Home » Eclipse Projects » Rich Client Platform (RCP) » How to make perspective invisible for user
How to make perspective invisible for user [message #511024] Fri, 29 January 2010 15:12 Go to next message
Miłosz is currently offline MiłoszFriend
I have problem with hiding perspective in Eclipse RCP Application. I want to make perspective invisible for user (dynamically). It means that perspective should be not visible in 'Perspectives' toolbar and 'Open Perspective' dialog (user can't open perspective). I have found how to hide perspective:
IPerspectiveDescriptor pd = ... // perspective to hide
PerspectiveRegistry pr = (PerspectiveRegistry) PlatformUI.getWorkbench().getPerspectiveRegistry();
pr.removeExtension(null, pd);
but I don't know how to make it accessible for user again (perspective visible in 'Perspectives' toolbar and 'Open Perspective' dialog).
Any ideas ??
Thanks in advance,
Miłosz
[Updated on: Fri, 29 January 2010 20:05]
Report message to a moderator
Re: How to make perspective invisible for user [message #511090 is a reply to message #511024] Fri, 29 January 2010 13:36 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Your best bet is to use activities. A disabled activity will hide the
perspective, and enabling it will make it visible.
The problem is you've simply removed the descriptor from the registry
.... that would probably make the system unhappy.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to make perspective invisible for user [message #511177 is a reply to message #511090] Sat, 30 January 2010 18:51 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Hi Mi,
Another practice is not to supply the open perspective menu nor show the
perspective toolbar but create your own.
Best Regards,
Wim Jongman
-- Press CTRL-ALT-DEL to continue ...
(Eclipse Old Skool Quote Service)
> PW
> Paul Webster
Re: How to make perspective invisible for user [message #511221 is a reply to message #511024] Sun, 31 January 2010 13:11 Go to previous message
Catalin Gerea is currently offline Catalin GereaFriend
Member
Hello
See here how to replace the perspective switcher in your application.
http://eclipsesource.com/blogs/2009/03/31/replacing-the-pers pective-switcher-in-rcp-apps/.
In the fill() method of the PerspectiveSwitcherMenu class you can make available the perspective depending on your needs.
Hope this helps you.
Time is what you make of it.
Previous Topic:CDT new project wizard
Next Topic:Pb with IInputValidator
Current Time: Thu Sep 19 17:46:46 GMT 2024
Powered by FUDForum. Page generated in 0.05722 seconds
