Home » Modeling » EMF » [CDO] Persisting cross-referenced models
[CDO] Persisting cross-referenced models [message #508910] Wed, 20 January 2010 17:12 Go to next message
Gaetan is currently offline GaetanFriend
I have a question with respect to persistance in CDO.
I have two local models (loaded from XMI resources) A and B. Model A has some references to model B.
I would like to persist A and B on the CDO server. I have no problem while persisting model B, but model A contains references to B and I could not persist those references on CDO.
Here is the code I am using:
CDOSession session = configuration.openSession();
CDOTransaction transaction = session.openTransaction();
ResourceSet cdoResourceSet = transaction.getResourceSet();
// Load resources A and B
Resource A = cdoResourceSet.getResource(..., true);
Resource B = cdoResourceSet.getResource(..., true);
// Create cdo resources
CDOResource cdoResourceA = transaction.getOrCreateResource(...)
CDOResource cdoResourceB = transaction.getOrCreateResource(...)
cdoResourceB.addAll(B.getContents()) // This works
cdoResourceA.addAll(A.getContents())
transaction.commit(); // This breaks (see below for the exact error)
transaction.close();
session.close();
Here is the execution error:
[ERROR] The object "org.eclipse.emf.ecore.impl.EObjectImpl@ed41a7
(eProxyURI: ../model/OUT.ecore#//@root.0/@elment.0/@element.4)(org.eclip se.emf.ecore.impl.EObjectImpl) " is not contained in a resource
My genmodel options:
Containment Proxies = true
Feature Delegation = Reflective
Is this the best way to proceed when committing two resources linked with cross-document references?
Gaetan.
Re: [CDO] Persisting cross-referenced models [message #508931 is a reply to message #508910] Wed, 20 January 2010 17:38 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Gaetan,
This could be a problem with CDO 3.0's "external references" that are
created during the import of your resource B (first import). But I'm not
sure.
We use to import multiple resource with EcoreUtil.copyAll(Collection<?
extends T>) and attach the resulting copies anywhere in your CDO object
graph.
BTW. I'd recommend to use a separate ResourceSet for A and B. You can
throw it away after copyAll().
Cheers
/Eike
Gaetan schrieb:
> session.close();
> [ERROR] The object
> "mailto:org.eclipse.emf.ecore.impl.EObjectImpl@ed41a7 (eProxyURI:
> Regards,
> Gaetan.
Re: [CDO] Persisting cross-referenced models [message #509150 is a reply to message #508931] Thu, 21 January 2010 14:14 Go to previous messageGo to next message
Hi Eike, thank you for your answer.
I tried the solution you suggested; here is the code from what I understood:
ResourceSet resourceSet = new ResourceSetImpl();
Resource A = resourceSet.getResource(..., true);
Resource B = resourceSet.getResource(..., true);
cdoResourceB.addAll(EcoreUtil.copyAll(B.getContents()))
cdoResourceA.addAll(EcoreUtil.copyAll(A.getContents()))
session.close();
At runtime I get a rather more telling error:
[ERROR] Rollback in DBStore: java.lang.IllegalArgumentException: DBStore does not support external references: oid:/XX/XX/model.ecore#//@element.4/@element.22
As I understand it, it seems like there is a problem with references reconcilation at commit.
Should I suppose that CDO will automatically "convert" local references to proper "CDO" ones? If so, what am I doing wrong? If not, what would be the proper pattern to convert cross documents references?
Note that since A and B are distinct models, I would be interested in keeping them in separate CDO resources.
In my first post I forgot to state the CDO version I use (2.0). Would switching to a higher version solve my problem? Is version 3.0 stable enough for general use?
Gaetan.
Re: [CDO] Persisting cross-referenced models [message #509195 is a reply to message #509150] Thu, 21 January 2010 16:03 Go to previous messageGo to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Gaetan,
the support for external references in DBStore was implemented after CDO
2.0.0 was released.
249610: [DB] Support external references (Implementation)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249610
It supposed to be included in CDO 2.0.0 SR1, but I'm not sure if we
managed to create such build. Eike?
You could take 2.0 code from CVS, it should be implemented :D
Víctor.
> understood:
> session.close();
> Regards,
> Gaetan.
Re: [CDO] Persisting cross-referenced models [message #509196 is a reply to message #509195] Thu, 21 January 2010 16:05 Go to previous messageGo to next message
Sorry, wrong bug. The correct one for 2.0 is this one:
289237: [DB] Support external references
https://bugs.eclipse.org/bugs/show_bug.cgi?id=289237
Víctor Roldán Betancort escribió:
> Gaetan,
> 2.0.0 was released.
> Cheers,
> Víctor.
>> understood:
>> session.close();
>> Regards,
>> Gaetan.
Re: [CDO] Persisting cross-referenced models [message #509355 is a reply to message #509196] Fri, 22 January 2010 08:46 Go to previous messageGo to next message
Hi Victor, Eike,
I checked out the CVS branch R2_maintenance ( server:anonymous@dev.eclipse.org:/cvsroot/modeling), which solved my problem.
Thank you,
Gaetan.
[Updated on: Fri, 22 January 2010 08:47]
Report message to a moderator
Re: [CDO] Persisting cross-referenced models [message #509359 is a reply to message #509355] Fri, 22 January 2010 08:53 Go to previous message
Gaetan schrieb:
> Hi Victor, Heike,
Eike ;-)
R2_0_maintenance ;-)
> ( server:mailto:anonymous@dev.eclipse.org:/cvsroot/modeling), which
> solved my problem.
Excellent.
Cheers
/Eike
Previous Topic:CDO 3.0 dependency on Helios
Next Topic:[CDO] Graceful server shutdown when running without a console
Current Time: Tue Jan 19 13:15:17 GMT 2021
Powered by FUDForum. Page generated in 0.01839 seconds
