jar/}
20:48:52,443 INFO [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@540200319 {vfsfile:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/prof ileservice-secured.jar/}
20:48:52,446 INFO [Ejb3DependenciesDeployer] Encountered deployment AbstractVFSDeploymentContext@109331363 {vfsfile:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/redr ock.ear/redrock-ejb.jar/}
20:48:54,554 INFO [JMXConnectorServerService] JMX Connector server: service:jmx:rmi://10.1.1.2/jndi/rmi://10.1.1.2:1090/jmxconne ctor
20:48:54,670 INFO [MailService] Mail Service bound to java:/Mail
20:48:56,682 INFO [tempOD] Initializing partition tempOD
20:48:56,771 INFO [STDOUT]
GMS: address is 10.1.1.2:54112 (cluster=tempOD)
20:48:56,845 INFO [PlatformMBeanServerRegistration] JBossCache MBeans were successfully registered to the platform mbean server.
20:48:56,895 INFO [STDOUT]
GMS: address is 10.1.1.2:54112 (cluster=tempOD-HAPartitionCache)
20:48:56,934 INFO [tempOD] Number of cluster members: 2
20:48:56,935 INFO [tempOD] Other members: 1
20:48:56,967 INFO [RPCManagerImpl] Received new cluster view: [10.1.1.1:60924|1] [10.1.1.1:60924, 10.1.1.2:54112]
20:48:57,014 INFO [LegacyStateTransferIntegrator] Using version 4096
20:48:57,022 INFO [RPCManagerImpl] Cache local address is 10.1.1.2:54112
20:48:57,023 INFO [RPCManagerImpl] state was retrieved successfully (in 136 milliseconds)
20:48:57,034 INFO [ComponentRegistry] JBoss Cache version: JBossCache 'Cascabel' 3.1.0.GA
20:48:57,036 INFO [tempOD] Fetching serviceState (will wait for 30000 milliseconds):
20:48:57,105 INFO [tempOD] serviceState was retrieved successfully (in 69 milliseconds)
20:48:57,214 INFO [HANamingService] Started HAJNDI bootstrap; jnpPort=1100, backlog=50, bindAddress=/10.1.1.2
20:48:57,229 INFO [DetachedHANamingService$AutomaticDiscovery] Listening on /10.1.1.2:1102, group=230.0.0.4, HA-JNDI address=10.1.1.2:1100
20:48:57,695 INFO [UnifiedInvokerHA] Service name is jboss:service=invoker,type=unifiedha
20:48:58,163 WARN [AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
20:48:58,265 WARN [AnnotationCreator] No ClassLoader provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
20:48:58,345 INFO [TransactionManagerService] JBossTS Transaction Service (JTA version - tag:JBOSSTS_4_6_1_GA) - JBoss Inc.
20:48:58,345 INFO [TransactionManagerService] Setting up property manager MBean and JMX layer
20:48:58,586 INFO [TransactionManagerService] Initializing recovery manager
20:48:58,835 INFO [TransactionManagerService] Recovery manager configured
20:48:58,835 INFO [TransactionManagerService] Binding TransactionManager JNDI Reference
20:48:58,856 INFO [TransactionManagerService] Starting transaction recovery manager
20:48:59,136 INFO [AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/jdk1.6.0_16/jre/lib/amd64/server:/usr/java/jdk1.6. 0_16/jre/lib/amd64:/usr/java/jdk1.6.0_16/jre/../lib/amd64:/u sr/java/packages/lib/amd64:/lib:/usr/lib
20:48:59,173 INFO [Http11Protocol] Initializing Coyote HTTP/1.1 on http-10.1.1.2-8080
20:48:59,186 INFO [StandardService] Starting service jboss.web
20:48:59,188 INFO [StandardEngine] Starting Servlet Engine: JBoss Web/2.1.3.GA
20:48:59,217 INFO [Catalina] Server startup in 44 ms
20:48:59,231 INFO [TomcatDeployment] deploy, ctxPath=/invoker
20:48:59,694 INFO [TomcatDeployment] deploy, ctxPath=/jbossws
20:48:59,797 INFO [RARDeployment] Required license terms exist, view vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/jboss- local-jdbc.rar/META-INF/ra.xml
20:48:59,807 INFO [RARDeployment] Required license terms exist, view vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/jboss- xa-jdbc.rar/META-INF/ra.xml
20:48:59,821 INFO [RARDeployment] Required license terms exist, view vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/jms-ra .rar/META-INF/ra.xml
20:48:59,833 INFO [RARDeployment] Required license terms exist, view vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/mail-r a.rar/META-INF/ra.xml
20:48:59,846 INFO [RARDeployment] Required license terms exist, view vfszip:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/deploy/quartz -ra.rar/META-INF/ra.xml
20:48:59,913 INFO [SimpleThreadPool] Job execution threads will use class loader of thread: main
20:48:59,932 INFO [QuartzScheduler] Quartz Scheduler v.1.5.2 created.
20:48:59,933 INFO [RAMJobStore] RAMJobStore initialized.
20:48:59,933 INFO [StdSchedulerFactory] Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties'
20:48:59,934 INFO [StdSchedulerFactory] Quartz scheduler version: 1.5.2
20:48:59,934 INFO [QuartzScheduler] Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.
