Home » Modeling » Epsilon » Method 'getContainmentReferences' not found (190:38)
Re: Method 'getContainmentReferences' not found (190:38) [message #521621 is a reply to message #521603] |
Thu, 18 March 2010 10:10 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Marin,
Unfortunately, we've not used Eugenia with XSD-generated Ecore models
before so you're breaking new ground here :) In any case, even if
something is not natively supported by the built-in annotations, if you
figure out how to do it in plain GMF, you can then use the approach
discussed in
http://eclipse.org/gmt/epsilon/doc/articles/eugenia-polishin g/ to
reproduce it within Eugenia.
Dimitris
Marin Orlić wrote:
> Hi Dimitrios,
> you're right, I was missing some annotations, now it's working.. There
> are some things I'm not sure how to specify - my model is created from
> XSD so the structure isn't what you'd normally expect. For instance, the
> model uses a separate class for labels and stores the labels in a mixed
> attribute which is a EFeatureMapEntry, to have it stored as XML element
> CDATA content.
> Do you have any pointers how to handle such stuff?
> Marin
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Method 'getContainmentReferences' not found (190:38) [message #521634 is a reply to message #521621] |
Thu, 18 March 2010 11:02 |
Marin rli? Messages: 35 Registered: October 2009 |
Member |
Dimitrios Kolovos wrote on Thu, 18 March 2010 06:10 | Unfortunately, we've not used Eugenia with XSD-generated Ecore models
Ah, lovely
Ok, thanks, I'll see what I can make of it!
Marin.
Quote: |
Marin Orlić wrote:
> Hi Dimitrios,
> CDATA content.
> Marin
Re: Method 'getContainmentReferences' not found (190:38) [message #587555 is a reply to message #587550] |
Hi Marin,
discussed in
Dimitris
Marin Orlić wrote:
> Hi Dimitrios,
> CDATA content.
> Marin
Re: Method 'getContainmentReferences' not found (190:38) [message #587565 is a reply to message #521621] |
Member |
Ah, lovely :)
> In any case, even if something is not natively supported by the built-in annotations, if you
> discussed in
Ok, thanks, I'll see what I can make of it! :)
Marin.
> Marin Orlić wrote:
> > Hi Dimitrios,
> > CDATA content.
> > Thanks,
> > Marin
Current Time: Thu Apr 25 01:46:58 GMT 2024
Powered by FUDForum. Page generated in 0.08969 seconds
