Home » Eclipse Projects » Nebula » Running Nebula Examples(Beginner Questions)
Running Nebula Examples [message #507904] Fri, 15 January 2010 05:40 Go to next message
parmy Missing name is currently offline parmy Missing nameFriend
I'd like to use the Nebula Grid in my project and thought I'd try out the examples, read through the snippets and then start work.
I've not managed to get the examples running.
This is what I have done so far:
1 - From my CVS Repositories, I've located the following entry:
HEAD: org.eclipse.swt.nebula
2 - I've Checked Out the project.
3 - I tried running directly from the Checked Out project, but I was unable to create a Run Configuration for this project. Is it possible to run directly from the Checked Out project? If so what do I need to do?
4 - I created a new Plug-in Project.
5 - Copied all the source files, icons, Manifest settings etc... from org.eclipse.swt.nebula.examples to my new Plug-in Project.
6 - I downloaded nebula-examples-ALL-incubation.zip, and updated the build path of my Plug-in Project.
7 - The project compiles ok, except for one problem in plugin.xml:
<extension point="org.eclipse.swt.nebula.examples.examples">
The error is "Unknown Extension Point".
I can confirm under the Extensions Point tab, if I open the "examples" Extension Point, the file "schema\examples.exsd" is opened and has the following entry:
<appInfo>
<meta.schema plugin="org.eclipse.swt.nebula.examples" id="examples" name="Nebula Example Part"/>
</appInfo>
I've probably approached running the examples in totally the wrong way, and any hints or pointers to an "idiots" guide to running the examples (and running checked out projects) would be warmly received.
Apologies in advance if this is not the correct forum to post these types of questions.
Cheers and thanks in advance
Parmy
Re: Running Nebula Examples [message #507908 is a reply to message #507904] Fri, 15 January 2010 06:22 Go to previous messageGo to next message
I managed to get the examples running, by importing from nebula-examples-ALL-incubation.zip.
It's good to see Grid running.
I'd would really appreciate it if someone could assist me running the "examples" from the checked-out project, so I can update the source and see the results.
I noticed one few issue:
1 - Clock does not appear on CDate Time.
Cheers
Parmy
Re: Running Nebula Examples [message #508011 is a reply to message #507908] Fri, 15 January 2010 09:56 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
You need to checkout all Nebula-Controls from CVS else OSGi leaves your
bundle in an unresolved state.
Tom
Am 15.01.10 07:22, schrieb parmy:
> Hi
> see the results.
> Cheers
> Parmy
Previous Topic:TableCombo key listener
Next Topic:Running Nebula Examples
Current Time: Fri Sep 20 14:57:54 GMT 2019
Powered by FUDForum. Page generated in 0.02567 seconds
