RE: [buckminster-dev] junit tests in headless buckminster [message #511327] |
Mon, 01 February 2010 04:56 |
Originally posted by: dieter.cailliau.barco.com
------_=_NextPart_001_01CAA324.868EE6BB
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Note that this link is broken =
'org.eclipse.buckminster.site.eclipse_1.1.350.r10878.zip.' =
http://www.eclipse.org/downloads/download.php?file=3D/tools/ buckminster/a=
rchivedsites-3.5/org.eclipse.buckminster.site.eclipse.headle ss_1.1.350.r1=
0878.zip
on this site http://www.eclipse.org/buckminster/downloads.html
-----Original Message-----
From: buckminster-dev-bounces@eclipse.org on behalf of Achim Demelt=20
Sent: Tue 26/01/2010 8:40
To: Buckminster developer discussions
Subject: Re: [buckminster-dev] junit tests in headless buckminster
=20
Dieter,
You can find download information under=20
http://www.eclipse.org/buckminster/downloads.html or you=20
can browse the files on one of the eclipse.org mirrors,=20
e.g.=20
http://ftp-stud.fht-esslingen.de/pub/Mirrors/eclipse/tools/b uckminster/
Everything you need should be contained in the latest=20
(headless) archived site for eclipse 3.6. You also need to=20
use the latest p2 director to install buckminster. You can=20
find the archive in that download area as well.
Achim
On Mon, 25 Jan 2010 18:30:14 +0100
"Cailliau, Dieter" <dieter.cailliau@barco.com> wrote:
I need an archived update site (containing the
org.eclipse.buckminster.junit.feature.feature.group ? )
This is not mentioned on this page:
so i don't know where to find it.
=20
=20
Achim Demelt
Sent: Mon 25/01/2010 18:14
buckminster
=20
Hi Dieter,
=20
The Buckminster JUnit and EclEmma code has been=20
committed
to the Buckminster
repository at eclipse.org. You can find the features on
our regular p2 sites,
i.e. the ones you're using anyway to install (headless)
Buckminster.
=20
Achim
=20
On Monday 25 January 2010 18:03:26 Cailliau, Dieter
wrote:
> I was wondering how to integrate my junit tests in the=20
>headless build
> procedure. Is this still up to date:
> http://code.google.com/p/buckminster-contrib/wiki/Buckminste rJUnit=20
>? If i
> do so, it stops with a NullPointerException:
>=20
> x@x:/usr/local/hbm$ ./buckminster -data /tmp/x1 -L DEBUG=20
>-consoleLog junit
> -l /plugins/com.x.util/src-test.launch !SESSION=20
>2010-01-25 19:50:18.752
> -----------------------------------------------=20
>eclipse.buildId=3Dunknown
> java.version=3D1.5.0_14
> java.vendor=3DSun Microsystems Inc.
> BootLoader constants: OS=3Dlinux, ARCH=3Dx86, WS=3Dgtk,=20
>NL=3Den_US
> Framework arguments: -L DEBUG junit -l=20
> Command-line arguments: -data /tmp/x1 -L DEBUG=20
>-consoleLog junit -l
>=20
> !ENTRY org.eclipse.buckminster.runtime 0 293 2010-01-25=20
>19:50:22.546
> !MESSAGE junit '-l' '/plugins/com.x.util/src-test.launch'
>=20
>=20
> DISCLAIMER:
> Unless indicated otherwise, the information contained in=20
>this message is
> privileged and confidential, and is intended only for=20
>the use of the
> addressee(s) named above and others who have been=20
>specifically authorized
> to receive it. If you are not the intended recipient,=20
>you are hereby
> notified that any dissemination, distribution or copying=20
>of this message
> and/or attachments is strictly prohibited. The company=20
>accepts no
> liability for any damage caused by any virus transmitted=20
>by this email.
> Furthermore, the company does not warrant a proper and=20
>complete
> transmission of this information, nor does it accept=20
>liability for any
> delays. If you have received this message in error,=20
>please contact the
> sender and delete the message. Thank you.
