Home » Eclipse Projects » Eclipse 4 » Using the e4 dependency injection implementation outside e4
Using the e4 dependency injection implementation outside e4 [message #507831] Thu, 14 January 2010 20:00 Go to next message
Lars Vogel is currently offline Lars VogelFriend
I would like to use the DI implementation of e4 outside of e4 (similar to Google Guice).
Is that possible? If yes, any pointer how to do this?
Best regards, Lars
Re: Using the e4 dependency injection implementation outside e4 [message #508350 is a reply to message #507831] Mon, 18 January 2010 14:05 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Lars Vogel wrote:
> Hello,
> to Google Guice).
Pointers, probably not :-)
But it should be usable with 3 plugins: org.eclipse.e4.core.services,
org.eclipse.e4.core.services.annotations, and javax.inject
org.eclipse.e4.core.services.context.spi.ContextInjectionFac tory to
inject and make (instantiate and then inject) an object. It also
supports an "invoke" (allows you to call a method with inject
parameters). Then all you need is an IEclipseContext full of values
from org.eclipse.e4.core.services.context.EclipseContextFactory :-)
Later,
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Using the e4 dependency injection implementation outside e4 [message #508470 is a reply to message #508350] Mon, 18 January 2010 23:38 Go to previous messageGo to next message
Thanks for the tips. :-)
On 18.01.2010 06:05, Paul Webster wrote:
> Lars Vogel wrote:
>> Hello,
>> to Google Guice).
> parameters). Then all you need is an IEclipseContext full of values from
> Later,
> PW
Re: Using the e4 dependency injection implementation outside e4 [message #567673 is a reply to message #507831] Mon, 18 January 2010 14:05 Go to previous messageGo to next message
Lars Vogel wrote:
> Hello,
> to Google Guice).
Later,
PW
Paul Webster
Re: Using the e4 dependency injection implementation outside e4 [message #567767 is a reply to message #508350] Tue, 19 January 2010 04:12 Go to previous message
> Lars Vogel wrote:
>> Hello,
>> to Google Guice).
> Later,
> PW
Previous Topic:Where is the ShowView-dialog in the e4 photo demo?
Next Topic:How to create a new Part Dynamically
Current Time: Wed Dec 06 14:46:18 GMT 2023
Powered by FUDForum. Page generated in 0.02899 seconds
