Home » Archived » Buckminster » Error while installing PDE feature for buckminster headless 3.6
Error while installing PDE feature for buckminster headless 3.6 [message #510438] Wed, 27 January 2010 14:32 Go to next message
I can't get Buckminster headless to work at all for a PDE project. Which means no continuous integration for us Sad.
Installing 3.5 headless went wrong because of an issue with the update site (see my post here).
Installing 3.6 headless went ok using the director:
director -r http://download.eclipse.org/tools/buckminster/headless-3.6/ -d buckminster-headless/ -p Buckminster -i org.eclipse.buckminster.cmdline.product
After this, I had a buckminster-headless subdirectory and switched to this directory.
Then I installed the core headless feature like this:
buckminster install http://download.eclipse.org/tools/buckminster/headless-3.6/ org.eclipse.buckminster.core.headless.feature
which worked fine.
But when I want to install the PDE feature like this:
buckminster install http://download.eclipse.org/tools/buckminster/headless-3.6/ org.eclipse.buckminster.pde.headless.feature
I get the following reproducible error:
An error occurred while installing the items
[0]session context was:(profile=Buckminster, phase=org.eclipse.equinox.internal.
provisional.p2.engine.phases.Install, operand=null --> [R]org.eclipse.buckminste
r.jarprocessor 1.0.0.r10579, action=org.eclipse.equinox.internal.p2.touchpoint.e
clipse.actions.InstallBundleAction).
[0]Error while loading manipulator.
Caused by:
(Before I had this error I ONCE got another error about not being able to resolve artifacts such as JUnit 4.7, unfortunately I lost the output. After this command "Buckminster listsite" was the same as before this command.)
Re: Error while installing PDE feature for buckminster headless 3.6 [message #510453 is a reply to message #510438] Wed, 27 January 2010 10:06 Go to previous messageGo to next message
We've had some problems with our 3.5 update sites today. Should be OK now.
I don't recommend using 3.6 at this time since it's pretty much in flux in preparation for the imminent M5 release.
- thomas
> means no continuous integration for us :(.
> site (see
> http://www.eclipse.org/forums/index.php?t=msg&goto=51043 6&#msg_510436).
> Quote:
>> director -r
> this directory.
> Quote:
>> buckminster install
> which worked fine.
> Quote:
>> buckminster install
> Quote:
>> Caused by:
> command.)
Re: Error while installing PDE feature for buckminster headless 3.6 [message #510546 is a reply to message #510453] Wed, 27 January 2010 19:22 Go to previous messageGo to next message
Great! I will try again tomorrow.
Re: Error while installing PDE feature for buckminster headless 3.6 [message #510685 is a reply to message #510438] Thu, 28 January 2010 10:43 Go to previous message
The site works now. However, I got exactly the same issue while installing the PDE plugin. After a google search it turns out I'm not the only one facing this problem...
It can be fixed by specifying an absolute path when installing buckminster-headless, not a relative path. After this the same commands to install buckminster features work ok.
Previous Topic:examples of eclipse.org projects using buckminster and central hudson
Next Topic:Creating Eclipse RCP plugins with a Maven dependency
Current Time: Sun Feb 09 12:43:51 GMT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
