Problem loading plugin class from endorsed code [message #508732] |
Wed, 20 January 2010 01:08 |
Jeff Messages: 2 Registered: January 2010 |
I am attempting to invoke a web service using the Metro library (https://metro.dev.java.net/) from within my RCP application. I bundled the relevant Metro jars (webservices-tools.jar, webservices-rt.jar, and webservices-api.jar) into a plugin and made my main application plugin depend on this new Metro plugin.
I also added the webservices-api.jar to my $JAVA_HOME/jre/lib/endorsed directory. According to the Metro website, this is required when using Metro with Java 1.6.
Now when I invoke a web service, I get the following error:
javax.xml.ws.WebServiceException: Provider com.sun.xml.ws.spi.ProviderImpl not found
at javax.xml.ws.spi.FactoryFinder.newInstance(FactoryFinder.jav a:38)
at javax.xml.ws.spi.FactoryFinder.find(FactoryFinder.java:133)
at javax.xml.ws.spi.Provider.provider(Provider.java:83)
at javax.xml.ws.Service.<init>(Service.java:56)
Caused by: java.lang.ClassNotFoundException: com.sun.xml.ws.spi.ProviderImpl
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at org.eclipse.core.runtime.internal.adaptor.ContextFinder.load Class(ContextFinder.java:129)
at javax.xml.ws.spi.FactoryFinder.newInstance(FactoryFinder.jav a:34)
... 43 more
The class com.sun.xml.ws.spi.ProviderImpl resides in webservices-rt.jar, which is a part of my Metro plugin. Furthermore, I have verified that my application plugin code can successfully load this class, so I'm not sure why javax.xml.ws.spi.FactoryFinder can't.
Since javax.xml.ws.spi.FactoryFinder resides in webservices-api.jar (the jar I had to put in the jre's endorsed directory), I suspect that this has something to do with endorsed code not being able to load classes from an Eclipse plugin.
Is it the case that code loaded by the JVM from the endorsed directory cannot load classes from plugins? Is there any way to enable this?
Java version: 1.6.0_16
Eclipse version: Eclipse Java EE IDE for Web Developers Build id: 20090920-1017 (it doesn't display a version beyond that)
Any help is greatly appreciated.
-Jeff
FUDForum. Page generated in 0.03420 seconds
