Re: Semantic Highlighting Job error [message #542190 is a reply to message #511949] |
Thu, 24 June 2010 08:30   |
Maarten Kossen Messages: 4 Registered: June 2010 |
I'm having the exact same problem. It's really bugging me, because Helios is unworkable for me.
The project I'm using is around 310MB in size and it is all PHP. There's not much needed to reproduce this. Just start eclipse and it'll go nuts (given that you already have a project).
I do think it may have something to do with the size of the project, as it doesn't have any trouble with smaller projects.
[Updated on: Thu, 24 June 2010 12:05] Report message to a moderator
Re: Semantic Highlighting Job error [message #544260 is a reply to message #544243] |
Fri, 02 July 2010 07:52   |
NoobieRoobie Messages: 17 Registered: June 2010 |
Maarten Kossen wrote on Fri, 02 July 2010 02:56 | May I ask what you mean with 'all-in-one package'?
Sure, it basically is a brand new install in its own folder by extracting a zip file.
You find multiple on this page:
http://www.eclipse.org/pdt/downloads/
The are listed below the "Eclipse PDT 2.2.0 All In Ones / Eclipse PHP Package" headline.
It might be adviseable to use a new workspace as well and to not import older projects, because even I do not get the errors any longer, PHP Search and Open Declarations (F3) does not currently work for me (even on brand new projects).
Update / Warning: I had problems re-using the already existing workspace with the new install. Projects in that workspace had problems running properly with the new standalone version.
[Updated on: Fri, 02 July 2010 12:23] Report message to a moderator
FUDForum. Page generated in 0.02575 seconds
