Home » Eclipse Projects » Eclipse 4 » Showing menu in e4 application
Showing menu in e4 application [message #508720] Tue, 19 January 2010 23:42 Go to next message
Lars Vogel is currently offline Lars VogelFriend
I want to add a menu to my minimal e4 application but the menu is not displayed.
I compared with the contact demo (which I also reduced for this purpose) but I cannot see any difference.
The Application.xmi is like the following.
<?xml version="1.0" encoding="ASCII"?>
<application:Application xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:application="http://www.eclipse.org/ui/2008/UIModel" id="Application">
<children xsi:type="application:Window" label="My first e4 application" iconURI="" tooltip="" id="Window" onTop="true" width="200" height="200">
<children xsi:type="application:Part" id="View1" style="" URI=" platform:/plugin/de.vogella.e4.rcp.first/de.vogella.e4.rcp.f irst.parts.View1 " containerData="" label="Hallo" tooltip=""/>
<children xsi:type="application:Menu" id="">
<children xsi:type="application:MenuItem" id="" label="File">
<children xsi:type="application:DirectMenuItem" URI=" platform:/plugin/de.vogella.e4.rcp.first/de.vogella.e4.rcp.f irst.handlers.ExitHandler " label="Exit"/>
</children>
</children>
</children>
</application:Application>
Advice would be welcome.
Best regards, Lars
Re: Showing menu in e4 application [message #508735 is a reply to message #508720] Wed, 20 January 2010 03:09 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANGFriend
Have you used the e4 Wizard to create an e4 application project? If you use
it, you will not run into this problem.
The problem is the menu is created in children. It should be mainMenu.
<mainMenu>
<children xsi:type="application:MenuItem" label="File">
</children>
</mainMenu>
I suppose you have created using EMF Reflective Editor.
Yves
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:hj5g0d$bst$1@build.eclipse.org...
> displayed.
> id="Application">
> </children>
> </children>
> </children>
> Best regards, Lars
Re: Showing menu in e4 application [message #508959 is a reply to message #508735] Wed, 20 January 2010 21:10 Go to previous messageGo to next message
Hi Yves,
thanks for the answer; it works now with your help. Sorry, I oversaw the obvious difference.
I'll update soon my e4 tutorial so that other do not have to make the same error. Once I updated it I'll post to this thread.
http://www.vogella.de/articles/EclipseE4/article.html
Best regards, Lars
Re: Showing menu in e4 application [message #508963 is a reply to message #508959] Wed, 20 January 2010 16:46 Go to previous messageGo to next message
news:hj7rg0$6qm$1@build.eclipse.org...
> Hi Yves,
> obvious difference.
I'll update the wizard today to have an example with Perspectives, ToolBar
and Menu together.
yves
Re: Showing menu in e4 application [message #508984 is a reply to message #508963] Wed, 20 January 2010 19:44 Go to previous messageGo to next message
Thanks again. I updated:
On 20.01.2010 13:25, Yves YANG wrote:
> "Lars Vogel"<Lars.Vogel@gmail.com> wrote in message
>> Hi Yves,
>> obvious difference.
> and Menu together.
> yves
Re: Showing menu in e4 application [message #567953 is a reply to message #508735] Wed, 20 January 2010 21:10 Go to previous messageGo to next message
Hi Yves,
Best regards, Lars
Re: Showing menu in e4 application [message #567975 is a reply to message #567953] Wed, 20 January 2010 21:25 Go to previous messageGo to next message
> Hi Yves,
> obvious difference.
and Menu together.
yves
Re: Showing menu in e4 application [message #567996 is a reply to message #567975] Thu, 21 January 2010 00:36 Go to previous message
>> Hi Yves,
>> obvious difference.
> and Menu together.
> yves
Previous Topic:Showing menu in e4 application
Next Topic:Problems extending the application model with PartDescriptor's.
Current Time: Sat Feb 29 08:04:06 GMT 2020
Powered by FUDForum. Page generated in 0.03288 seconds
