Home » Eclipse Projects » Plugin Development Environment (PDE) » Build Path Incomplete(Cannot find an class-file from included jar-library)
icon5.gif  Build Path Incomplete [message #507684] Thu, 14 January 2010 11:34 Go to next message
No real name is currently offline No real nameFriend
this is propably a newbish question/problem:
I'm trying to compile the source of Relo.
I managed to reduce the number of errors in the checked out project from 100 to 2 by adding the required referenced librarys from the GEF.
The remaining errors are:
  1. The project was not build since its build path is incomplete. Cannot find the class file for org.eclipse.core.runtime.Plugin. Fix the build path then try building this project.
  2. The type org.eclipse.core.runtime.Plugin cannot be resolved. it is indirectly referenced from requred .class files.
I do not completely understand how I can complete the Build Path, as it already includes the org.eclipse.runtime_3.5.0.20090525.jar which contains the Plugin.class
But I'm a virgin wrt Eclipse and plug-in programming, so maybe I'm missing something basic or obvious here.
Thanks for any thoughts.
[Updated on: Thu, 14 January 2010 11:43]
Report message to a moderator
Re: Build Path Incomplete [message #508171 is a reply to message #507684] Sun, 17 January 2010 02:29 Go to previous messageGo to next message
Vineet Sinha is currently offline Vineet SinhaFriend
The Relo codebase has had a new home for the last 2+ years. See
www.architexa.com - it is in private beta, but we are beginning to let
users in.
Vineet
eclipseuser@mailinator.com wrote:
> Hello,
> http://relo.csail.mit.edu/developers.html
Re: Build Path Incomplete [message #508172 is a reply to message #507684] Sun, 17 January 2010 02:52 Go to previous messageGo to next message
Member
The Relo codebase has had a ew home for the last 2+ years. See www.architexa.com - it is in prviate beta, but we are beginning to let users in.
Vineet
Re: Build Path Incomplete [message #508318 is a reply to message #508172] Mon, 18 January 2010 12:08 Go to previous message
Well thanks for the pointer, but that does not really help me in building the project. You're now working with a closed source I guess.
I'd like to build upon Relo's functionality for a Diploma Thesis of my own and it would be great not to reimplement all the class/method-extraction stuff.
Chris
Update: Problem solved. Just in case anybody runs into the same problem:
I worked under the wrong assumption, that the repository contained one plug-in and therefore one project, which it does not. Check out the
  • edu.mit.csail.relo
  • edu.mit.csail.relo.console
  • edu.mit.csail.relo.intro
  • edu.mit.csail.relo.jdt
  • edu.mit.csail.relo.log4j
  • edu.mit.csail.relo.store
  • jiggle
  • org.apache.commons.collections
projects from the repository, correct the single exception error, and then run the edu.mit.csail.relo plugin.
Said I was a noob, didn't I Wink.
Chris
[Updated on: Mon, 18 January 2010 12:49]
Previous Topic:plugin with POI
Next Topic:Build Path Incomplete
Current Time: Sun Jun 13 13:59:59 GMT 2021
Powered by FUDForum. Page generated in 0.02188 seconds
