Home » Eclipse Projects » Eclipse 4 » Remote javascript debugger(Breakpoints do not work in remote javascript debugger)
Remote javascript debugger [message #510339] Wed, 27 January 2010 10:21 Go to next message
Jeroen ter Voorde is currently offline Jeroen ter VoordeFriend
I'm trying to get the remote javascript debugger to work using e4 M3 and rhino 1.7R2. I've added the code as described in the wiki:
String rhinoDebug = System.getProperty("rhino.debug");
if ( rhinoDebug != null) {
RhinoDebugger debugger = new RhinoDebugger(rhinoDebug);
debugger.start();
ContextFactory.getGlobal().addListener(debugger);
And i'm able to connect to the debugger from eclipse and get a thread list. However the debugger does not suspend on any breakpoints. I am assuming this is because it cannot match the source files to the locations my scripts return.
I've set the sourcefiles location to projectname/path and the source lookup directory to Workspace (as my scripts come from several projects). I've also tried paths relative to a single project and using that project as the lookup dir.
I'm using Windows Vista and jdk 1.6.0-18.
Any ideas?
Jeroen
Re: Remote javascript debugger [message #510620 is a reply to message #510339] Thu, 28 January 2010 02:38 Go to previous messageGo to next message
Simon Kaegi is currently offline Simon KaegiFriend
Hi Jeroen,
You're guessing right in that you're likely having problems with source
lookup. At the moment the source lookup is setup to work well with
JavaScript bundles but more general file based source lookup is not reliable
without knowing how the internals work. This is obviously something we're
working on improving right now in HEAD to ensure it demoes well at
Eclipsecon however for now your best bet is to break on script load and then
set your breakpoints in each script. After you've loaded the script once
this approach will generally work from run to run.
-Simon
"Jeroen ter Voorde" <jeroen@bitnetwerk.nl> wrote in message
news:hjp42j$8q6$1@build.eclipse.org...
> debugger.start();
> my scripts return.
> as the lookup dir.
> Any ideas?
> Jeroen
Re: Remote javascript debugger [message #510646 is a reply to message #510620] Thu, 28 January 2010 08:14 Go to previous messageGo to next message
Hi Simon,
Thanks for your reply. I will give it another shot when the next milestone is released.
Jeroen
Re: Remote javascript debugger [message #523675 is a reply to message #510646] Sun, 28 March 2010 14:55 Go to previous messageGo to next message
Jeff Simpson is currently offline Jeff SimpsonFriend
I may have missed something, but I cannot find the RemoteDebugger class? Is this installed with E4? Or do we implement our own? I see the Debugger interface is available from Rhino.
-Jeff
Re: Remote javascript debugger [message #524402 is a reply to message #523675] Wed, 31 March 2010 14:54 Go to previous messageGo to next message
The JavaScript Debug work has now graduated out of the e4 incubator and is
now part of JSDT and the Helios release.
You can find this stuff in
/cvsroot/webtools/org.eclipse.jsdt/bundles/org.eclipse.wtp.j sdt.debug.*
Now, with that said all of JSDT is packaged as part of e4 so...
-Simon
"Jeff Simpson" <jeff@syncrodoka.net> wrote in message
news:honqkn$ogk$1@build.eclipse.org...
> Thanks
> -Jeff
Re: Remote javascript debugger [message #568127 is a reply to message #510620] Thu, 28 January 2010 08:14 Go to previous messageGo to next message
Hi Simon,
Jeroen
Re: Remote javascript debugger [message #572222 is a reply to message #510646] Sun, 28 March 2010 14:55 Go to previous messageGo to next message
-Jeff
Re: Remote javascript debugger [message #572407 is a reply to message #572222] Wed, 31 March 2010 19:38 Go to previous message
-Simon
> Thanks
> -Jeff
Previous Topic:XWT Designer MigLayout
Next Topic:e4 app based on Contact demo has problem with IEclipseContext
Current Time: Thu Mar 04 10:51:16 GMT 2021
Powered by FUDForum. Page generated in 0.02020 seconds