20:49:00,083 INFO [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name 'java:DefaultDS'
20:49:00,853 INFO [ServerPeer] JBoss Messaging 1.4.3.GA server [2] started
20:49:00,997 INFO [STDOUT]
GMS: address is 10.1.1.2:54112 (cluster=MessagingPostOffice-CTRL)
20:49:01,063 INFO [GroupMember] org.jboss.messaging.core.impl.postoffice.GroupMember$ControlMembershipListener@6ac7bf5b got new view [10.1.1.1:60924|1] [10.1.1.1:60924, 10.1.1.2:54112], old view is null
20:49:01,063 INFO [GroupMember] I am (10.1.1.2:54112)
20:49:01,063 INFO [GroupMember] New Members : 2 ([10.1.1.1:60924, 10.1.1.2:54112])
20:49:01,063 INFO [GroupMember] All Members : 2 ([10.1.1.1:60924, 10.1.1.2:54112])
20:49:01,178 INFO [STDOUT]
GMS: address is 10.1.1.2:7900 (cluster=MessagingPostOffice-DATA)
20:49:01,313 INFO [QueueService] Queue[/queue/DLQ] started, fullSize=200000, pageSize=2000, downCacheSize=2000
20:49:02,175 INFO [ConnectionFactory] Connector bisocket://10.1.1.2:4457 has leasing enabled, lease period 10000 milliseconds
20:49:02,175 INFO [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@1604dd0d started
20:49:02,178 INFO [TopicService] Topic[/topic/cacheSynchronization] started, fullSize=200000, pageSize=2000, downCacheSize=2000
20:49:02,205 INFO [ConnectionFactory] Connector bisocket://10.1.1.2:4457 has leasing enabled, lease period 10000 milliseconds
20:49:02,206 INFO [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@40819d8c started
20:49:02,208 INFO [QueueService] Queue[/queue/externalEventQueue] started, fullSize=200000, pageSize=2000, downCacheSize=2000
20:49:02,216 INFO [ConnectionFactory] Connector bisocket://10.1.1.2:4457 has leasing enabled, lease period 10000 milliseconds
20:49:02,216 INFO [ConnectionFactory] org.jboss.jms.server.connectionfactory.ConnectionFactory@4b9ac7f5 started
20:49:02,218 INFO [QueueService] Queue[/queue/ExpiryQueue] started, fullSize=200000, pageSize=2000, downCacheSize=2000
20:49:02,219 INFO [TopicService] Topic[/topic/toplinkSynchronization] started, fullSize=200000, pageSize=2000, downCacheSize=2000
20:49:02,221 INFO [QueueService] Queue[/queue/applicationEvent] started, fullSize=200000, pageSize=2000, downCacheSize=2000
20:49:02,224 INFO [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name 'java:JmsXA'
20:49:02,602 INFO [JBossASKernel] Created KernelDeployment for: profileservice-secured.jar
20:49:02,605 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfile Service,service=EJB3
20:49:02,605 INFO [JBossASKernel] with dependencies:
20:49:02,605 INFO [JBossASKernel] and demands:
20:49:02,605 INFO [JBossASKernel] jndi:SecureManagementView/remote-org.jboss.deployers.spi.man agement.ManagementView
20:49:02,605 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:02,605 INFO [JBossASKernel] and supplies:
20:49:02,605 INFO [JBossASKernel] Class:org.jboss.profileservice.spi.ProfileService
20:49:02,605 INFO [JBossASKernel] jndi:SecureProfileService/remote
20:49:02,605 INFO [JBossASKernel] jndi:SecureProfileService/remote-org.jboss.profileservice.sp i.ProfileService
20:49:02,605 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecurePr ofileService,service=EJB3) to KernelDeployment of: profileservice-secured.jar
20:49:02,606 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploym entManager,service=EJB3
20:49:02,606 INFO [JBossASKernel] with dependencies:
20:49:02,606 INFO [JBossASKernel] and demands:
20:49:02,606 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:02,606 INFO [JBossASKernel] and supplies:
20:49:02,606 INFO [JBossASKernel] jndi:SecureDeploymentManager/remote-org.jboss.deployers.spi. management.deploy.DeploymentManager
20:49:02,606 INFO [JBossASKernel] Class:org.jboss.deployers.spi.management.deploy.DeploymentMa nager
20:49:02,607 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureDe ploymentManager,service=EJB3) to KernelDeployment of: profileservice-secured.jar
20:49:02,607 INFO [JBossASKernel] installing bean: jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagem entView,service=EJB3
20:49:02,607 INFO [JBossASKernel] with dependencies:
20:49:02,607 INFO [JBossASKernel] and demands:
20:49:02,607 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:02,607 INFO [JBossASKernel] and supplies:
20:49:02,607 INFO [JBossASKernel] jndi:SecureManagementView/remote-org.jboss.deployers.spi.man agement.ManagementView
20:49:02,607 INFO [JBossASKernel] Class:org.jboss.deployers.spi.management.ManagementView
20:49:02,607 INFO [JBossASKernel] Added bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureMa nagementView,service=EJB3) to KernelDeployment of: profileservice-secured.jar
20:49:02,612 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@21efcaaf {name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureP rofileService,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:02,612 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@296a3a9c {name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureD eploymentManager,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:02,612 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@52231cdb {name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureM anagementView,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:02,683 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploym entManager,service=EJB3
