Home » Modeling » EMF » dialog box to confirm delete(Where to add dialog box to confirm delete?)
dialog box to confirm delete [message #508736] Wed, 20 January 2010 03:24 Go to next message
John Ye is currently offline John YeFriend
I am customizing an emf generated editor with tables and trees. I would like to add a dialog box to confirm delete and give user a chance to cancel. What is the best way to do it?
I can override Command's execute function to launch a MessageBox, but this creates coupling with UI. Besides, editor is marked as dirty already.
A related question is how to provide feedback on how many objects by type are deleted through statusLineManager, especially when delete cascade.
Thanks a lot.
Re: dialog box to confirm delete [message #508798 is a reply to message #508736] Wed, 20 January 2010 06:32 Go to previous messageGo to next message
John,
Comments below.
Does delete have some permanent impact that's not undoable?
> already.
And by then it's already been tested if it's executable and is expected
to execute properly.
> cascade.
For all these things you'd need to override DeleteAction itself.
> Thanks a lot.
Ed Merks
Re: dialog box to confirm delete [message #508903 is a reply to message #508798] Wed, 20 January 2010 16:39 Go to previous message
Ed,
Thanks a lot for your help. I will override DeleteAction's createCommand function to implement cascade deletion. I ran into problems when overriding ItemProviderAdapter's createRemoveCommand function.
I guess I can override run() function of DeleteAction to provide UI feedback.
The delete action is undoable. I plan to show a dialog box with "Do not show this dialog again" checkbox so that the dialog box is only shown the first time.
Thanks again,
John
Previous Topic:How to show an editable properties view
Next Topic:Is there a way to delete all generated code?
Current Time: Tue Jan 19 13:03:51 GMT 2021
Powered by FUDForum. Page generated in 0.02421 seconds
