Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Exception in template query
[Acceleo] Exception in template query [message #508809] Wed, 20 January 2010 12:34 Go to next message
Sebastien Roy is currently offline Sebastien RoyFriend
Member
I have the following code :
[for (importValue : String | c.attribute.type.getTypeImport(c).trim())]
import [importValue/];
[/for]
[template public getTypeImport(t : Type, c : Class)]
[/template]
That lead to the following exception :
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchO peration.run(AcceleoLaunchOperation.java:105)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 192)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 109)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchD elegate.launch(AcceleoLaunchDelegate.java:52)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: java.lang.StackOverflowError
at java.lang.reflect.Method.copy(Method.java:143)
at java.lang.reflect.ReflectAccess.copyMethod(ReflectAccess.jav a:118)
at sun.reflect.ReflectionFactory.copyMethod(ReflectionFactory.j ava:282)
at java.lang.Class.searchMethods(Class.java:2656)
at java.lang.Class.getMethod0(Class.java:2670)
at java.lang.Class.getMethod(Class.java:1603)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.getJavaMeth odFor(EcoreEvaluationEnvironment.java:151)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.getJavaMeth odFor(EcoreEvaluationEnvironment.java:1)
at org.eclipse.ocl.AbstractEvaluationEnvironment.callOperation( AbstractEvaluationEnvironment.java:177)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperati on(EcoreEvaluationEnvironment.java:89)
at org.eclipse.acceleo.engine.internal.environment.AcceleoEvalu ationEnvironment.callOperation(AcceleoEvaluationEnvironment. java:238)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperati on(EcoreEvaluationEnvironment.java:1)
at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp( EvaluationVisitorImpl.java:192)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitOperationCallExp(AcceleoEvaluationVisitor.j ava:943)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:399)
at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp( EvaluationVisitorImpl.java:161)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab stractEvaluationVisitor.java:246)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E valuationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 376)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:87 2)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:473)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 357)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:770)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 355)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplateInvocation(AcceleoEvaluation Visitor.java:805)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 366)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:491)
The exception is not thrown when the called template has only one argument :
[for (importValue : String | c.attribute.type.getTypeImport().trim())]
[/for]
[template public getTypeImport(t : Type)]
[/template]
That looks like a bug, doesn't it ?
Sebastien
Re: [Acceleo] Exception in template query [message #508861 is a reply to message #508809] Wed, 20 January 2010 15:01 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------010901040908060009030909
Hi Sebastien,
Looks like a bug alright, though I wonder what could possibly trigger
this when the template has two parameters... Could you raise a bugzilla
with the sample model and template?
Laurent Goubet
Obeo
Sebastien Roy wrote:
> Hello,
> [/for]
> [/template]
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> gin.java:1069)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Visitor.java:805)
> argument :
> [/for]
> [/template]
> Sebastien
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010901040908060009030909--
Re: [Acceleo] Exception in template query [message #508898 is a reply to message #508809] Wed, 20 January 2010 16:23 Go to previous messageGo to next message
Member
Well, the bug is not 100% reproducible.
After some changes, in the template content and in the way it is called, i haven't go any error.
The expression
c.attribute.type.MyCalledTemplate(c)
is similar to
c.attribute.type->collect(MyCalledTemplate(self,c))
I will create a test template in order to try to reproduce this problem independently from the rest of my code.
regards
[Updated on: Wed, 20 January 2010 17:36]
Report message to a moderator
Re: [Acceleo] Exception in template query [message #509052 is a reply to message #508898] Thu, 21 January 2010 09:51 Go to previous messageGo to next message
Member
I'm sorry, but I didn't succeeded in reproducing the bug in a simple test example.
It should be linked to the specific model and code context I had at this time.
Sorry
Sebastien
Re: [Acceleo] Exception in template query [message #509081 is a reply to message #509052] Thu, 21 January 2010 10:58 Go to previous message
--------------040201060802090907070705
Sebastien,
I tend to dislike bugs that come up randomly ... I hope we'll find a
sure-fire way to trigger this in order to fix the underlying issue.
For now, glad that it works as expected.
Laurent Goubet
Obeo
> test example.
> this time.
> Sorry
> Sebastien
--------------040201060802090907070705--
Previous Topic:[Xpand] TypeProposalComputer.computeProposals()
Next Topic:[Xpand] Long namespaces and editor proposals
Current Time: Sun Nov 27 02:43:52 GMT 2022
Powered by FUDForum. Page generated in 0.02352 seconds