20:49:02,691 INFO [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureDeploymentManager ejbName: SecureDeploymentManager
20:49:02,723 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
SecureDeploymentManager/remote - EJB3.x Default Remote Business Interface
SecureDeploymentManager/remote-org.jboss.deployers.spi.manag ement.deploy.DeploymentManager - EJB3.x Remote Business Interface
20:49:02,772 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagem entView,service=EJB3
20:49:02,772 INFO [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureManagementView ejbName: SecureManagementView
20:49:02,782 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
SecureManagementView/remote - EJB3.x Default Remote Business Interface
SecureManagementView/remote-org.jboss.deployers.spi.manageme nt.ManagementView - EJB3.x Remote Business Interface
20:49:02,820 INFO [SessionSpecContainer] Starting jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfile Service,service=EJB3
20:49:02,821 INFO [EJBContainer] STARTED EJB: org.jboss.profileservice.ejb.SecureProfileServiceBean ejbName: SecureProfileService
20:49:02,830 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
SecureProfileService/remote - EJB3.x Default Remote Business Interface
SecureProfileService/remote-org.jboss.profileservice.spi.Pro fileService - EJB3.x Remote Business Interface
20:49:02,919 INFO [TomcatDeployment] deploy, ctxPath=/
20:49:02,967 INFO [TomcatDeployment] deploy, ctxPath=/jmx-console
20:49:09,315 INFO [JBossASKernel] Created KernelDeployment for: redrock-ejb.jar
20:49:09,315 INFO [JBossASKernel] installing bean: jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=PagedLis tAPIImpl,service=EJB3
20:49:09,315 INFO [JBossASKernel] with dependencies:
20:49:09,315 INFO [JBossASKernel] and demands:
20:49:09,315 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:09,315 INFO [JBossASKernel] and supplies:
20:49:09,315 INFO [JBossASKernel] jndi:redrock/PagedListAPIImpl/local-com.attask.api.PagedList APILocal
20:49:09,315 INFO [JBossASKernel] jndi:redrock/PagedListAPIImpl/remote
20:49:09,316 INFO [JBossASKernel] jndi:redrock/PagedListAPIImpl/remote-com.attask.api.PagedLis tAPIRemote
20:49:09,316 INFO [JBossASKernel] Class:com.attask.api.PagedListAPILocal
20:49:09,316 INFO [JBossASKernel] Class:com.attask.api.PagedListAPIRemote
20:49:09,316 INFO [JBossASKernel] jndi:redrock/PagedListAPIImpl/local
20:49:09,316 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Pag edListAPIImpl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
20:49:09,316 INFO [JBossASKernel] installing bean: jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJAXAPII mpl,service=EJB3
20:49:09,316 INFO [JBossASKernel] with dependencies:
20:49:09,317 INFO [JBossASKernel] and demands:
20:49:09,317 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:09,317 INFO [JBossASKernel] and supplies:
20:49:09,317 INFO [JBossASKernel] jndi:redrock/AJAXAPIImpl/local
20:49:09,317 INFO [JBossASKernel] jndi:redrock/AJAXAPIImpl/local-com.attask.api.APILocal
20:49:09,317 INFO [JBossASKernel] Class:com.attask.api.APILocal
20:49:09,317 INFO [JBossASKernel] jndi:redrock/AJAXAPIImpl/remote
20:49:09,317 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJA XAPIImpl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
20:49:09,317 INFO [JBossASKernel] installing bean: jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=APIImpl, service=EJB3
20:49:09,317 INFO [JBossASKernel] with dependencies:
20:49:09,317 INFO [JBossASKernel] jndi:redrock/APIImpl/remote-com.attask.api.APIRemote
20:49:09,317 INFO [JBossASKernel] Class:com.attask.api.APIRemote
20:49:09,318 INFO [JBossASKernel] Class:com.attask.api.APILocal
20:49:09,318 INFO [JBossASKernel] jndi:redrock/APIImpl/local
20:49:09,318 INFO [JBossASKernel] jndi:redrock/APIImpl/local-com.attask.api.APILocal
20:49:09,318 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=API Impl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
20:49:09,318 INFO [JBossASKernel] installing bean: jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=FlashAPI Impl,service=EJB3
20:49:09,318 INFO [JBossASKernel] with dependencies:
20:49:09,318 INFO [JBossASKernel] and demands:
20:49:09,318 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:09,318 INFO [JBossASKernel] and supplies:
20:49:09,318 INFO [JBossASKernel] jndi:redrock/FlashAPIImpl/remote-com.attask.api.FlashAPIRemo te
20:49:09,318 INFO [JBossASKernel] Class:com.attask.api.FlashAPIRemote
20:49:09,318 INFO [JBossASKernel] Class:com.attask.api.FlashAPILocal
20:49:09,318 INFO [JBossASKernel] jndi:redrock/FlashAPIImpl/local