>=20
_______________________________________________
buckminster-dev mailing list
buckminster-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
=20
=20
=20
DISCLAIMER:
this message is privileged and confidential, and is
intended only for the use of the addressee(s) named above
and others who have been specifically authorized to
receive it. If you are not the intended recipient, you are
hereby notified that any dissemination, distribution or
copying of this message and/or attachments is strictly
prohibited. The company accepts no liability for any
damage caused by any virus transmitted by this email.
complete transmission of this information, nor does it
accept liability for any delays. If you have received this
message in error, please contact the sender and delete the
message. Thank you.
DISCLAIMER:
Unless indicated otherwise, the information contained in this message is =
privileged and confidential, and is intended only for the use of the =
addressee(s) named above and others who have been specifically =
authorized to receive it. If you are not the intended recipient, you are =
hereby notified that any dissemination, distribution or copying of this =
message and/or attachments is strictly prohibited. The company accepts =
no liability for any damage caused by any virus transmitted by this =
email. Furthermore, the company does not warrant a proper and complete =
transmission of this information, nor does it accept liability for any =
delays. If you have received this message in error, please contact the =
Content-Type: application/ms-tnef;
name="winmail.dat"
eJ8+IhUJAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcA GAAAAElQTS5NaWNy
b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEgAEAOgAAAFJFOiBb YnVja21pbnN0ZXIt
ZGV2XSBqdW5pdCB0ZXN0cyBpbiBoZWFkbGVzcyBidWNrbWluc3RlcgCAFQEF gAMADgAAANoHAgAB
AAoANQAUAAEAOAEBIIADAA4AAADaBwIAAQAKADYAFAABADkBAQmAAQAhAAAA Q0JBOEMxOUVFRjY5
QUM0Qjk2RkQ1MUU3OTI5RTU4QUYAnAcBA5AGAIASAAA5AAAAAwAmAAAAAAAD ADYAAAAAAEAAOQBd
AsliJKPKAR4APQABAAAABQAAAFJFOiAAAAAAAgFHAAEAAAAzAAAAYz1CRTth PVJUVDtwPUJBUkNP
O2w9S05ETUVYMDEtMTAwMjAxMDk1NDIwWi0yMDU5MDkAAB4ASQABAAAAOgAA AFJlOiBbYnVja21p
