Home » Modeling » EMF » EObject to String
Re: EObject to String [message #507290 is a reply to message #507275] |
Tue, 12 January 2010 18:18   |
Ed Merks Messages: 31780 Registered: July 2009 |
Milan,
Well, a String can't be an EObject so that's just not going to work
other than how I've already spelled out. You could make the type be
EJavaObject, i.e., the EDataType that wraps java.lang.Object, but that's
not going to serialize nicely.
Milan Milanovich wrote:
> Dear Mr. Merks,
> well, my class is defined like this:
> class Expr {
> body : EObject;
> i.e., body is EObject type, because I need to give it different
> reference types during runtime. Sometimes it should be instances of a
> String, but sometimes it should be EBoolean. I'm just wondering how to
> assign different types to the body in runtime.
> Regards, Milan
Ed Merks
Re: EObject to String [message #508233 is a reply to message #507290] |
Sun, 17 January 2010 23:34   |
Milan Milanovich Messages: 201 Registered: July 2009 |
Dear Mr. Merks,
I have created a volatile, transient property in my EMF code and tried to implement it, like this:
final CommonFactory factory = CommonFactoryImpl.eINSTANCE;
final CommonPackage cPackage = CommonPackageImpl.eINSTANCE;
ItemDefinition itemDefintion = factory.createItemDefinition();
SimpleAnyType ant = XMLTypeFactory.eINSTANCE.createSimpleAnyType();
ant.setInstanceType((EcorePackage.eINSTANCE.getEString()));
FormalExpression fe = factory.createFormalExpression();
fe.setBody(ant);
and on the end of this method, I call generated method to populate it with created data: setConditionExpression(fe);
However, when I try to save this object...graphically in GMF, I'm getting an error: ItemDefinition is not contained in a resource. What do I need to do?
Milan
[Updated on: Sun, 17 January 2010 23:36] Report message to a moderator
Re: EObject to String [message #508349 is a reply to message #508237] |
Mon, 18 January 2010 14:09   |
Dear Mr. Merks,
Ed Merks wrote on Sun, 17 January 2010 19:22 | Milan,
Comments below.
> Dear Mr. Merks,
Why access it via the Impl class when it's defined in the interface?
Yes, you are right, my mistake...
EcorePackage.Literals.ESTRING works too and it's a constant.
O.K.
> do I need to do?
If it's a non-containment reference, you'll have to store it in some
other containment reference or at the root of a resource.
Yes, it is a non-containment reference, and I cannot store it to some other containment reference. So, I need to store it at the root of a resource ? How can I get a resource in my model Implementation class ?
thanks, Milan
Re: EObject to String [message #508386 is a reply to message #508349] |
Mon, 18 January 2010 15:54   |
Milan,
In general you can't assume there is always a resource, but
EObject.eResource() will return it if there is one.
> Dear Mr. Merks,
>> Milan,
>> Comments below.
>> > Dear Mr. Merks,
>> tried > to implement it, like this:
> O.K.
>> it > with created data: setConditionExpression(fe);
>> > However, when I try to save this object...graphically in GMF, I'm >
>> > do I need to do?
> thanks, Milan
Ed Merks
Re: EObject to String [message #508436 is a reply to message #508425] |
Mon, 18 January 2010 19:27   |
Dear Mr. Merks,
Ed Merks wrote on Mon, 18 January 2010 12:56 | Milan,
resource.getContents().add(child)
Good, now I don't get the error, however all of these elements are not saved in the file. E.g., this is saved:
<conditionExpression xsi:type="bpmn2_2:FormalExpression" language="ocl" evaluatesToTypeRef="/1" body="/2"/>
evaluatesToTypeRef and body elements are the elements which I have added to the resource, but they are not saved in the file?
thanks, Milan
[Updated on: Mon, 18 January 2010 19:28] Report message to a moderator
Re: EObject to String [message #508588 is a reply to message #508436] |
Tue, 19 January 2010 14:48   |
Milan,
Only an XMIResourceImpl will save multiple roots, so you'll need to rely
on an XMI serialization.
> Dear Mr. Merks,
>> Milan,
> thanks, Milan
>> > Dear Mr. Merks,
>> > Ed Merks wrote on Mon, 18 January 2010 10:54
>> >> Milan,
>> >> In general you can't assume there is always a resource, but >>
>> > O.K. Thank you.
>> > In the case, when I do this:
>> > final CommonFactory factory = CommonFactory.eINSTANCE;
>> > final CommonPackage cPackage = CommonPackage.eINSTANCE;
>> > I can get eResource() from another object in this method, but how
>> can > I add the itemDefinition to the Resource?
