Re: [CDO Teneo] Does CDOENumStringType.nullSafeGet require identical name and literal for EEnum? [message #509867 is a reply to message #509864] |
Mon, 25 January 2010 16:04 |
Bjoern Sundin Messages: 47 Registered: July 2009 |
Member |
Hi Martin,
It's entered in Bugzilla, Bug 300695. I could not assign it to anyone, though...
Re: literal for i18n. I'm not sure about this, but in generated EMF editors gui I thought to have seen the literal values.
Cheers
Bjoern
"Martin Taal" <mtaal@elver.org> schrieb im Newsbeitrag news:hjkeck$e6l$1@build.eclipse.org...
> Hi Bjoern,
> Yes this seems wrong, afaik know now the literal should be used, the error is in the nullSafeSet method and the names of the
> variables should be changed to literal.
> Can you enter a bugzilla for this and assign it to me?
> Below you say that you want to use the literal for i18n, but you mean the name maybe?
> gr. Martin
> Bjoern Sundin wrote:
>> I hope I'm not too nagging for you, but while I'm testing CDO 3.0 using a Hibernate Datastore I do get some unexpected issues.
>> In my application I define several EEnums in the ecore file. On initiating the model I get following exception:
>> [QUOTE]
>> The enum value string is not valid for enumerator: DataType
>> java.lang.IllegalStateException: The enum value string is not valid for enumerator: DataType
>> at org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOEN umStringType.nullSafeGet(CDOENumStringType.java:150)
>> [UNQUOTE]
>> As it seems the value 'string' is not recognized in the enum 'DataType' which I declare in the ecore as follows:
>> <eClassifiers xsi:type="ecore:EEnum" name="DataType">
>> <eLiterals name="boolean" literal="Boolean"/>
>> <eLiterals name="integer" value="1" literal="Integer"/>
>> <eLiterals name="float" value="2" literal="Float"/>
>> <eLiterals name="string" value="3" literal="String"/>
>> <eLiterals name="complex" value="4" literal="Complex"/>
>> </eClassifiers>
>> If I debug I find that the method CDOENumStringType.nullSafeGet on line 147 is calling getEEnumLiteralByLiteral passing the enum
>> name as parameter.
>> System outs from the method shows following:
>> name: 'string' // The name variable
>> getEEnum().getEEnumLiteralByLiteral(name.trim()): 'null' // That's why an exception is thrown
>> getEEnum().getEEnumLiteral(name.trim()): 'String' // The literal returned giving the name as parameter
>> If I modify the ecore declaration so that name and literal are identical and regenerate the model the code works well.
>> I do not really see why one has to set the name and the literal identical. I actually planned to use the literal for i18n
>> purposes.
>> Can someone help me sorting this out?
>> Cheers
>> Bjoern
> With Regards, Martin Taal
> Springsite/Elver.org
> Office: Hardwareweg 4, 3821 BV Amersfoort
> Postal: Nassaulaan 7, 3941 EC Doorn
> The Netherlands
> Cell: +31 (0)6 288 48 943
> Tel: +31 (0)84 420 2397
> Fax: +31 (0)84 225 9307
> Mail: mtaal@springsite.com - mtaal@elver.org
> Web: www.springsite.com - www.elver.org
Re: [CDO Teneo] Does CDOENumStringType.nullSafeGet require identical name and literal for EEnum? [message #509886 is a reply to message #509875] |
Mon, 25 January 2010 16:35 |
Yes, that's why the enum string type should use the literal and not the name (so it is a real bug :-).
gr. Martin
> Re: literal for i18n.On the other hand, when I look in an XMI export the literals have been used, not the name.
> /Björn
> "Bjoern Sundin" <bsu@bergauer.ch> schrieb im Newsbeitrag news:hjkfdj$814$1@build.eclipse.org...
>> Hi Martin,
>> Cheers
>> Bjoern
>>> Hi Bjoern,
>>> gr. Martin
>>>> [QUOTE]
>>>> [UNQUOTE]
>>>> </eClassifiers>
>>>> name as parameter.
>>>> purposes.
>>>> Cheers
>>>> Bjoern
>>> The Netherlands
The Netherlands
FUDForum. Page generated in 0.03494 seconds