bnN0ZXItZGV2XSBqdW5pdCB0ZXN0cyBpbiBoZWFkbGVzcyBidWNrbWluc3Rl cgAAAEAATgAAoTXm
Wp7KAR4AWgABAAAAJAAAAGJ1Y2ttaW5zdGVyLWRldi1ib3VuY2VzQGVjbGlw c2Uub3JnAAIBWwAB
AAAAZQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAGJ1Y2ttaW5zdGVyLWRl di1ib3VuY2VzQGVj
bGlwc2Uub3JnAFNNVFAAYnVja21pbnN0ZXItZGV2LWJvdW5jZXNAZWNsaXBz ZS5vcmcAAAAAAgFc
AAEAAAApAAAAU01UUDpCVUNLTUlOU1RFUi1ERVYtQk9VTkNFU0BFQ0xJUFNF Lk9SRwAAAAAeAF0A
AQAAAA4AAABBY2hpbSBEZW1lbHQgAAAAAgFeAAEAAABCAAAAAAAAAIErH6S+ oxAZnW4A3QEPVAIA
AAAAQWNoaW0gRGVtZWx0IABTTVRQAGEuZGVtZWx0QGV4eGNlbGxlbnQuZGUA AAACAV8AAQAAABwA
AABTTVRQOkEuREVNRUxUQEVYWENFTExFTlQuREUAHgBmAAEAAAAFAAAAU01U UAAAAAAeAGcAAQAA
ACQAAABidWNrbWluc3Rlci1kZXYtYm91bmNlc0BlY2xpcHNlLm9yZwAeAGgA AQAAAAUAAABTTVRQ
AAAAAB4AaQABAAAAFwAAAGEuZGVtZWx0QGV4eGNlbGxlbnQuZGUAAB4AcAAB AAAANgAAAFtidWNr
bWluc3Rlci1kZXZdIGp1bml0IHRlc3RzIGluIGhlYWRsZXNzIGJ1Y2ttaW5z dGVyAAAAAgFxAAEA
AAAbAAAAAcqeWunzuzAkPF0GQqa1Ik8yp6UALwEyXjREAB4AdAABAAAAIgAA AEJ1Y2ttaW5zdGVy
IGRldmVsb3BlciBkaXNjdXNzaW9ucwAAAB4AGgwBAAAAEQAAAENhaWxsaWF1 LCBEaWV0ZXIAAAAA
HgAdDgEAAAA2AAAAW2J1Y2ttaW5zdGVyLWRldl0ganVuaXQgdGVzdHMgaW4g aGVhZGxlc3MgYnVj
a21pbnN0ZXIAAAACAQkQAQAAACIKAAAeCgAApxYAAExaRnUSWw+eAwAKAHJj cGcxMjXiMgNDdGV4
BUEBAwH3/wqAAqQD5AcTAoAP8wBQBFY/CFUHshElDlEDAQIAY2jhCsBzZXQy BgAGwxEl9jMERhO3
MBIsETMI7wn3tjsYHw4wNREiDGBjAFBzCwkBZDM2FlALpgewb3kOsCB0E+AF QB1ABAAgUmwLgGsg
HbFiA2BryQnwICcFsGcuBZAd4JJwFBAuYhrQa20LgHJzDrByLgCQDrAfFl8E MS4hMDM1MC5ygDEw
ODc4LnoFICAuJyAgaAJAcDo4Ly93IwAfFx7hL2SIb3duF7BhZHMj90AucGhw P2YDEGVwPS90bwbw
JIAfqS8zCsAT0Gl2CYAgYnMtcDMuNS8e7x//KKFo/mUkYCWQBBAhLwUgCqIK gP8CIB2EIGIijyOV
JjokBypQXHRtGAAsIzBaLTFyTz0FEGcLgAdABdAqsWFn1mUxcywURgNhOh5Q KOgSLQEAdi0G4HVu
Y5UHkEAjSSAscWJlE+AsbGY2ADaQQScRbSD0RGUHgGwFQSwjBmACMAUzsFQK UCAyNi8wDDEvAdAh
wCA4OjRTAUAsI1RvM7BCKOggMzSRN3BvcDrSBABjdRUEEGkCIHM3tXVialMF kDhBUmUzsFsz3V28
IGo08CBwHTAHkHQEIL8LgC0wKnUzyiwUN6VECJCVICEsMFpZCGAgYwOReSVw bmQ68CQVP1ECEHL1
AMB0PBEgNPAEgTelLU/vLl8vbTYABcB5QuEsFEMS/R5hdxQQHTEdICVyBCAs cb8CIB0gNrFKUjVa
KRByA2B9FAAsN6UosCgwRUwBgHCqLSlAdSUQZkWwLSqxkx3hMqBuLgEAL3A8 wHQvTUykLyhVJc8m
0C7lMFpFJ0ByeR2RT8BI89dLMAmALOBoCGBsQ4A2QP9DAAIhC3FUgT9hSlIL YD8C5TelKCpmKSAm
