Home » Modeling » EMF » monitoring the progress of loading resources
monitoring the progress of loading resources [message #507629] Thu, 14 January 2010 08:02 Go to next message
Robert Wloch is currently offline Robert WlochFriend
I was wondering if there's a way to hook a progress monitor for loading resources. Currently I am working with a quite big model that's partitioned in several files. Loading a resource using
Resource resource = resourceSet.getResource(uri, true);
can take up to 40 seconds in my case.
The Javadoc of Resource.load(options) mentions the Eclipse progress monitor but I couldn't find an example where it's actually used.
Can someone provide a small sample or a hint how to do it?
Thanks in advance!
Rob
Re: monitoring the progress of loading resources [message #507711 is a reply to message #507629] Thu, 14 January 2010 12:44 Go to previous messageGo to next message
Robert,
XSDResourceImpl shows an example.
Robert Wloch wrote:
> that's partitioned in several files. Loading a resource using Resource
> resource = resourceSet.getResource(uri, true); can take up to 40
> seconds in my case.
> Thanks in advance!
> Rob
Ed Merks
Re: monitoring the progress of loading resources [message #507714 is a reply to message #507711] Thu, 14 January 2010 13:03 Go to previous messageGo to next message
Ed,
I've had a look at that class before my post. Since you point me to it again, I suppose the functionality has to be provided by a custom Resource implementation. I was hoping it's already there and I just needed the right options key. So, in my case I'll need to provide a custom GMFResource and a custom LazyLinkingResource then.
Rob
Re: monitoring the progress of loading resources [message #507724 is a reply to message #507714] Thu, 14 January 2010 13:18 Go to previous message
Robert,
You might be able to make due with a OPTION_RESOURCE_HANDLER if they're
derived from XMLResource. Given we have a ProgressMonitor API in EMF
itself, one could imagine making better use of that in the base framework...
Robert Wloch wrote:
> Ed,
> Quote:
> Regards
> Rob
Ed Merks
Previous Topic:editor code usage
Next Topic:Re: [emf-dev] exposing Ecore models via web services
Current Time: Sun Sep 27 07:33:06 GMT 2020
Powered by FUDForum. Page generated in 0.02076 seconds
