Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Using EMF+ with SWT
Using EMF+ with SWT [message #507369] Wed, 13 January 2010 03:18 Go to next message
Jan Mauersberger is currently offline Jan MauersbergerFriend
I'm trying to find a way to draw draw2d graphics into an EMF+ file. The
background: before I was using the EMF library from FreeHEP to write EMF
files but unfortunately FreeHEP/EMF does not support transparency. I
found out that this is supported by EMF+ which in turn is part of GGI+.
I tried alternatives as the Tritos project which is using a custom
Device implementation that uses handles to native enhanced meta file
structures in conjunction with SWT but again this is only EMF.
My plan was now to write my own Device (or what ever), create a GDI+
Metafile object and somehow "force" (or just ask) SWT to use this in the
drawing context in enhanced Gdip mode.
Unfortunately I'm stuck. It seems that in advanced Gdip mode the SWT is
using the "Gdip.Graphics_new(int /*long*/ hdc)" method to create a
Grphics object which does (in the native code) uses the new
Graphics(HDC) constructor. As far as I can see I have to use the
Graphics(Image) constructor because the Metafile class is extending the
Image class.
Does anyone has an idea how to accomplish that without writing my own
drawing context from scratch?
Thanks a lot in advance
Jan
PS: Any plans to improve the Gdip support in SWT?
Re: Using EMF+ with SWT [message #509715 is a reply to message #507369] Mon, 25 January 2010 07:34 Go to previous message
Just to answer myself and to renew this question :-)
If I wrap the native Metafile with a native Graphics object and pass
this to the SWT GC, again the result is only EMF (not EMF+). The only
solution I partially accomplished was to write my own SWT Graphics
object that uses the native GDIP Graphics object and more or less does
the same things as the SWT GC but that' a lot of copy & paste from the
GC class ;-(
The simplest way would be to allow passing an own native GDIP Graphics
object to the GC but the current SWT implementation doe snot support
this. Any chance to get that supported in the future?
Jan
> Hello,
> Image class.
> Jan
Previous Topic:Best way to embed Links in Text
Next Topic:Table: Removing not only items, but also all colums
Current Time: Tue Aug 04 18:58:59 GMT 2020
Powered by FUDForum. Page generated in 0.01952 seconds