>> > -- > Regards, Milan
Ed Merks
Re: EObject to String [message #508694 is a reply to message #508588] |
Tue, 19 January 2010 21:49   |
Dear Mr. Merks,
good, thanks. I switched to XMI in genmodel and it works now...i.e., it is saved in XMI file. However, when I try to read the SimpleAnyType value I get an exception. I save like this:
Resource r =someObject.eResource();
ant.setInstanceType(EcorePackage.Literals.ESTRING);
ant.setValue(newCondition);
r.getContents().add(ant); // add to resource
this works well, however when I tried to load the value later:
SimpleAnyType ant = (SimpleAnyType)((FormalExpression) e).getBody();
String s = (String)ant.getValue(); <- here I get an exception:
at org.eclipse.emf.ecore.util.EcoreUtil.createFromString(EcoreUtil.java:3257)
at org.eclipse.emf.ecore.xml.type.impl.SimpleAnyTypeImpl.getValue(SimpleAnyTypeImpl.java:124)
what is the problem here?
Regards, Milan
[Updated on: Tue, 19 January 2010 21:51] Report message to a moderator
Re: EObject to String [message #508855 is a reply to message #508850] |
Wed, 20 January 2010 14:58   |
Dear Mr. Merks,
O.K., but where can I found XMLResource in this case?
Is it O.K. to do this in my PackageResourceImpl extends XMIResourceImpl constructor:
Map options = new HashMap();
options.put(XMIResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
save(options);
btw- I'm using XMI serialization now.
Regards, Milan
[Updated on: Wed, 20 January 2010 15:19] Report message to a moderator
Re: EObject to String [message #508888 is a reply to message #508881] |
Wed, 20 January 2010 16:08   |
Dear Mr. Merks,
I meant above...sorry. I repeat it here:
I put this code in my PackageResourceFactory:
save(options);
However, the problem remains. Everything is written good with this code:
FormalExpression fe = (FormalExpression) e;
Resource r = fe.eResource();
fe.setBody(ant);
this is what I get in the model file (an excerpt):
<bpmn2_2:ItemDefinition structure="/3"/>
<xsd:SimpleAnyType>
some string <instanceType href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</xsd:SimpleAnyType>
however, when I try to read this by using this code:
String s = (String)ant.getValue(); <- here I get an exception shown below
I get and exception:
at ca.athabascau.semtech.bpmn2.common.impl.SequenceFlowImpl.getCondition(SequenceFlowImpl.java:330)
Milan
[Updated on: Wed, 20 January 2010 16:43] Report message to a moderator
Re: EObject to String [message #508899 is a reply to message #508888] |
Wed, 20 January 2010 16:21   |
--------------090404060803040702020805
Milan,
Here's what the resource factory looks like for a model generated from
XML Schema:
* Creates an instance of the resource.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public Resource createResource(URI uri) {
XMLResource result = new LibraryResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER,
Boolean.TRUE);
return result;
> Dear Mr. Merks,
> save(options);
> Milan
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Milan,<br>
<br>
XML Schema:<br>
<blockquote><small>Â Â Â /**</small><br>
<small>Â Â Â Â * Creates an instance of the resource.</small><br>
<small>Â Â Â Â * <!-- begin-user-doc --></small><br>
<small>Â Â Â Â * <!-- end-user-doc --></small><br>
<small>Â Â Â Â * @generated</small><br>
<small>Â Â Â Â */</small><br>
<small>Â Â Â @Override</small><br>
<small>Â Â Â public Resource createResource(URI uri) {</small><br>
<small>Â Â Â Â Â Â XMLResource result = new LibraryResourceImpl(uri);</small><br>
<small>Â Â Â Â Â Â
Boolean.TRUE);</small><br>
<small>Â Â Â Â Â Â
<br>
<small>Â Â Â Â Â Â
<br>
<small>Â Â Â Â Â Â
<small>Â Â Â Â Â Â
<br>
<small>Â Â Â Â Â Â
<small>Â Â Â Â Â Â return result;</small><br>
<small>Â Â Â }</small><br>
</blockquote>
<br>
<br>
<blockquote cite="mid:hj79qn$s7u$1@build.eclipse.org" type="cite">Dear
Mr. Merks, <br>
<br>
<br>
constructor:
<br>
<br>
<br>
       <br>
<br>
   Â
<br>
save(options);
<br>
<br>
<br>
<br>
<br>
Milan
<br>
</blockquote>
</body>
</html>
--------------090404060803040702020805--
Ed Merks
Re: EObject to String [message #508907 is a reply to message #508905] |
Wed, 20 January 2010 16:51   |
Dear Mr. Merks,
I have updated my method and it now looks like this:
XMIResource result= new CommonResourceImpl(uri);
result.getDefaultSaveOptions().put(XMIResource.OPTION_EXTENDED_META_DATA,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMIResource.OPTION_EXTENDED_META_DATA,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMIResource.OPTION_SCHEMA_LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMIResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMIResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMIResource.OPTION_USE_LEXICAL_HANDLER,
Boolean.TRUE);
return result;
however, I'm still gettng an exception when I try to get SimpleAnyType value, as I desribed here.
Thanks, Milan
Re: EObject to String [message #508912 is a reply to message #508907] |
Wed, 20 January 2010 17:11   |
Milan,
What does the serialization look like?