20:49:09,318 INFO [JBossASKernel] jndi:redrock/FlashAPIImpl/local-com.attask.api.FlashAPILocal
20:49:09,319 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Fla shAPIImpl,service=EJB3) to KernelDeployment of: redrock-ejb.jar
20:49:09,319 INFO [JBossASKernel] installing bean: jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Applicat ionEventMDB,service=EJB3
20:49:09,319 INFO [JBossASKernel] with dependencies:
20:49:09,319 INFO [JBossASKernel] and demands:
20:49:09,319 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:09,319 INFO [JBossASKernel] and supplies:
20:49:09,319 INFO [JBossASKernel] jndi:null
20:49:09,319 INFO [JBossASKernel] Class:javax.jms.MessageListener
20:49:09,319 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=App licationEventMDB,service=EJB3) to KernelDeployment of: redrock-ejb.jar
20:49:09,320 INFO [JBossASKernel] installing bean: jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=CacheSyn chronizationMessageBean,service=EJB3
20:49:09,320 INFO [JBossASKernel] with dependencies:
20:49:09,320 INFO [JBossASKernel] and demands:
20:49:09,320 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService
20:49:09,320 INFO [JBossASKernel] and supplies:
20:49:09,320 INFO [JBossASKernel] jndi:null
20:49:09,320 INFO [JBossASKernel] Class:javax.jms.MessageListener
20:49:09,320 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Cac heSynchronizationMessageBean,service=EJB3) to KernelDeployment of: redrock-ejb.jar
20:49:09,322 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@2a435561 {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AP IImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:09,323 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@7f608105 {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJ AXAPIImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:09,323 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@203d7d5 {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Fl ashAPIImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:09,323 INFO [EJB3EndpointDeployer] Deploy AbstractBeanMetaData@d64bda {name=jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=Pa gedListAPIImpl,service=EJB3_endpoint bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl properties=[container] constructor=null autowireCandidate=true}
20:49:09,375 INFO [SessionSpecContainer] Starting jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=PagedLis tAPIImpl,service=EJB3
20:49:09,376 INFO [EJBContainer] STARTED EJB: com.attask.api.PagedListAPIImpl ejbName: PagedListAPIImpl
20:49:09,405 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
redrock/PagedListAPIImpl/remote - EJB3.x Default Remote Business Interface
redrock/PagedListAPIImpl/remote-com.attask.api.PagedListAPIR emote - EJB3.x Remote Business Interface
redrock/PagedListAPIImpl/local - EJB3.x Default Local Business Interface
redrock/PagedListAPIImpl/local-com.attask.api.PagedListAPILo cal - EJB3.x Local Business Interface
20:49:09,444 INFO [SessionSpecContainer] Starting jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=AJAXAPII mpl,service=EJB3
20:49:09,445 INFO [EJBContainer] STARTED EJB: com.attask.api.AJAXAPIImpl ejbName: AJAXAPIImpl
20:49:09,523 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
redrock/AJAXAPIImpl/local - EJB3.x Default Local Business Interface
redrock/AJAXAPIImpl/local-com.attask.api.APILocal - EJB3.x Local Business Interface
20:49:09,554 INFO [SessionSpecContainer] Starting jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=APIImpl, service=EJB3
20:49:09,555 INFO [EJBContainer] STARTED EJB: com.attask.api.EJBAPIImpl ejbName: APIImpl
20:49:09,641 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
redrock/APIImpl/remote - EJB3.x Default Remote Business Interface
redrock/APIImpl/remote-com.attask.api.APIRemote - EJB3.x Remote Business Interface
redrock/APIImpl/local - EJB3.x Default Local Business Interface
redrock/APIImpl/local-com.attask.api.APILocal - EJB3.x Local Business Interface
20:49:09,672 INFO [SessionSpecContainer] Starting jboss.j2ee:ear=redrock.ear,jar=redrock-ejb.jar,name=FlashAPI Impl,service=EJB3
20:49:09,673 INFO [EJBContainer] STARTED EJB: com.attask.api.FlashAPIImpl ejbName: FlashAPIImpl
20:49:09,789 INFO [JndiSessionRegistrarBase] Binding the following Entries in Global JNDI:
redrock/FlashAPIImpl/remote - EJB3.x Default Remote Business Interface
redrock/FlashAPIImpl/remote-com.attask.api.FlashAPIRemote - EJB3.x Remote Business Interface
redrock/FlashAPIImpl/local - EJB3.x Default Local Business Interface
redrock/FlashAPIImpl/local-com.attask.api.FlashAPILocal - EJB3.x Local Business Interface
20:49:09,829 INFO [EJBContainer] STARTED EJB: com.attask.biz.event.ApplicationEventMessageBean ejbName: ApplicationEventMDB
20:49:09,921 INFO [EJBContainer] STARTED EJB: com.attask.util.cache.CacheSynchronizationMessageBean ejbName: CacheSynchronizationMessageBean
20:49:10,125 INFO [DefaultEndpointRegistry] register: jboss.ws:context=attaskWS,endpoint=APIImpl