9izkRFF1S8YgJ9A2TbBC0gdAc35vVFRRgDelO+BKNFZlcP8UQDugGCA9AAWx WrEpIgdA/wMgKNpZ
w0MSLBRDU0pSJvV/VeQdYUOnCsAqcFfQBCB39TdwbFKrQypgBJBM8EDV6zbU MFpPA6BNAiBNAA4w
LCBKA5E5EzE5YDMw4DoxNCArOSE5lSJw3CJDC3BdcAcwdU0AQaTYIiA8O6BB wi5DEGfUtEBiJvFv
aUADcD5h4OsDYA6wOmN2SVRUA5FX59h1cGRWcSzkKFVVU+L/SlEsFSgvKTQ+ o08gKnBO8A8YIHCH
CcAIYHAgPyDaKWN2VB2iHbFuHQBMgP84ITwRVIEsdgqwMqBq5UW/L0bPL29j lFoxaUORbiftBUBr
cyAH4HcqYBggWqL/Q1NwYWN2et4xfzKPM580r/01v2YsFDbqY3Y4FGUxZXH/ ONdmQWagcic6Hzsv
PDaDMX88zz3fPu8EECwUQC97OEg/ePBBq3s4cqAdIIW6SlWXilIAcEOARW8A RW0AwP9VQQEALTBh
wTZAHqFJRQNw/ykQAkAJgCwUWrFKUoW5Y3bZGCBwbyBhBbB5V9AFQP8jSV5Y X1dwlUrSLBUIcJUx
vmdU4ArBXDEnc2NnaW7g302wSlJLIQQgSQEnefE74ONT4gBweXdhldBc+Vc4 /ywUhbl6z2MPZBd7
OGUEbMA7ldBlhHUKwKMxZgUwM/46OLASIGfNLBRqmmpwa3D/nMBh0aLxBnFT 8VTAB+Bc8/cOsAnA
bNJtldCKPUpSpqV/P5kDEJM1anBcIANgf/Bk/3DSa2AEICykRKBdcXHBWrG/ bMKmly02kXJNkFGQ
ZyWQ92oyUDAmKi1VUgUQUGAD8HhraS+FuZBUpqVx8En/NpAAoKv2JAB4sU0A imEpQHeGwGHRIHBo
V9AHsFTgbMRQb6iSckV4f/AFMMc8EaaXpqZ4QHh1cDvgBybQF7BDEGwvaGJt +CQgLiYqfEBswWGg
UXBSbbCweDF8QEw3MEV4QlVHqoaxglowJZBM97AgiiSr5y0DIFAwCkB80UMk gGpBLnguda2xL+m4
8GMtipIuC2B/0bYAACFTRVNTSU9OK6qGORItOOAtZYExOe46IYBmkCIANw5B vbfDrx/Ev8WKqoZu
+KuxSWQ9D3/QeXKYpWpwamF2YRYuU4E8Aj0q8DUuMN8q4ITlyOdDcAWwPYhA ZRFTDeADYHN5KUFt
BCBJ13/gUqVqcEJRkHS9ECRgLxKBvKIBkAIwc36QT1MSPR3hdXhNAEFSQ6BI PXg4Nk0AV87QCGd0
a00GPk5MPbEJ8F9VU6amflBhB4D9p4ByHhAKwJlwc2LOkbuI34o0vjGmpb5v v39opqYIUP+RMUNw
vjBVodKMus+737zqP74hq+fU79X/1wempiFFcE5UUllIwW7fKUNyF3/QRKAH gCAWUDI5M09l48Hl
pqXCVDIyJ+A0ijbfh03AwUFHRYolNie+MCJgJ9zf3e9oJ3/Ih+Xf5u/n/8jH C2BPwC4Ptk88Ebee
pqZESVND6ExBSeVAUqaXkGA/019DYQ3gVnFz4UpRcgPxZf9NAEpSRDpVW6al HZMHgX1i/x4hq+kn
MCWBfYBrwkOAVVH/JXABAHOBB0BNAJCycsKooftFAXPibJXQWML055wSS0ab q+ckYGSYURQQZShX
sf988AeAYVEG4GAxkLLyY2HRT1TAkbFgMZIJPnOG0GN/BpDx8V1wldHq8FTA BRB675MmrEFasVyB
ZWAjcHCz8v9JAmFxcxPzFPk1XIHg4AiQzw+g0GcCxnnSYnmr53Mh///hWoId UpyRhwIUECkRRJM/
TQCHEbHC6vFK8s3ycHn/U+KmpUtj9Xj7iENwKAGV4f/0QBPQ0tMeIgkSiJD5 waxx/R2gYiBxJRCP
Q2pBGxAH0f+mpQ0AtxJzAqvnZ/EOoB3g/nT51AfD0hD14mlQ+uFVAf+V0QfR 9wDh8K0xqODbMJLk
/6qGE3EdkzdQZ8HM19HgcND98nJt+gDy5Q9WJABKwXMi/6dATLDOYbYRrHGG 0pCypqX/D1IlkG0w
