Re: WidgetNotFound when looking for menu item? [message #508028 is a reply to message #507870] |
Fri, 15 January 2010 15:16 |
Pascal G Messages: 157 Registered: July 2009 |
Robert M. Fuhrer wrote:
> srcEditor.setFocus(); // necessary?
No, since the setFocus() doesn't do anything right now...
> When this code begins to run, the variable 'srcEditor' refers to a Java
> editor containing a class with an appropriate main(String[]) method (a
> subsequent part of the test successfully executes this main() method).
> Moreover, this editor has focus, so I think the call to setFocus() is
> unnecessary.
> Any clues as to why this fails?
I'd like to know more about your failure. Is it an assert that fails or
an exception? What's the error message? At which line does it fail?
Also, I haven't tested much the menus with SWTBot, only thing I can say
is that sometime some of my tests fail because they can't find the File
menu... however, I haven't tried to consistently reproduce this
behavior, so it doesn't really classify as a bug, yet.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: WidgetNotFound when looking for menu item? [message #508098 is a reply to message #508028] |
Fri, 15 January 2010 21:42 |
Robert M. Fuhrer Messages: 294 Registered: July 2009 |
It fails with a WidgetNotFoundException at the line that reads
SWTBotMenu runJavaAppItem = runAsMenu.menu("Java Application");
Here's the backtrace:
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundExcep tion: The widget was null.
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.<init>(AbstractSWTBot.java:97)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.<init>(SWTBotMenu.java:42)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.menu(SWTBot Menu.java:96)
at swtbot.example.SWTTest1.jdtSmokeTest(SWTTest1.java:227)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(Ru nBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(Run Afters.java:31)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:73)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java: 173)
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner. run(SWTBotJunit4ClassRunner.java:54)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:46)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
at java.lang.Thread.run(Thread.java:637)
>> unnecessary.
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
FUDForum. Page generated in 0.03514 seconds
