Home » Archived » Test and Performance Tools Platform (TPTP) » "org.eclipse.test.coretestapplication" could not be found in the registry(Automating Eclipse PDE Unit Tests using Ant)
"org.eclipse.test.coretestapplication" could not be found in the registry [message #510199] Tue, 26 January 2010 16:38 Go to next message
kent gibson is currently offline kent gibsonFriend
I am trying to run PDE unit tests using ant in 3.5, somewhat similiar to this article:
http://www.eclipse.org/articles/printable.php?file=Article-P DEJUnitAntAutomation/index.html
I can build the test client but when I start the client I always get this error:
java.lang.RuntimeException: Application "org.eclipse.test.coretestapplication" could not be found in the registry. The applications available are: ch.sbb.rcsd.client.application.application, org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
at org.eclipse.core.launcher.Main.main(Main.java:34)
To do this I have created a feature based product which has dependencies on org.eclips.test, org.eclipse.rcp and a feature that I have defined.
My test feature basically mimics the application 100%, in other words the same plugins and fragments are listed in the plugins tab.
When I validate the product "almost everything" validates. It has some problems with internal packages from org.eclipse.equinox.internal.*
Does anyone have a clue what I might be doing wrong?
Many thanks in advance.
Re: "org.eclipse.test.coretestapplication" could not be found in the registry [message #510368 is a reply to message #510199] Wed, 27 January 2010 06:28 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Kent,
Unfortunately, you have the wrong news group. I would suggest the
Eclipse PDE news group.
Paul
"kent gibson" <kentgibson@yahoo.com> wrote in message
news:hjn5r2$sc6$1@build.eclipse.org...
>this article:
> error:
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: "org.eclipse.test.coretestapplication" could not be found in the registry [message #510378 is a reply to message #510199] Wed, 27 January 2010 11:57 Go to previous message
ok thanks, i cloned it there.
Previous Topic:Access to Variables of testcase in VerificationHooksMethode
Next Topic:TPTP with Websphere 7
Current Time: Fri Jun 05 17:20:02 GMT 2020
Powered by FUDForum. Page generated in 0.06238 seconds
