Home » Modeling » EMF » Get rid of Example EMF Model Creation Wizards
Get rid of Example EMF Model Creation Wizards [message #509510] Fri, 22 January 2010 16:33 Go to next message
Dirk Hoffmann is currently offline Dirk HoffmannFriend
allmost finished my EMF (version 2.2) + RCP based product.
Everything seems fine, just there is still the
"Example EMF Model Creation Wizards"
entry under File->New.
How do I get rid of that? Our customers must not be able to create empty
model instances using this wizard.
Thanks and Regards,
Dirk
Re: Get rid of Example EMF Model Creation Wizards [message #509525 is a reply to message #509510] Fri, 22 January 2010 17:02 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Dirk,
I don't use per-model wizards or editors (see my blog
http://thegordian.blogspot.com/2009/09/emf-tips-3-why-should -i-want-to.html
), but IIRC you just need to remove the respective extension from your
generated plugin.xml.
DTH?
Cheers
/Eike
Dirk Hoffmann schrieb:
> empty model instances using this wizard.
> Thanks and Regards,
> Dirk
Re: Get rid of Example EMF Model Creation Wizards [message #509718 is a reply to message #509525] Mon, 25 January 2010 07:56 Go to previous message
Hi Eike,
thanks, I should have hit on that by myself.
The extension is specified in the generated editor's plugin.xml
acconpanied by its implementing class.
Dirk
Eike Stepper schrieb:
> Hi Dirk,
> DTH?
> Cheers
> /Eike
> http://twitter.com/eikestepper
>> Hi,
>> Thanks and Regards,
>> Dirk
Previous Topic:emf validation question
Next Topic:Change in EMF Reference Navigability
Current Time: Tue Oct 27 02:10:32 GMT 2020
Powered by FUDForum. Page generated in 0.01597 seconds
