Home » Eclipse Projects » Eclipse Platform » popup menu: dynamic objectContribution(RFC: provide dynamic objectContribution as dynamic menuContribution)
popup menu: dynamic objectContribution [message #511184] Sat, 30 January 2010 15:16 Go to next message
I need to have a dynamic popup menu objectContribution like exits a dynamic menuContribution. Can someone explain me if this is possible in M3.5 and how to do it??
Otherwise, I would suggest to make an RFE for this kind of dynamic menu that needs to know on which object there were activated...
Thanks for you help
zosrothko
Re: popup menu: dynamic objectContribution [message #512009 is a reply to message #511184] Wed, 03 February 2010 11:07 Go to previous messageGo to next message
There is no way to use a pulldown action in an object contribution.
But you can use menuContribution to supply a dynamic
org.eclipse.ui.actions.CompoundContributionItem to a popup. You can use
visibleWhen to restrict it similar to objectClass.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: popup menu: dynamic objectContribution [message #512077 is a reply to message #512009] Wed, 03 February 2010 15:04 Go to previous messageGo to next message
My popup dynamic contributionItem values are depending on the value of the initially selection object, and since this object is never passed to the menuContribution, I can't implement the dynamic items of the popup...
for example, having 2 objects A & B in a TreeViewer, the popup submenu should display A1, A2 when A is selected and B1, B2, B3, B4 when B is selected...
Did I misunderstand something from your answer??
TIA for your reply.
zosrothko
Re: popup menu: dynamic objectContribution [message #512567 is a reply to message #512077] Fri, 05 February 2010 09:09 Go to previous messageGo to next message
While not elegant, you can implement
org.eclipse.ui.menus.IWorkbenchContribution which will give you a
service locator. If you want to know what the selection for your popup,
is, use:
evalService = (IEvaluationService) locator
.getService(IEvaluationService.class);
Object selection = evalService.getCurrentState()
.getVariable(ISources.ACTIVE_MENU_SELECTION_NAME);
PW
Paul Webster
Re: popup menu: dynamic objectContribution [message #512749 is a reply to message #512567] Sun, 07 February 2010 04:35 Go to previous messageGo to next message
Hi Paul
Thank for your help.. it works as expected...
Anyway, I am wondering why do you consider this solution as non elegant?? Also, I am wondering why the selected object is not forwarded to menuContribution in all case??
Is this something missing from the spec, or another reason?
zos
Re: popup menu: dynamic objectContribution [message #513235 is a reply to message #512749] Tue, 09 February 2010 08:15 Go to previous message
> elegant??
It's technically correct, just a little verbose, that's all.
Because the menu contribution is normally a View component (not model or
control), and most view components don't have code associated with them
at all. But they can reach out to the "model" or in your case
application state.
PW
Paul Webster
Previous Topic:worspace indication
Next Topic:Editor association seems broken in Helios
Current Time: Sun May 18 22:28:47 EDT 2025
Powered by FUDForum. Page generated in 0.02977 seconds
