Loading a UML2 model exported with MagicDraw along with profiles [message #508943] |
Wed, 20 January 2010 19:32 |
Luca Messages: 6 Registered: October 2009 |
I'm trying to execute an atl transformation in a standalone application (clearly it works fine in eclipse...), using eclipse modeling 3.5, atl 3.0.0, uml 2.0.0 and emf 2.2.0 (the last two because the exported EMF UML2 (v.2.x) XMI models from MagicDraw 16.6 have the xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML").
I have created a java project following the "new" approach for ATL ( http://wiki.eclipse.org/ATL/Developer_Guide#ATL_Architecture and http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/examples/org.eclipse.m2m.atl.examples.publi c2private.ui/src/org/eclipse/m2m/atl/examples/public2private /ui/PrivatizeAction.java?root=Modeling_Project&view=mark up), namely using these imports:
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.core.service.CoreService;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
import org.eclipse.uml2.uml.Package;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
I first register the package (schema), the resource factory, and the "pathmaps" for UML:
resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(
UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
String umlResourcesFile = new File(
"lib/org.eclipse.uml2.uml.resources_2.0.0.v200606221411.jar").getAbsolutePath();
URI uri = URI.createURI("jar:file://" + umlResourcesFile +"!/");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
then the EMF's stuff:
CoreService.registerLauncher(new EMFVMLauncher());
CoreService.registerFactory("EMF", EMFModelFactory.class);
factory = CoreService.createModelFactory("EMF");
CoreService.registerExtractor("EMF", new EMFExtractor());
CoreService.registerInjector("EMF", new EMFInjector());
injector = CoreService.getInjector("EMF");
extractor = CoreService.getExtractor("EMF");
I load the metamodels (UML 2.0.0 and Persons, actually it's a pure example):
umlMetamodel = factory.newReferenceModel();
injector.inject(umlMetamodel, "http://www.eclipse.org/uml2/2.0.0/UML");
outputMetamodel = factory.newReferenceModel();
injector.inject(outputMetamodel, new File(metamodelsPath + "Persons.ecore").getAbsolutePath());
Then the input model:
umlModel = factory.newModel(umlMetamodel);
injector.inject(umlModel, (new File(modelsPath + "input_model.uml").getAbsolutePath()));
In this last line, I obtain the following exception:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http:///schemas/MagicDrawProfile/_yTCU4AHvEd-Q248yC_s0OA/0' not found.
pointing at the bottom of the model file at the end of this line (the last in the file):
<MagicDrawProfile:auxiliaryResource xmi:id="_yZNOUgHvEd-Q248yC_s0OA" base_Element="magicdraw_uml_standard_profile_v_0001" base_Package="magicdraw_uml_standard_profile_v_0001"/>,
while at the top the namespace is:
xmlns:MagicDrawProfile="http:///schemas/MagicDrawProfile/_yTCU4AHvEd-Q248yC_s0OA/0"
and the schemaLocation:
xsi:schemaLocation="http:///schemas/MagicDrawProfile/_yTCU4AHvEd-Q248yC_s0OA/0 UML_Standard_Profile.MagicDraw_Profile.profile.uml#_yTQXUgHv Ed-Q248yC_s0OA "
I imagine this is related to the 4 profiles that are applied in the model (MagicDraw applies them, so I have the 4 files: UML_Standard_Profile.MagicDraw_Profile.DSL_Customization.pro file.uml, UML_Standard_Profile.MagicDraw_Profile.profile.uml, UML_Standard_Profile.UML_Standard_Profile.profile.uml, UML_Standard_Profile.Validation_Profile.profile.uml).
I suppose their nsURI are not automatically resolved, so my question is how to register them properly (I tried to follow http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_register_ a_dynamic_package.3F, but without success...I think I miss something...)?
Thanks in advance
Luca
FUDForum. Page generated in 0.03966 seconds