20:49:13,910 INFO [WSDLFilePublisher] WSDL published to: file:/mnt/OD_DOC/jboss-4.2.2.GA/server/node2/data/wsdl/redro ck.ear/redrock-ejb.jar/API.wsdl
20:49:26,663 INFO [FiveMinuteTimerEvent] Five Minute Timer Event service created
20:49:26,698 INFO [HourlyTimerEvent] Hourly Timer Event service created
20:49:26,705 INFO [DailyTimerEvent] Daily Timer Event service created
20:49:26,764 INFO [AtTaskStats] AtTaskStats default constructor
20:49:26,815 INFO [RedRockApplication] Starting @task 4.0 R12 redrock/branches/version4r12 (build: 760-27784)...
20:49:27,280 INFO [Environment] ATTASK_DOC_HOME:/mnt/OD_DOC/attaskHome
Re: ORA-03137 error while using eclipselink 1.1.1 [message #512581 is a reply to message #512418] Fri, 05 February 2010 14:46 Go to previous messageGo to next message
This is the latest threadstack
Fri, Feb 5, 2010 6:23 AM
UpTime: 44:47:18
http://app01.prod.ut.us.attask-ondemand.com:8080/attask/test /threadStack.jsp
Free Memory: 5432 MB
Total Memory: 9895 MB
Total Threads: 431
Large Identity Maps
com.attask.model.RKOpTask 29593
com.attask.model.RKAssignment 67500
com.attask.model.RKParameterValue 91899
com.attask.model.RKPredecessor 19213
com.attask.model.RKHour 112755
com.attask.model.RKNote 16155
com.attask.model.RKUserPrefValue 18226
com.attask.model.RKTask 29128
com.attask.model.RKProjectUser 12018
com.attask.model.RKParameterOption 26001
Query For Object Locks
(1310) http-10.1.1.1-8080-34
RUNNABLE
5
java.lang.Thread.dumpThreads(Native Method)
java.lang.Thread.getAllStackTraces(Thread.java:1487)
org.apache.jsp.test.threadStack_jsp._jspService(threadStack_ jsp.java:84)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:70)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:235)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:190)
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:92)
org.jboss.web.tomcat.security.SecurityContextEstablishmentVa lve.process(SecurityContextEstablishmentValve.java:126)
org.jboss.web.tomcat.security.SecurityContextEstablishmentVa lve.invoke(SecurityContextEstablishmentValve.java:70)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
org.jboss.web.tomcat.service.jca.CachedConnectionValve.invok e(CachedConnectionValve.java:158)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:330)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:829)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:598)
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
java.lang.Thread.run(Thread.java:619)
(2) Reference Handler
WAITING
10
java.lang.Object.wait(Native Method)
java.lang.Object.wait(Object.java:485)
java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 116)
(3) Finalizer
WAITING
8
java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:118)
java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:134)
java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 59)
(4) Signal Dispatcher
RUNNABLE
9
(9) DestroyJavaVM
RUNNABLE
5
(12) Timer-0
TIMED_WAITING
5
java.util.TimerThread.mainLoop(Timer.java:509)
java.util.TimerThread.run(Timer.java:462)
(14) Timer-Log4jService
TIMED_WAITING
5
(15) JBoss System Threads(1)-1
RUNNABLE
5
java.net.PlainSocketImpl.socketAccept(Native Method)
java.net.PlainSocketImpl.accept(PlainSocketImpl.java:390)
java.net.ServerSocket.implAccept(ServerSocket.java:453)
java.net.ServerSocket.accept(ServerSocket.java:421)
org.jboss.web.WebServer.run(WebServer.java:320)
org.jboss.util.threadpool.RunnableTaskWrapper.run(RunnableTa skWrapper.java:147)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
(16) RMI TCP Accept-1098
RUNNABLE
5
sun.rmi.transport.tcp.TCPTransport$AcceptLoop.executeAcceptL oop(TCPTransport.java:369)
sun.rmi.transport.tcp.TCPTransport$AcceptLoop.run(TCPTranspo rt.java:341)
(17) RMI Reaper
WAITING
5
sun.rmi.transport.ObjectTable$Reaper.run(ObjectTable.java:33 3)
(18) GC Daemon
TIMED_WAITING
2
sun.misc.GC$Daemon.run(GC.java:100)
(19) JBoss System Threads(1)-2
RUNNABLE
5
org.jnp.server.Main$AcceptHandler.run(Main.java:597)
(20) SubscriptionWatchDog
TIMED_WAITING
5
java.lang.Thread.sleep(Native Method)
org.jboss.ws.extensions.eventing.mgmt.SubscriptionManager$Wa tchDog.run(SubscriptionManager.java:653)
(21) JBoss System Threads(1)-3
WAITING
5
sun.misc.Unsafe.park(Native Method)
java.util.concurrent.locks.LockSupport.park(LockSupport.java :158)
java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.await(AbstractQueuedSynchronizer.java:1925)
java.util.concurrent.LinkedBlockingQueue.take(LinkedBlocking Queue.java:358)
java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolEx ecutor.java:947)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
(23) RMI Scheduler(0)
TIMED_WAITING
5
java.util.concurrent.locks.LockSupport.parkNanos(LockSupport .java:198)
java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.awaitNanos(AbstractQueuedSynchronizer.java:1963)
java.util.concurrent.DelayQueue.take(DelayQueue.java:164)
java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:583)