> Dear Mr. Merks,
> @Override
> result.getDefaultSaveOptions().put(XMIResource.OPTION_EXTEND ED_META_DATA,
> Boolean.TRUE);
> result.getDefaultLoadOptions().put(XMIResource.OPTION_EXTEND ED_META_DATA,
> Boolean.TRUE);
> result.getDefaultSaveOptions().put(XMIResource.OPTION_SCHEMA _LOCATION,
> Boolean.TRUE);
> result.getDefaultLoadOptions().put(XMIResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
> Boolean.TRUE);
> result.getDefaultSaveOptions().put(XMIResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
> Boolean.TRUE);
> result.getDefaultLoadOptions().put(XMIResource.OPTION_USE_LE XICAL_HANDLER,
> Boolean.TRUE);
> return result;
> http://www.eclipse.org/forums/index.php?t=msg&&th=16 0464&goto=508888#msg_508888
> Thanks, Milan
Ed Merks
Re: EObject to String [message #508935 is a reply to message #508932] |
Wed, 20 January 2010 18:40   |
Dear Mr. Merks,
Ed Merks wrote on Wed, 20 January 2010 12:40 | Milan,
That looks okay, but not what I'd expect. The stack trace you show
makes it sound like the instanceType is null though, but I'd expect it
to be set based on what I see below. One thing that seems problematic
though is that the instanceType reference is cross document and yet the
instanceType feature doesn't do cross document proxy resolution. It's
generally expected that the serialization would be using a containing
element along with an xsi:type but given you're putting this at the root
of a document, there is no good element name to use. I think the best
approach would be to define some type of "ValueContainer" EClass with a
containment reference to EObject and to nest all these "free floating
values" inside that container which in turn is nested at the root of the
resource.
Actually, the instanceType is not null, but the value. If I try to read the instance type I get:
org.eclipse.emf.ecore.impl.EDataTypeImpl@1092e60 (eProxyURI: http://www.eclipse.org/emf/2002/Ecore#//EString)
so it's not null.
I'm what is the ValueContainer eclass, but when I set the body (of SimpleAnyType) to my FormalExpression instance, it is already initialized by using the seq initializer in gmfmap.
One general question regarding this subject, i.e., non-containament references which are not defined graphically in gmf, e.g.:
class SequenceFlow{
expression[0..1]: Expression;
class FormalExpression extends Expression { <- this class is not defined graphically
body : EObject;
language : EString;
I want to enable that when a user clicks on the SequenceFlow, he can define its expression, by instantiating
the FormalExpression and populating the body with empty String and the language with asting. Then, user
should enter body of the FormalExpression. This is maybe GMF related question, but I want to ask you what strategy do you recommend me (example?) ?
thanks, Milan
[Updated on: Wed, 20 January 2010 18:45] Report message to a moderator
Re: EObject to String [message #508937 is a reply to message #508935] |
Wed, 20 January 2010 18:47   |
Milan,
Comments below.
> Dear Mr. Merks,
>> Milan,
>> it to be set based on what I see below. One thing that seems
>> problematic though is that the instanceType reference is cross
>> document and yet the instanceType feature doesn't do cross document
>> proxy resolution. It's generally expected that the serialization
>> would be using a containing element along with an xsi:type but given
>> you're putting this at the root of a document, there is no good
>> element name to use. I think the best approach would be to define
>> some type of "ValueContainer" EClass with a containment reference to
>> EObject and to nest all these "free floating values" inside that
>> container which in turn is nested at the root of the resource.
> mailto:org.eclipse.emf.ecore.impl.EDataTypeImpl@1092e60 (eProxyURI:
> so it's not null.
Yes, as I said, that feature doesn't try to resolve proxies but the
serialization would result in a proxy being created.
> I'm what is the ValueContainer eclass, but when I set body (of
> initialized by using seq initializer in gmfmap.
> class SequenceFlow{
> defined graphically
> body : EObject;
> language : EString;
> I want to enable that when a user click on the SequenceFlow, he can
> the FormalExpression and populating body with empty String and
> language with some other sting. Then, user
> (example?) ?
It's a GMF question for which I don't know the answer.
> thanks, Milan
Ed Merks
Re: EObject to String [message #508952 is a reply to message #508939] |
Wed, 20 January 2010 20:25  |
Milan,
Comments below.
> Dear Mr. Merks,
> O.K. Thank you. Regarding this:
>> Milan,
> I have a top-most element of my model called Collaboration, which have
> containment reference to a Definitions object. This Definitions object
> is intended to be used for defining some types. It definition looks
> like this:
> class Definitions {
I tend to have an aversion to classes with a puralized name because it's
very hard to create well formed English sentence from such nouns. You
create a Definitions. What if there are two Definitions as opposed to
just one.
> targetNamespace : EString;
> typeLanguage : EString;
> rootElements : RootElement;
> imports : Import;
> extensions : Extension;
> Is this class good candidate for the " ValueContainer" EClass ? Or
> should I add it one EObject[0..*] containment reference to hold all of
> the SimpleValueTypes?
Yes, you need some type of EObject containment reference somewhere.
> thanks, Milan
Ed Merks
Current Time: Sun Mar 07 10:09:22 GMT 2021
Powered by FUDForum. Page generated in 0.03311 seconds
