Re: *EXPAND* Java-Extension-Problem [message #508406 is a reply to message #508366] |
Mon, 18 January 2010 11:46 |
--------------040604030203040800000907
something like this should work:
String myJavaExtension(String s):
JAVA org.your.package.getYourExtension(
java.lang.String);
this calls a method using a java.lang.String as Parameter and also a
String as Return value
ekke
Am 18.01.10 16:06, schrieb hyperion@gmx.at:
> Hey, I tried 4 hours to use the Java-Extension of Expand, but it does
> not work as written in the documentation. I use the latest
> Itemis-Distro of eclipse:
> I can map a Java Funktion to an Expand-Funktion as long as I do not
> use any parameters. Then it works... if I use any parameters I cannot
> match the funktion anymore... I tried everything:
> 1.)
> String createData(Data data): JAVA
> generator.xml.XmlHelper.createXmlData(Data data);
> -->Does not find Data in the Mapping on the right side
> 2.)
> generator.xml.XmlHelper.createXmlData(data);
> -->Does not find data in the Mapping on the right side, same effect
> 3.)
> String createXmlData(fullpackage.Data data): JAVA
> fullpackage.Data.createXmlData(fullpackage.Data data);
> -->I get an error while calling the method in an template File
> Is this a bug, or did I something wrong? Thank you!
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
something like this should work:<br>
<br>
String myJavaExtension(String s):<br>
JAVA org.your.package.getYourExtension(<br>
java.lang.String);<br>
<br>
String as Return value<br>
<br>
ekke<br>
<br>
Am 18.01.10 16:06, schrieb <a class="moz-txt-link-abbreviated" href="mailto:hyperion@gmx.at:">hyperion@gmx.at:</a>
<blockquote cite="mid:hj1tdk$q02$1@build.eclipse.org" type="cite">Hey,
I tried 4 hours to use the Java-Extension of Expand, but it does not
work as written in the documentation. I use the latest Itemis-Distro of
eclipse:
<br>
<br>
I can map a Java Funktion to an Expand-Funktion as long as I do not use
any parameters. Then it works... if I use any parameters I cannot match
<br>
<br>
1.)
<br>
<br>
<br>
<br>
<br>
2.)
<br>
<br>
<br>
<br>
<br>
3.)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------040604030203040800000907--
ekke
independent software architect
blog: http://ekkes-corner.org
FUDForum. Page generated in 0.03109 seconds