java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:576)
(24) JBoss System Threads(1)-4
WAITING
5
(25) RMI TCP Accept-1090
RUNNABLE
5
(26) RMI TCP Accept-0
RUNNABLE
5
(27) RMI RenewClean-[10.1.1.1:34154]
TIMED_WAITING
5
sun.rmi.transport.DGCClient$EndpointEntry$RenewCleanThread.r un(DGCClient.java:516)
(29) ServerSocketRefresh
WAITING
5
org.jboss.remoting.transport.socket.SocketServerInvoker$Serv erSocketRefresh.run(SocketServerInvoker.java:844)
(30) AcceptorThread[ServerSocket[addr=/10.1.1.1,port=0,localport= 4457]]
RUNNABLE
5
org.jboss.remoting.transport.socket.SocketServerInvoker.acce pt(SocketServerInvoker.java:1109)
org.jboss.remoting.transport.socket.SocketServerInvoker.acce ss$200(SocketServerInvoker.java:70)
org.jboss.remoting.transport.socket.SocketServerInvoker$Acce ptThread.run(SocketServerInvoker.java:1020)
(31) secondaryServerSocketThread[0]
RUNNABLE
5
org.jboss.remoting.transport.bisocket.BisocketServerInvoker$ SecondaryServerSocketThread$1.run(BisocketServerInvoker.java :1110)
java.security.AccessController.doPrivileged(Native Method)
org.jboss.remoting.transport.bisocket.BisocketServerInvoker$ SecondaryServerSocketThread.run(BisocketServerInvoker.java:1 106)
(32) ServerSocketRefresh
WAITING
5
(33) AcceptorThread[ServerSocket[addr=/10.1.1.1,port=0,localport= 3873]]
RUNNABLE
5
(35) JBoss System Threads(1)-5
WAITING
5
(36) Timer-1,10.1.1.1:47891
TIMED_WAITING
5
(37) FD_SOCK server socket acceptor,null
RUNNABLE
5
org.jgroups.protocols.FD_SOCK$ServerSocketHandler.run(FD_SOC K.java:1022)
(38) DiagnosticsHandler,10.1.1.1:47891
RUNNABLE
5
java.net.PlainDatagramSocketImpl.receive0(Native Method)
java.net.PlainDatagramSocketImpl.receive(PlainDatagramSocket Impl.java:136)
java.net.DatagramSocket.receive(DatagramSocket.java:712)
org.jgroups.protocols.TP$DiagnosticsHandler.run(TP.java:2199 )
(39) UDP ucast,10.1.1.1:47891
RUNNABLE
5
org.jgroups.protocols.UDP$UcastReceiver.run(UDP.java:946)
(40) UDP mcast,10.1.1.1:47891
RUNNABLE
10
org.jgroups.protocols.UDP.run(UDP.java:262)
(41) Timer-2,10.1.1.1:47891
TIMED_WAITING
5
(45) Timer-3,10.1.1.1:47891
TIMED_WAITING
5
(47) Incoming-1,10.1.1.1:47891
WAITING
10
(48) Incoming-2,10.1.1.1:47891
WAITING
10
(49) Timer-4,10.1.1.1:47891
TIMED_WAITING
5
(50) FD_SOCK server socket acceptor,10.1.1.1:47891
RUNNABLE
5
(51) Timer-5,10.1.1.1:47891
TIMED_WAITING
5
(52) Timer-6,10.1.1.1:47891
TIMED_WAITING
5
(53) Incoming-3,10.1.1.1:47891
WAITING
10
(54) Incoming-4,10.1.1.1:47891
WAITING
5
(55) Incoming-5,10.1.1.1:47891
WAITING
10
(56) Timer-7,10.1.1.1:47891
TIMED_WAITING
5
(57) FD_SOCK pinger,tempOD,10.1.1.1:47891
RUNNABLE
5
java.net.SocketInputStream.socketRead0(Native Method)
java.net.SocketInputStream.read(SocketInputStream.java:129)
java.net.SocketInputStream.read(SocketInputStream.java:182)
org.jgroups.protocols.FD_SOCK.run(FD_SOCK.java:425)
(58) Timer-8,10.1.1.1:47891
TIMED_WAITING
5
(60) Timer-9,10.1.1.1:47891
TIMED_WAITING
5
(61) Incoming-6,10.1.1.1:47891
WAITING
10
(62) Incoming-7,10.1.1.1:47891
WAITING
5
(63) Timer-10,10.1.1.1:47891
TIMED_WAITING
5
(64) FD_SOCK pinger,tempOD-HAPartitionCache,10.1.1.1:47891
RUNNABLE
5
(65) Timer-11,10.1.1.1:47891
TIMED_WAITING
5
(66) Timer-12,10.1.1.1:47891
TIMED_WAITING
5
(68) Incoming-8,10.1.1.1:47891
WAITING
5
(69) Incoming-9,10.1.1.1:47891
WAITING
5
(70) Incoming-10,10.1.1.1:47891
WAITING
10
(71) Incoming-11,10.1.1.1:47891
WAITING
5
(72) Incoming-12,10.1.1.1:47891
WAITING
10
(73) Incoming-13,10.1.1.1:47891
WAITING
5
(74) Incoming-14,10.1.1.1:47891
WAITING
5
(75) Incoming-15,10.1.1.1:47891
WAITING
5
(76) Incoming-16,10.1.1.1:47891
WAITING
5
(77) RMI RenewClean-[10.1.1.3:1101]
TIMED_WAITING
5
(78) RMI RenewClean-[10.1.1.2:1101]
TIMED_WAITING
5
(80) Incoming-17,10.1.1.1:47891
WAITING
5
(81) Incoming-18,10.1.1.1:47891
WAITING
10
(82) AsynchKeyChangeHandler Thread
WAITING
5
org.jboss.ha.framework.server.AsynchEventHandler.run(AsynchE ventHandler.java:103)
(83) AsynchViewChangeHandler Thread
WAITING
5
(84) RMI TCP Accept-1101
RUNNABLE
5
(85) Incoming-19,10.1.1.1:47891
WAITING
5
(86) Incoming-20,10.1.1.1:47891
WAITING
10
(89) JBoss System Threads(1)-6
RUNNABLE
5
org.jboss.ha.jndi.DetachedHANamingService$AcceptHandler.run( DetachedHANamingService.java:821)
(90) JBoss System Threads(1)-7
RUNNABLE
5
org.jboss.ha.jndi.DetachedHANamingService$AutomaticDiscovery .run(DetachedHANamingService.java:640)
(91) HDScanner
TIMED_WAITING
5
(92) ServerSocketRefresh
WAITING
5
(93) AcceptorThread[ServerSocket[addr=/10.1.1.1,port=0,localport= 4446]]
RUNNABLE
5
(94) Listener:4713
RUNNABLE
5
com.arjuna.ats.internal.arjuna.recovery.Listener.run(Listene r.java:118)
(96) Thread-9
TIMED_WAITING
5
com.arjuna.ats.internal.arjuna.coordinator.ReaperThread.run( ReaperThread.java:98)
(97) Thread-10
WAITING
5
com.arjuna.ats.arjuna.coordinator.TransactionReaper.waitForC ancellations(TransactionReaper.java:504)
com.arjuna.ats.internal.arjuna.coordinator.ReaperWorkerThrea d.run(ReaperWorkerThread.java:74)
(98) Thread-11
TIMED_WAITING