ARgUVDvzS1T44/9EV00AcyCGURiCkIIQU6qG/xF/tEg3cJzQL/AChv6TAdX/ X4L1ev8Q/hBMwdBn
GvFhwP9VNYiQ+0sooEUDkLIhMWhx/5PD9aUO8s5g0nBJAczXZyb+XyovKz8s Cmcmfr1zUGfB/1Pi
zvBSUC0ff0SAKmcmdTL/0xB1gH9xddsWAtfBuRAJAf9EMrDLf3F63zYd8C9n gPFf//Jv839Vw5NF
9Wz2z/ff9ib/+R+Tw/ro/A/9Fmck/a/+tv//rwC0WqFnJAHfAu8D/wV1/3TV BgMG3wfvCP2SVgoU
Cu3/DF8NbGckDl8PZRBIEW8GRf8SnxOvFLMVf34iFv8YDxkf//iwklca8xvP HN8d6kO1HsT/VW8h
LyI/ZyQjX5nAJP8mj/cnk2WrKG8KLA9snyxPi+v/Lk9ujzCPdOcyTzNfNG81 dQV71H13YAAAHgA1
EAEAAAA+AAAAPDAyOEFFOEE3QzA0RUUxNDg4OUJFOTlFNTQ1MEJFMzJEMDYx ODEzRUVAa25kbWV4
MDEuYmFyY28uY29tPgAAAB4AORABAAAA5AAAADwwMjhBRThBN0MwNEVFMTQ4 ODlCRTk5RTU0NTBC
RTMyRDA2MTgxM0Q1QGtuZG1leDAxLmJhcmNvLmNvbT48YTE0MTE1ODljN2Ew Y2M5OThhNzYwM2Vm
ZWJkYTE5ODZmMTNkNDNhMEBsb2NhbGhvc3Q+PDAyOEFFOEE3QzA0RUUxNDg4 OUJFOTlFNTQ1MEJF
MzJEMDYxODEzRDZAa25kbWV4MDEuYmFyY28uY29tPiA8ZmYxMTRiZTQ1Y2Yy NDI3NjcyNmE3NjA2
ZmUzMDNjNjBmNWI0ODIyNUBsb2NhbGhvc3Q+AB4ARxABAAAADwAAAG1lc3Nh Z2UvcmZjODIyAAAL
APIQAQAAAB8A8xABAAAAgAAAAFIARQAlADMAQQAgAFsAYgB1AGMAawBtAGkA bgBzAHQAZQByAC0A
ZABlAHYAXQAgAGoAdQBuAGkAdAAgAHQAZQBzAHQAcwAgAGkAbgAgAGgAZQBh AGQAbABlAHMAcwAg
AGIAdQBjAGsAbQBpAG4AcwB0AGUAcgAuAEUATQBMAAAACwD2EAAAAABAAAcw /5/GYiSjygFAAAgw
d6uThiSjygEDAN4/r28AAAMA8T8JBAAAHgD4PwEAAAARAAAAQ2FpbGxpYXUs IERpZXRlcgAAAAAC
Afk/AQAAAEQAAAAAAAAA3KdAyMBCEBq0uQgAKy/hggEAAAAAAAAAL089QkFS Q08vT1U9QUcwMDEv
Q049UkVDSVBJRU5UUy9DTj1ESUVDAB4A+j8BAAAAFQAAAFN5c3RlbSBBZG1p bmlzdHJhdG9yAAAA
AAIB+z8BAAAAHgAAAAAAAADcp0DIwEIQGrS5CAArL+GCAQAAAAAAAAAuAAAA AwD9P+QEAAADABlA
AAAAAAMAGkAAAAAAAwAdQAAAAAADAB5AAAAAAB4AMEABAAAABQAAAERJRUMA AAAAHgAxQAEAAAAF
AAAARElFQwAAAAAeADJAAQAAACQAAABidWNrbWluc3Rlci1kZXYtYm91bmNl c0BlY2xpcHNlLm9y
ZwAeADNAAQAAABcAAABhLmRlbWVsdEBleHhjZWxsZW50LmRlAAAeADhAAQAA AAUAAABESUVDAAAA
AB4AOUABAAAAAgAAAC4AAAADAHZA/////wsAKQAAAAAACwAjAAAAAAADAAYQ kFzqqwMABxAZDwAA
AwAQEAAAAAADABEQAAAAAB4ACBABAAAAZQAAAE5PVEVUSEFUVEhJU0xJTktJ U0JST0tFTk9SR0VD
TElQU0VCVUNLTUlOU1RFUlNJVEVFQ0xJUFNFMTEzNTBSMTA4NzhaSVBIVFRQ Oi8vV1dXRUNMSVBT
RU9SRy9ET1dOTE9BRFMAAAAAAgF/AAEAAAA+AAAAPDAyOEFFOEE3QzA0RUUx NDg4OUJFOTlFNTQ1
MEJFMzJEMDYxODEzRUVAa25kbWV4MDEuYmFyY28uY29tPgAAAG37
------_=_NextPart_001_01CAA324.868EE6BB--
FUDForum. Page generated in 0.03193 seconds
