Home » Eclipse Projects » Plugin Development Environment (PDE) » RCP Export Problems -- "Unable to acquire application service"
RCP Export Problems -- "Unable to acquire application service" [message #51363] |
Sat, 21 March 2009 18:37 |
Jesse Riggins Messages: 24 Registered: July 2009 |
--------------070809080608020406070802
(Apologies for the cross post...please let me know if this was better
suited in one newsgroup over another)
I was seeing this problem in a separate application that I was trying to
export, but I also see it when creating a brand new headless RCP app
using the "Hello World" template.
First off, I created the new app and a launch config using only those
plugins deemed required by the system. When I attempt to run, I get the
trace listed as "Trace 1" below. After manually adding the
org.eclipse.update.configurator plugin, the launch runs successfully.
Next I created a product (HelloWorld.product) based off of the launch
config and tried to export it. Everything seems to export fine, but
when I run the eclipse.exe file, I get the "Trace 2" trace.
Would anyone have an idea as to whether or not there is something that
I'm doing wrong? I've got the sample app that I can send if need be.
Thanks in advance,
Jesse
*Trace 1:*
!SESSION 2009-03-21 12:14:23.437
eclipse.buildId=unknown
java.version=1.6.0_05
Framework arguments: -product HelloWorld.product
Command-line arguments: -product HelloWorld.product -data
C:\dev\ChiroPOS2/../runtime-HelloWorld.product -dev
file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties
-os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.109
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.IllegalArgumentException: The System Bundle's start level can
not be modified.
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1122)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:646)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:623)
at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!MESSAGE
!STACK 0
not be modified.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.125
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Platform not running
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
Trace 2:
*!SESSION 2009-03-21 12:05:43.000
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:05:43.781
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
suited in one newsgroup over another)<br>
<br>
to export, but I also see it when creating a brand new headless RCP app
using the "Hello World" template.<br>
<br>
the trace listed as "Trace 1" below. After manually adding the
org.eclipse.update.configurator plugin, the launch runs successfully.<br>
<br>
when I run the eclipse.exe file, I get the "Trace 2" trace.<br>
<br>
I'm doing wrong? I've got the sample app that I can send if need be.<br>
<br>
Thanks in advance,<br>
Jesse<br>
<br>
<b>Trace 1:</b><br>
<br>
-----------------------------------------------<br>
eclipse.buildId=unknown<br>
java.version=1.6.0_05<br>
java.vendor=Sun Microsystems Inc.<br>
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US<br>
Framework arguments: -product HelloWorld.product<br>
<a class="moz-txt-link-freetext" href=" file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties "> file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties </a>
-os win32 -ws win32 -arch x86<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.109<br>
!MESSAGE An unexpected runtime error has occurred.<br>
!STACK 0<br>
not be modified.<br>
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1122) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:646) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:623) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308) <br>
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234) <br>
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211) <br>
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141) <br>
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518) <br>
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469) <br>
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281) <br>
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247) <br>
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201) <br>
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644) <br>
at
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175) <br>
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<br>
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)<br>
at java.lang.reflect.Method.invoke(Unknown Source)<br>
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) <br>
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)<br >
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)<br>
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)<br>
<br>
!MESSAGE <br>
!STACK 0<br>
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.125<br>
!MESSAGE Application error<br>
!STACK 1<br>
java.lang.IllegalStateException: Platform not running<br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179) <br>
<br>
<br>
<br>
<b><br>
Trace 2:<br>
<br>
</b>!SESSION 2009-03-21 12:05:43.000
Command-line arguments: -os win32 -ws win32 -arch x86<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:05:43.781<br>
!STACK 1<br>
(see config.ini).<br>
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386) <br>
at
<br>
</body>
</html>
--------------070809080608020406070802--
Re: RCP Export Problems -- "Unable to acquire application service" [message #51502 is a reply to message #51475] |
Sun, 22 March 2009 11:26 |
--------------070503060200030905080303
After a week of researching, I think I found my needle in the haystack.
After trying the same thing out with an SR1 build, I noticed that in my
config.ini file, the start level for SR1 was:
*org.eclipse.core.runtime@start*
where my 3.4.2 export was:
*org.eclipse.core.runtime@2:start*
After making the change in my 3.4.2 exported application to match that
of the SR1 one, things seemed to work fine.
I'm curious, though, if anyone else is seeing this problem in 3.4.2 or
if it's just me.
Thanks for reading,
Jesse
>>> better suited in one newsgroup over another)
>>> trying to export, but I also see it when creating a brand new
>>> headless RCP app using the "Hello World" template.
>>> those plugins deemed required by the system. When I attempt to run,
>>> I get the trace listed as "Trace 1" below. After manually adding
>>> the org.eclipse.update.configurator plugin, the launch runs
>>> successfully.
>>> launch config and tried to export it. Everything seems to export
>>> fine, but when I run the eclipse.exe file, I get the "Trace 2" trace.
>>> that I'm doing wrong? I've got the sample app that I can send if
>>> need be.
>> What version of Eclipse are you using? What version of Eclipse are
>> you targetting in your target platform?
> 3.4.2 for both.
> Jesse
<html>
<head>
</head>
haystack. :-) <br>
<br>
config.ini file, the start level for SR1 was:<br>
<br>
<b>org.eclipse.core.runtime@start</b><br>
<br>
where my 3.4.2 export was:<br>
<br>
<b>org.eclipse.core.runtime@2:start</b><br>
<br>
of the SR1 one, things seemed to work fine.<br>
<br>
if it's just me.<br>
<br>
Thanks for reading,<br>
Jesse<br>
<br>
<blockquote cite="mid:gq3vsu$80k$1@build.eclipse.org" type="cite">Chris
Aniszczyk wrote:
<br>
<blockquote type="cite">Jesse Riggins wrote:
<br>
<blockquote type="cite">(Apologies for the cross post...please let
me know if this was better suited in one newsgroup over another)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
What version of Eclipse are you using? What version of Eclipse are you
<br>
</blockquote>
3.4.2 for both. <br>
<br>
Jesse
<br>
</blockquote>
<br>
</body>
</html>
--------------070503060200030905080303--
Re: RCP Export Problems -- "Unable to acquire application service" [message #593736 is a reply to message #51475] |
if it's just me.
Thanks for reading,
Jesse
>>> successfully.
>>> need be.
> 3.4.2 for both.
> Jesse
<html>
<head>
</head>
haystack. :-) <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Jesse<br>
<br>
Aniszczyk wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
Jesse
<br>
</blockquote>
<br>
</body>
</html>
Current Time: Thu Apr 18 03:56:08 GMT 2024
Powered by FUDForum. Page generated in 0.02515 seconds