5
com.arjuna.ats.internal.arjuna.recovery.ExpiredEntryMonitor. run(ExpiredEntryMonitor.java:237)
(99) Thread-12
TIMED_WAITING
5
com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.doB ackoffWait(PeriodicRecovery.java:660)
com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.doW orkInternal(PeriodicRecovery.java:765)
com.arjuna.ats.internal.arjuna.recovery.PeriodicRecovery.run (PeriodicRecovery.java:412)
(101) Listener:4712
RUNNABLE
5
(102) PooledInvokerAcceptor#0-4448
RUNNABLE
5
org.jboss.invocation.pooled.server.PooledInvoker.run(PooledI nvoker.java:262)
(103) RMI TCP Accept-4444
RUNNABLE
5
(104) RMI TCP Accept-4447
RUNNABLE
5
(105) PooledInvokerAcceptor#0-4445
RUNNABLE
5
(106) ContainerBackgroundProcessor[StandardEngine[jboss.web]]
TIMED_WAITING
5
org.apache.catalina.core.ContainerBase$ContainerBackgroundPr ocessor.run(ContainerBase.java:1590)
(107) WorkManager(2)-1
WAITING
5
java.util.concurrent.PriorityBlockingQueue.take(PriorityBloc kingQueue.java:220)
org.jboss.resource.adapter.mail.inflow.NewMsgsWorker.run(New MsgsWorker.java:76)
org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java :205)
org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrap per.java:260)
(108) DefaultQuartzScheduler_Worker-0
TIMED_WAITING
5
org.quartz.simpl.SimpleThreadPool.getNextRunnable(SimpleThre adPool.java:428)
org.quartz.simpl.SimpleThreadPool.access$000(SimpleThreadPoo l.java:47)
org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThr eadPool.java:518)
(109) DefaultQuartzScheduler_Worker-1
TIMED_WAITING
5
(110) DefaultQuartzScheduler_Worker-2
TIMED_WAITING
5
(111) DefaultQuartzScheduler_Worker-3
TIMED_WAITING
5
(112) DefaultQuartzScheduler_Worker-4
TIMED_WAITING
5
(113) DefaultQuartzScheduler_Worker-5
TIMED_WAITING
5
(114) DefaultQuartzScheduler_Worker-6
TIMED_WAITING
5
(115) DefaultQuartzScheduler_Worker-7
TIMED_WAITING
5
(116) DefaultQuartzScheduler_Worker-8
TIMED_WAITING
5
(117) DefaultQuartzScheduler_Worker-9
TIMED_WAITING
5
(118) DefaultQuartzScheduler_QuartzSchedulerThread
TIMED_WAITING
5
org.quartz.core.QuartzSchedulerThread.run(QuartzSchedulerThr ead.java:394)
(119) IdleRemover
TIMED_WAITING
5
org.jboss.resource.connectionmanager.IdleRemover$IdleRemover Runnable.run(IdleRemover.java:167)
(121) Thread-13
TIMED_WAITING
5
org.jboss.messaging.core.impl.memory.SimpleMemoryManager$Mem oryRunnable.run(SimpleMemoryManager.java:126)
(124) Scheduler main thread
WAITING
5
org.jgroups.util.Queue.peek(Queue.java:399)
org.jgroups.util.Scheduler.run(Scheduler.java:76)
(125) FD_SOCK server socket acceptor,10.1.1.1:47891
RUNNABLE
5
(127) FD_SOCK pinger,MessagingPostOffice-CTRL,10.1.1.1:47891
RUNNABLE
5
(129) Timer-1,10.1.1.1:7900
TIMED_WAITING
5
(130) FD_SOCK server socket acceptor,null
RUNNABLE
5
(131) ReceiverThread
RUNNABLE
5
org.jgroups.protocols.MPING.run(MPING.java:365)
(132) DiagnosticsHandler,10.1.1.1:7900
RUNNABLE
5
(133) ConnectionTable.AcceptorThread,10.1.1.1:7900
RUNNABLE
5
org.jgroups.blocks.ConnectionTable.run(ConnectionTable.java: 239)
(134) Timer-2,10.1.1.1:7900
TIMED_WAITING
5
(135) ConnectionTable.Connection.Receiver [10.1.1.1:7900 - 10.1.1.2:40560],10.1.1.1:7900
RUNNABLE
5
java.io.BufferedInputStream.fill(BufferedInputStream.java:21 8)
java.io.BufferedInputStream.read(BufferedInputStream.java:23 7)
java.io.DataInputStream.readInt(DataInputStream.java:370)
org.jgroups.blocks.BasicConnectionTable$Connection.run(Basic ConnectionTable.java:659)
(139) Timer-3,10.1.1.1:7900
TIMED_WAITING
5
(140) Incoming-1,10.1.1.1:7900
WAITING
5
(141) Timer-4,10.1.1.1:7900
TIMED_WAITING
5
(142) FD_SOCK pinger,MessagingPostOffice-DATA,10.1.1.1:7900
RUNNABLE
5
(144) Incoming-2,10.1.1.1:7900
WAITING
5
(145) Incoming-3,10.1.1.1:7900
WAITING
5
(146) Incoming-4,10.1.1.1:7900
WAITING
5
(147) Timer-1
TIMED_WAITING
5
(148) Incoming-5,10.1.1.1:7900
WAITING
5
(149) Incoming-6,10.1.1.1:7900
WAITING
5
(150) Timer-2
TIMED_WAITING
5
(151) control: Socket[addr=/10.1.1.2,port=12850,localport=37398]
Re: ORA-03137 error while using eclipselink 1.1.1 [message #513038 is a reply to message #512129] Mon, 08 February 2010 16:05 Go to previous messageGo to next message
I could not see the exception stack trace to,
in any of the logs you added, can you include just the Java exception stack trace to this exception, it should be a DatabaseException I assume?
Re: ORA-03137 error while using eclipselink 1.1.1 [message #513068 is a reply to message #512129] Mon, 08 February 2010 17:21 Go to previous messageGo to next message
Eric Neilsen is currently offline Eric NeilsenFriend
I work with Otto, here are the logs that we see. Notice that the error we see in the Java Apps appear to be related to an invalid username/password; however when we look at the logs in Oracle it seems to be the
first error that otto displayed. Once we bounce the application server everything returns to normal. From the application server the username and password doesn't change, we are sending the correct username/password to oracle.
