[Announce] M2T templates for Java metamodel [message #507111] |
Tue, 12 January 2010 08:45 |
Fabien Giquel Messages: 147 Registered: July 2009 |
A new plugin, for working with Java models, is available :
the goal of this 'Java Generation' plugin is to allow Java code
generation from a Java model.
Such a generation will participate to Legacy Refactoring & Migration chains.
For more informations :
http://wiki.eclipse.org/MoDisco/JavaGeneration
Fabien GIQUEL
R&D Engineer
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
Fabien GIQUEL
R&D Engineer
Mia-Software
rue Nina Simone
44000 NANTES
Re: [Announce] M2T templates for Java metamodel [message #509943 is a reply to message #509870] |
Mon, 25 January 2010 20:31 |
Hi Jean-Sebastien, hi Sylvain,
"Java discoverer +M2T" process allows quite a round-trip scenario :
- you will not loose any Java information (including ordering)
- you will loose your original indentation (spaces, tabs, line feed) -> in fact, at the end of the M2T, a call to JDT formater is done (i.e. ctrl+shift+f)
- some '/***...*' will become '/*'
- some '{' may appear enclosing blocks which did not have it before (e.g. within if statements).
Moreover, at the moment, there is an issue on discoverer which may move some Java comments, i will fix it asap.
In order to improve the round-trip, i suppose we may follow two ways :
- build traceability links with original files parts, to restore original source regions where not modified.
- as Sylvain suggests it, keep links to JDT AST nodes to use JDT rewriting apis.
Fabien GIQUEL
R&D Engineer
Mia-Software
rue Nina Simone
44000 NANTES
Re: [Announce] M2T templates for Java metamodel [message #574175 is a reply to message #507134] |
Tue, 12 January 2010 11:11 |
Le 12/01/2010 10:47, Sylvain EVEILLARD a écrit :
> Just a quick question, are those templates generated or hand-coded ?
templates are 95% hand-coded (templates declarations were generated)
Fabien GIQUEL
R&D Engineer
Mia-Software
Fabien GIQUEL
R&D Engineer
Mia-Software
rue Nina Simone
44000 NANTES
Re: [Announce] M2T templates for Java metamodel [message #574467 is a reply to message #574416] |
Fabien GIQUEL
R&D Engineer
Mia-Software
Fabien GIQUEL
R&D Engineer
Mia-Software
rue Nina Simone
44000 NANTES
FUDForum. Page generated in 0.03830 seconds