LOGS:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.1.1.v20090430-r4097): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
Error Code: 1017
at org.eclipse.persistence.exceptions.DatabaseException.sqlExce ption(DatabaseException.java:323)
at org.eclipse.persistence.exceptions.DatabaseException.sqlExce ption(DatabaseException.java:318)
at org.eclipse.persistence.sessions.DefaultConnector.connect(De faultConnector.java:136)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDa tasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.connectInternal(DatasourceAccessor.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.connectInternal(DatabaseAccessor.java:265)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.connect(DatasourceAccessor.java:407)
at org.eclipse.persistence.sessions.server.ConnectionPool.build Connection(ConnectionPool.java:130)
at org.eclipse.persistence.sessions.server.ReadConnectionPool.a cquireConnection(ReadConnectionPool.java:79)
at org.eclipse.persistence.sessions.server.ServerSession.alloca teReadConnection(ServerSession.java:486)
at org.eclipse.persistence.sessions.server.ServerSession.execut eCall(ServerSession.java:532)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:205)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:191)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.selectOneRow(DatasourceCallQueryMechanism.java:619 )
at org.eclipse.persistence.internal.queries.ExpressionQueryMech anism.selectOneRowFromTable(ExpressionQueryMechanism.java:25 63)
at org.eclipse.persistence.internal.queries.ExpressionQueryMech anism.selectOneRow(ExpressionQueryMechanism.java:2533)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjec tLevelReadQuery(ReadObjectQuery.java:429)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:928)
at org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:664)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:889)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(Read ObjectQuery.java:397)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute InUnitOfWork(ObjectLevelReadQuery.java:952)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2755)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1181)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1165)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1125)
at com.attask.biz.ObjectQuery.getObject(ObjectQuery.java:162)
at com.attask.biz.ObjectQuery.getObject(ObjectQuery.java:99)
at com.attask.biz.ObjectQuery.getRegisteredObject(ObjectQuery.j ava:50)
at com.attask.biz.LoginMethods.performExternalLoginAndSynch(Log inMethods.java:792)
at com.attask.biz.LoginMethods.login(LoginMethods.java:316)
at com.attask.biz.LoginMethods.login(LoginMethods.java:295)
at com.attask.biz.LoginMethods.loginFromAPI(LoginMethods.java:2 25)
at com.attask.api.APIImpl.login(APIImpl.java:78)
at sun.reflect.GeneratedMethodAccessor676.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(Method Invocation.java:122)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodIn vocation.java:111)
at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBC ontainerInvocationWrapper.java:69)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor $InvocationContext.proceed(InvocationContextInterceptor.java :138)
at com.attask.aop.APIInterceptor.ejbInterceptor(APIInterceptor. java:48)
at sun.reflect.GeneratedMethodAccessor437.invoke(Unknown Source)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.i nvoke(EJB3InterceptorInterceptor.java:83)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.i nvoke(EJB3InterceptorInterceptor.java:70)
at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBC ontainerInvocationWrapper.java:59)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke( InterceptorSequencer.java:73)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundI nvoke(InterceptorSequencer.java:59)
at sun.reflect.GeneratedMethodAccessor425.invoke(Unknown Source)
at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointA dvice.java:174)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodIn vocation.java:102)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor .fillMethod(InvocationContextInterceptor.java:72)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.Invocat ionContextInterceptor_z_fillMethod_916938399.invoke(Invocati onContextInterceptor_z_fillMethod_916938399.java)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor .setup(InvocationContextInterceptor.java:88)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.Invocat ionContextInterceptor_z_setup_916938399.invoke(InvocationCon textInterceptor_z_setup_916938399.java)
at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor .invoke(CachedConnectionInterceptor.java:62)
at org.jboss.ejb3.entity.TransactionScopedEntityManagerIntercep tor.invoke(TransactionScopedEntityManagerInterceptor.java:56 )
at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOp erationsInterceptor.java:47)
at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.jav a:42)
at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke (StatelessInstanceInterceptor.java:68)
at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79 )
at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterce ptor.java:190)
at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropa gationInterceptor.java:76)
at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invo ke(Ejb3AuthenticationInterceptorv2.java:186)
at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagati onInterceptor.java:41)
at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(Bloc kContainerShutdownInterceptor.java:67)
at org.jboss.aspects.currentinvocation.CurrentInvocationInterce ptor.invoke(CurrentInvocationInterceptor.java:67)
at org.jboss.ejb3.stateless.StatelessContainer.localInvoke(Stat elessContainer.java:306)
at org.jboss.ejb3.stateless.StatelessContainer.invokeEndpoint(S tatelessContainer.java:662)
at org.jboss.wsf.container.jboss50.invocation.InvocationHandler EJB3.invoke(InvocationHandlerEJB3.java:96)
at org.jboss.ws.core.server.ServiceEndpointInvoker.invoke(Servi ceEndpointInvoker.java:222)
at org.jboss.wsf.stack.jbws.RequestHandlerImpl.processRequest(R equestHandlerImpl.java:474)
at org.jboss.wsf.stack.jbws.RequestHandlerImpl.handleRequest(Re questHandlerImpl.java:295)
at org.jboss.wsf.stack.jbws.RequestHandlerImpl.doPost(RequestHa ndlerImpl.java:205)
at org.jboss.wsf.stack.jbws.RequestHandlerImpl.handleHttpReques t(RequestHandlerImpl.java:131)
at org.jboss.wsf.common.servlet.AbstractEndpointServlet.service (AbstractEndpointServlet.java:85)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:190)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentVa lve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentVa lve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invok e(CachedConnectionValve.java:158)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
at oracle.jdbc.driver.SQLStateMapping.newSQLException(SQLStateM apping.java:70)
at oracle.jdbc.driver.DatabaseError.newSQLException(DatabaseErr or.java:131)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseE rror.java:204)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:455 )
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:406 )
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399 )
at oracle.jdbc.driver.T4CTTIoauthenticate.receiveOauth(T4CTTIoa uthenticate.java:799)
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:36 8)
at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:508)
at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:203)
at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDrive rExtension.java:33)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:51 0)
at java.sql.DriverManager.getConnection(DriverManager.java:582)
at java.sql.DriverManager.getConnection(DriverManager.java:154)
at org.eclipse.persistence.sessions.DefaultConnector.connect(De faultConnector.java:97)
... 113 more
Re: ORA-03137 error while using eclipselink 1.1.1 [message #517919 is a reply to message #513068] Tue, 02 March 2010 14:28 Go to previous message
Looks like your user/password are wrong.
How have you configured your ServerSession?
Previous Topic:eclipselink problem with commons-dbcp
Next Topic:Set JPA entities at runtime
Current Time: Tue Apr 16 09:40:24 GMT 2024
Powered by FUDForum. Page generated in 0.80696 seconds
